The breather exhausts excess pressure built up in your crank case. Anything
that would allow pressure created in the combustion chambers into your crank case can lead to additional pressure and excess oil being emitted from your breather along with the gasses. A bad oil ring on a piston or anything not sealing in the valve train... valve not seating properly or a worn valve guide. I'm not an A&P, and this would be better confirmed by Jim or others, but I would imagine that either a oil return line or even a pushrod sleeve would allow pressure from a cylinder head into the case. Guys? Jim "Robert M. Gary" wrote in message ups.com... Jim Burns wrote: No, remember on a compression check your valves are closed, thus why I suggested the valve wobble test. Not saying the guide is cracked, but it or they could be worn. I was just trying to keep the symptom (excess oil out the breather) separated from the cause (unknown) and relate what I had discovered. If it were caused by a valve problem though would the oil still come out the breather? My engine seems extreamly clean of oil. I can see oil dripping from the breather. -Robert |
Check the valve guides and seals, with the valve closed,
compression will be good. But when the valve opens, if the guide is worn or the seal is bad, oil will be sucked from the top end. "Robert M. Gary" wrote in message oups.com... | | Jim Burns wrote: | It seems like I'm agreeing with Jim these days, I'd also say that something | is creating excessive case pressure. Along those lines I just tore down a | horizontally opposed Kohler that was blowing oil from the breather faster | than I could dump it in. It had blown a cylinder barrel seal, not a gasket, | just an RTV seal. The key is that something caused the seal to blow. What | did I find? Cracked exhaust valve guide that allowed exhaust pressures into | the case. | | Would that show up in a compression test though? I"m getting 79's all | around in the compression test. The IA seemed impressed with the | compression. Also, my EGTs seem to be running about the same. | | -Robert | |
The change in oil consumption may be cause for concern as already mentioned,
but as to the cooling effect of the extra couple of quarts of oil, I have never seen my A4A run cooler on 8 quarts than on 6 (It's about 115 F here today.) It consistently uses 1 quart every 8 hours which is not unusual for this type engine. I have seen discussions about very low oil consumption being a cause for concern because it may cause lubrication issues in the cylinders. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel "Robert M. Gary" wrote in message ups.com... I have an IO-360-A3B6 900 SFNEW in '97. I used to be able to keep about 7 quarts in it without it blowing out. Now it seems to be blowing oil down to about 5.5 quarts. Since I live in the 100F OATs part of the country, the extra oil really helps cooling. Should I worry about what is causing the extra oil blow out or just chock it up to an aging engine. I know some engines always blow out to 6ish quarts. If I shouldn't worry about the extra blow out I'll just put a separator on it, but I don't want to mask a problem first. One recent change is we raised the oil pressure since the regulator had been slipping prior to annual. -Robert |
I am curious, what is your oil temp in those 'HOT'" conditions?
Ben Mike Noel wrote: The change in oil consumption may be cause for concern as already mentioned, but as to the cooling effect of the extra couple of quarts of oil, I have never seen my A4A run cooler on 8 quarts than on 6 (It's about 115 F here today.) It consistently uses 1 quart every 8 hours which is not unusual for this type engine. I have seen discussions about very low oil consumption being a cause for concern because it may cause lubrication issues in the cylinders. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel "Robert M. Gary" wrote in message ups.com... I have an IO-360-A3B6 900 SFNEW in '97. I used to be able to keep about 7 quarts in it without it blowing out. Now it seems to be blowing oil down to about 5.5 quarts. Since I live in the 100F OATs part of the country, the extra oil really helps cooling. Should I worry about what is causing the extra oil blow out or just chock it up to an aging engine. I know some engines always blow out to 6ish quarts. If I shouldn't worry about the extra blow out I'll just put a separator on it, but I don't want to mask a problem first. One recent change is we raised the oil pressure since the regulator had been slipping prior to annual. -Robert |
During climb at 100 mph indicated there is about a needle width of green
between the oil temperature indicator needle and red-line. When I throttle back to a cruise power setting of about 2500 RPM @ 6500 MSL and a bit rich of peak on the leanest cylinder, the oil temp gauge drops back to a couple of needle widths below red-line. I suspect the oil cooler could use a flush, but the oil cooler bypass valve was replaced about a year ago and its seat in the oil filter adapter was lapped. The bypass valve work produced a noticeably cooler climb. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel wrote in message ups.com... I am curious, what is your oil temp in those 'HOT'" conditions? Ben Mike Noel wrote: The change in oil consumption may be cause for concern as already mentioned, but as to the cooling effect of the extra couple of quarts of oil, I have never seen my A4A run cooler on 8 quarts than on 6 (It's about 115 F here today.) It consistently uses 1 quart every 8 hours which is not unusual for this type engine. I have seen discussions about very low oil consumption being a cause for concern because it may cause lubrication issues in the cylinders. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel "Robert M. Gary" wrote in message ups.com... I have an IO-360-A3B6 900 SFNEW in '97. I used to be able to keep about 7 quarts in it without it blowing out. Now it seems to be blowing oil down to about 5.5 quarts. Since I live in the 100F OATs part of the country, the extra oil really helps cooling. Should I worry about what is causing the extra oil blow out or just chock it up to an aging engine. I know some engines always blow out to 6ish quarts. If I shouldn't worry about the extra blow out I'll just put a separator on it, but I don't want to mask a problem first. One recent change is we raised the oil pressure since the regulator had been slipping prior to annual. -Robert |
![]() Robert M. Gary wrote: I have an IO-360-A3B6 900 SFNEW in '97. I used to be able to keep about 7 quarts in it without it blowing out. Now it seems to be blowing oil down to about 5.5 quarts. Since I live in the 100F OATs part of the country, the extra oil really helps cooling. I don't think a quart of extra oil in the crankcase makes much difference on cooling. Cooling takes place in the oil cooler, and as long as you have normal flow through it, it should cool fine. |
Paul kgyy wrote:
Robert M. Gary wrote: I have an IO-360-A3B6 900 SFNEW in '97. I used to be able to keep about 7 quarts in it without it blowing out. Now it seems to be blowing oil down to about 5.5 quarts. Since I live in the 100F OATs part of the country, the extra oil really helps cooling. I don't think a quart of extra oil in the crankcase makes much difference on cooling. Cooling takes place in the oil cooler, and as long as you have normal flow through it, it should cool fine. Yes, but heating takes place in the crankcase and more oil will absorb heat from more area. Hotter oil entering the oil cooler will transfer more heat to the air. Matt |
![]() Paul kgyy wrote: Robert M. Gary wrote: I don't think a quart of extra oil in the crankcase makes much difference on cooling. Cooling takes place in the oil cooler, and as long as you have normal flow through it, it should cool fine. The more frequently the oil has to go through the system the hotter it gets. The oil does not heat when its sitting in the sump. -Robert |
Blow out static port | [email protected] | Owning | 36 | May 13th 05 02:59 PM |
Cambridge Fuse Question | Brian Iten | Soaring | 9 | January 4th 05 02:43 PM |
Pearl Harbor Defense | Dave | Military Aviation | 157 | September 27th 04 12:43 AM |
A Question For Real Airline Pilots | Blue | Simulators | 34 | September 6th 04 01:55 AM |
Boxer to blow billions on MANPADS | Henry J. Cobb | Military Aviation | 0 | December 3rd 03 04:44 PM |
