Mounting a turn coordinator on the tail?
Old July 30th 06, 02:17 PM posted to rec.aviation.ifr
Jay Somerset
Default Mounting a turn coordinator on the tail?
On Sat, 29 Jul 2006 15:52:39 -0600, Tim Auckland wrote:
(Things are so slow in this group at the moment, I thought I'd post
this to get your input on something I've been mulling over...)
If you put a plane into a skidding left turn (wings level) with left
rudder, the ball on the panel goes to the right.
However, I've been trying to work out what would happen to the ball if
it was mounted on the tail.
The rudder is pushing the tail of the plane to the right, so I think
the ball would go to the left.
Can anyone confirm this?
Tim.
In the situation you describe, the ball should first go to the left, as the
tail is pushed out to the right by the action of the rudder. Once the skid
is stable, and the ball will go over to the right, to reflect the fact that
the aircraft (including its tail) is turning left.
Old July 31st 06, 12:36 AM posted to rec.aviation.ifr
Judah
Tim Auckland wrote in news:eglnc2tk7l96o5qq3mqajbujfip02iaaol@
4ax.com:
Tim.
More importantly, if you put the TC in the tail, how much rudder pressure
would the pilot have to apply in order to turn the tail quickly enough around
to see it?
I believe cats and dogs have the ability to achieve the necessary speeds,
almost even to the point that some may catch their tails in their mouths as
they look to focus on their balls. But I don't think airplanes are quite
limber enough for this capability.
Old July 31st 06, 04:31 PM posted to rec.aviation.ifr
Tim Auckland
to see it?
There's a Tony Hancock radio sketch where he gets ejected from a
plane, lands on the tail, lassoos the controls, and steers it home.
Tail flapper failure Veeduber Home Built 2 May 22nd 04 06:52 AM
Rate of turn indicator on commercial jets (Boeing / Airbus) Mark Simulators 1 November 1st 03 10:35 AM
IFR in the 1930's Dick Restoration 26 September 11th 03 07:42 PM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Home Built 4 July 26th 03 11:34 AM
