"B A R R Y" wrote in message
... I think the aft CG will result in a higher cruise speed because the arm between the center of lift and CG will be reduced (assuming CL is behind the CG) and the tail will have to do less work. I would think the CG that requires the least amount of trim would be the most efficient. If that is in fact true, the most efficient CG would vary for different aircraft. I agree that there's a secondary effect with respect to control surface drag related to the trim position. However, the primary issues are a) downforce balancing the CG (presumably forward of the center of lift), which has to be compensated for in the form of more lift (so more induced drag) and b) the induced drag from the horizontal stabilizer/elevator itself (adding to the total induced drag directly). Both of these directly correlate to the CG position. The parasitic drag due to trim position is only likely to be significant when the CG is already relatively far aft and the increase in induced drag isn't large. So yes, the *exact* place where the least total drag occurs may not be precisely at the rear-most CG position available, but I suspect in most cases it is (hopefully airplane designers aren't normally creating trim systems that require a non-neutral trim position for a neutral elevator force), and when it's not, it's not going to be far from there. Pete |
Peter Duniho wrote:
The parasitic drag due to trim position is only likely to be significant when the CG is already relatively far aft and the increase in induced drag isn't large. So yes, the *exact* place where the least total drag occurs may not be precisely at the rear-most CG position available, but I suspect in most cases it is (hopefully airplane designers aren't normally creating trim systems that require a non-neutral trim position for a neutral elevator force), and when it's not, it's not going to be far from there. Thanks for the explaination. For me, it's time to break out the water bottles and experiment across my particular range. Thanks to the OP for posting the question! |
gman wrote:
I think the aft CG will result in a higher cruise speed because the arm between the center of lift and CG will be reduced (assuming CL is behind the CG) and the tail will have to do less work. Any ideas? I know that this is off-topic but regarding the dynamics of loads in flight, CG, loading patterns, etc., there's a really nice 6.3 MB publication by Airbus that I'd be happy to mail any aviation student if they wrote in privately. Cheers, Ramapriya |
You will go a little faster with rear CG, but in a plane like a
Skyhawk, it will only be a knot or two, at MOST. |
Warrior cruise RPM settings | lardsoup | Piloting | 35 | October 9th 05 11:59 PM |
Crosswind Landings... But airspeed? | Jmarc99 | Soaring | 21 | October 4th 05 07:54 PM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Flying on the step? | [email protected] | Piloting | 30 | November 3rd 04 01:06 AM |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
