Blow out static port
Old May 2nd 05, 10:01 AM
Default Blow out static port
Hi group,
There are larve in my static ports again.
The problem is that I do not have compressed air to blow them out.
I was thinking about using CO2 cartridges like they use for emergency
tire repairs. Or maybe a bicycle pump will do the job.
My concern is the max pressure I can use before I damage something.
I know that I have to de-couple the static lines from the instruments.
I'm going to try to build something to block the ports.
The ports are about 1/8"dia. and 1/4" deep. A pin will do the job but
I'm afraid that even a small remove-before-flight flag will pull them
out in some wind.
-Kees.
Is my static port leaking? Derrick Early Instrument Flight Rules 2 August 15th 04 02:13 AM
Why a static port? Paul Mennen Owning 11 August 19th 03 05:58 AM
Is a static port a precision thing? Larry Smith Home Built 8 August 12th 03 11:26 PM
Static in KX-165A Chad Lemmen Owning 3 July 21st 03 10:57 PM
Canard static port location Paul Lee Home Built 1 July 12th 03 03:55 AM
