Microair Mic Problem
Old July 19th 06, 04:47 AM posted to rec.aviation.soaring
Mike I Green
Default Microair Mic Problem
I have a Microaire Transponder. It failed after about 9 months. No
problem getting it fixed and it is going strong for the past 2 years.
Their radio may be another story.
mg
BTIZ wrote:
"Mal" wrote in message
http://www.mrsoaring.com/squealing_mikes.htm
HTH
Is MicroAir still in business? IT so, they have the worst customer support
program ever. They have failed to answer repeated attempted contacts for
support on their 760 radio. We are replacing it with a Becker.
I find it surprising that mrsoaring is supporting such a company. But then
again, it looks like they are on the same continent.
BT
Mike I Green
mg
HTH
BT
Old July 19th 06, 05:14 AM posted to rec.aviation.soaring
Greg Arnold
mg
Seems like it is the luck of the draw on the Microair radio. I have one
that worked fine for several years, but I recently replaced it with
another brand because its ergonomics aren't the best.
Old July 19th 06, 02:32 PM posted to rec.aviation.soaring
David Kinsell
mg
Our club has three in use, one actual failure in maybe 10 years of
total time. Excellent transmit quality with amplified Telex dynamic
mikes. I'd sure try one of those to see how they work. Make sure
you don't use the external Microair amplifier.
I agree on the ergonomics, not the best for a club environment.
-Dave
Old July 20th 06, 01:55 PM posted to rec.aviation.soaring
Ian McPhee
My name (mrsoaring) has been used re Microair boom mics I notice
I made about 1800 boom mics and about 1/2 of those were sold thru Microair
but for the past 12 months they have made their own.
The original mic (mine) was electret. Their new mics are amplified dynamic
mics using aluminum fill. I once used aluminum fill - big mistake as it
work hardens and springy. For the last 1000 or so mics they have been brass
fill (11mm diameter) If you have one of those springy mics then best
contact me direct and will do something for you (guess 3+ years old).
I now make amplified dynamic which work with Microair, Xcom Icom Terra etc
Genave Terra and a dynamic only for Becker Dittel etc
Setting up in field I adj gain so it works well 1 or 2 cm from lips but does
not work well when 10 to 15cm away. I listen on another radio 30m away.
This is essential in open cockpit aircraft such as Tigermoth and open
ultralights
I am no longer listed as a Microair dealer on their web site but all I say
is never take no from Microair till they get it right!! They do not like
low voltage - I recommend use of 16g aircraft wire especially in big 2
seaters like ASH25. -18g is OK for single seaters - I recommend dual
batteries and a good switch to use is C&K7211 with bat1 bat2 and OFF. Also
be careful with voltage loss across those glass fuses -contacts can play up.
Please fee free to contact me off line - go thru mrsoaring.com site
Ian McPhee.(mrsoaring.com)... Byron Bay Australia
"Bela Szalai" wrote in message
Check the type of fuse(s) used between the battery terminals and the
radio.
On my first glider it took me months to realize that I had a slow blowing
fuse that dropped the voltage about 0.5 volts and made transmission
scratchy.
- Béla
------Original Message-----
-Sent: Tuesday, July 18, 2006 2:11 PM
-To: Bela Szalai
-Subject: [r.a.s] Microair Mic Problem
-Newsgroup: rec.aviation.soaring
-Subject: Microair Mic Problem
-Author: Henryk Birecki
-Date/Time: 21:00 18 July 2006
-I keep hearing of problems with Microair radios, but mine
-worked flawlessly for the past six years, or maybe rather 5 as
-the first year I was fussing with home built mike system. No
-problems since I got the Microair boom mike.
-The only "problem" I ever experienced is related to battery.
-As the battery goes down you reach a point that you receive
-just fine, but there is no transmission. I cannot compare
-sensitivity to battery charge of Microair radio to others, but
-I bet it is not significantly different.
-In case o significant problems, first thing I'd check is
-antenna connection and antenna tuning.
-Henryk Birecki
-"palombian" wrote:
-I have a MicroAir 760 for 5 years in my glider and another
-club member
-before me Never problems
-JW
- wrote in message
roups.com...
- We have a Microair in our glider. It has never worked properly in
- spite of a round-trip to Oz. We have given up on it, and now use
- hand helds.
- Cheers anyway, Charles
Ongoing Arrow alternator/charging problem Chuck Owning 6 December 22nd 04 01:18 AM
Mooney Engine Problem in Flight - Advise Paul Smedshammer Owning 17 December 21st 04 06:39 AM
Heater problem fixed! Jim Burns Owning 14 December 17th 04 10:38 PM
Microair vs Becker Ian McPhee Soaring 0 August 30th 03 09:45 PM
Problem: Ground Speed Estimate with Volkslogger and WinPilot RamyYanetz Soaring 3 August 26th 03 03:06 PM
