oil blow out IO-360
Old July 15th 06, 12:38 AM posted to rec.aviation.piloting,rec.aviation.owning
Mike Noel
Default oil blow out IO-360
The change in oil consumption may be cause for concern as already mentioned,
but as to the cooling effect of the extra couple of quarts of oil, I have
never seen my A4A run cooler on 8 quarts than on 6 (It's about 115 F here
today.) It consistently uses 1 quart every 8 hours which is not unusual for
this type engine. I have seen discussions about very low oil consumption
being a cause for concern because it may cause lubrication issues in the
cylinders.
Best Regards,
http://photoshow.comcast.net/mikenoel
I have an IO-360-A3B6 900 SFNEW in '97. I used to be able to keep about
7 quarts in it without it blowing out. Now it seems to be blowing oil
down to about 5.5 quarts. Since I live in the 100F OATs part of the
country, the extra oil really helps cooling.
Should I worry about what is causing the extra oil blow out or just
chock it up to an aging engine. I know some engines always blow out to
6ish quarts.
If I shouldn't worry about the extra blow out I'll just put a separator
on it, but I don't want to mask a problem first. One recent change is
we raised the oil pressure since the regulator had been slipping prior
to annual.
-Robert
Old July 15th 06, 03:21 AM posted to rec.aviation.piloting,rec.aviation.owning
Paul kgyy
I don't think a quart of extra oil in the crankcase makes much
difference on cooling. Cooling takes place in the oil cooler, and as
long as you have normal flow through it, it should cool fine.
Old July 15th 06, 03:23 AM posted to rec.aviation.piloting,rec.aviation.owning
Matt Whiting
Yes, but heating takes place in the crankcase and more oil will absorb
heat from more area. Hotter oil entering the oil cooler will transfer
more heat to the air.
Matt
Old July 15th 06, 04:14 AM posted to rec.aviation.piloting,rec.aviation.owning
Robert M. Gary
The more frequently the oil has to go through the system the hotter it
gets. The oil does not heat when its sitting in the sump.
-Robert
Old July 16th 06, 12:40 AM posted to rec.aviation.piloting,rec.aviation.owning
soxinbox[_1_]
Excuse my ignorance, but how would valve guides, bad rings, etc cause it to
leak down to 5.5 quarts and then stop. It seems these causes would result in
a continued loss as long as the engine was run.
"Jim Macklin" wrote in message
news:kaStg.67770$ZW3.1299@dukeread04...
Do a differential compression test and pay attention to
valve guides play and seals, often the oil is not being
blown out the breather, but is leaking around the valves
[even one valve] and burning. If you have high leakage
during the differential compression test, you're getting too
much blow-by and that is raising the crankcase pressure and
blowing oil out the breather tube. If the breather is
blocked, it will blow the main seal and you'll see oil
behind the prop. If the oil level goes down fast and then
stabilizes, you may have a dipstick that is not calibrated
properly and you're over filling.
The engine is old, nearly ten years, check all the seals and
mating surfaces. You only have 900 hours, but that is less
than 100 hours a year. Corrosion in the cylinders and blow
by, and oil being sucked past the ring into the combustion
chamber are all possible, Check valve guides and seals,
differential compression and if available, borescope it.
Higher oil pressure would increase the leakage, but not
effect the valve guides or rings. An oil separator will
only help if the oil is going out the breather tube.
James H. Macklin
ATP,CFI,A&P
to keep about
blowing oil
part of the
out or just
blow out to
| 6ish quarts.
put a separator
recent change is
slipping prior
| to annual.
| -Robert
Old July 16th 06, 12:54 AM posted to rec.aviation.piloting,rec.aviation.owning
I am curious, what is your oil temp in those 'HOT'" conditions?
Ben
cylinders.
Best Regards,
6ish quarts.
to annual.
-Robert
Old July 16th 06, 05:17 AM posted to rec.aviation.piloting,rec.aviation.owning
Jim Macklin
Probably, but there might be more than one condition working
on the oil loss. I'd look at quantity and baffling as well
as crankcase pressure, but oil does strange things. There
are dry sump engines that scavenge oil from the crankcase
and return it to an external oil tank, these have two oil
pumps, on to provide engine pressure and the other [larger
pump] to remove the used and foamy oil from the engine. In
all engines [modern designs] the oil that was sent to the
rockers must be drained away back to the crankcase. If
there is a blockage, it will pool and be more likely to be
sucked past the valves.
It is possible that the oil level seems to stabilize at 5.5
quarts only because the flight was terminated and the oil
replenished.
A sudden change in the pattern is what should cause alarm
and investigation. If the airplane has a history of doing
one thing and then that changes for no apparent reason, why
is important to find out.
James H. Macklin
ATP,CFI,A&P
"soxinbox" wrote in message
| "Jim Macklin" wrote
in message
too
and
then
calibrated
and
less
blow
combustion
| James H. Macklin
| ATP,CFI,A&P
able
| to keep about
be
| blowing oil
OATs
| part of the
blow
| out or just
always
| blow out to
| | 6ish quarts.
just
| put a separator
| recent change is
been
| slipping prior
| | to annual.
| | -Robert
Old July 16th 06, 06:52 AM posted to rec.aviation.piloting,rec.aviation.owning
Mike Noel
During climb at 100 mph indicated there is about a needle width of green
between the oil temperature indicator needle and red-line. When I throttle
back to a cruise power setting of about 2500 RPM @ 6500 MSL and a bit rich
of peak on the leanest cylinder, the oil temp gauge drops back to a couple
of needle widths below red-line.
I suspect the oil cooler could use a flush, but the oil cooler bypass valve
was replaced about a year ago and its seat in the oil filter adapter was
lapped. The bypass valve work produced a noticeably cooler climb.
Best Regards,
Ben
mentioned,
for
cylinders.
Best Regards,
6ish quarts.
to annual.
-Robert
Old July 17th 06, 04:44 PM posted to rec.aviation.piloting,rec.aviation.owning
Jim Macklin
Sounds like a good place to start.
too
and
then
calibrated
| I just go ahold of my mechanic (he's been out of town). He
suggests
| another compression check (although we just did one last
month) and a
| boroscope. I'd be happy with the boroscope since I've been
meaning to
| do that for quite some time. He also suggested keeping an
oil log since
| I've never actually tracked oil usage.
| -Robert
oil blow out IO-360 Robert M. Gary Piloting 18 July 17th 06 04:44 PM
Blow out static port [email protected] Owning 36 May 13th 05 02:59 PM
Aviation song for US? Jürgen Exner Piloting 39 March 7th 05 02:01 AM
Cambridge Fuse Question Brian Iten Soaring 9 January 4th 05 02:43 PM
Boxer to blow billions on MANPADS Henry J. Cobb Military Aviation 0 December 3rd 03 04:44 PM
