Flexible air intake hose
Old July 21st 06, 04:11 AM posted to rec.aviation.homebuilt
jerry wass
Default Flexible air intake hose
Capt. Geoffrey Thorpe wrote:
"abripl" wrote in message
I am using 3.5" dia Aeroduct-CAT ducting for a short distance directly
from my intake plenum under my fuselage to the carburetor. The problem
with the CAT is that the wire reinforcing and fabric do not give
radially well, so it transmits some engine vibration to the fuselage.
I would like to find some very flexible ducting (3.5 " bore). I noticed
some of the production built flexible rubber ducting in my car from air
filter to the fuel control(?). I was looking at my 2.5" rubber hose
that ducts the exhaust fumes out of the garage but it is really bulky
and not easy to apply a clamp to.
Anybody has specific product and sources suggestions?
One could, of course, construct one's own duct, eh?
Silicon caulk, fiberglass cloth, make a form and you are good to go.
Note: you said "short distance" - for "long" distances, without some form of
reinforcement the duct could collaps from the pressure difference (I've seen
it happen). You could use loops of wire in place of teh continuous coil.
Geoff
I think I have some red silicone rubber only hose--has/had one layer of string
reinforcing on the outside only--peels off easily--rubber about 1/8"
thick--If you're interested, I'll measure it tomorrow. Jerry
Q. about Eurofighter intake Alistair Gunn Military Aviation 1 August 20th 04 06:58 AM
Lycoming intake preheater Dale Larsen Home Built 5 June 6th 04 10:32 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
high-speed camera view of a piston intake, combustion, exhaust R.Hubbell General Aviation 0 February 20th 04 03:36 AM
flexible wing human powered flight patrick timony Home Built 3 January 15th 04 12:21 AM
