Warrior cruise RPM settings
Old October 4th 05, 05:34 PM
lardsoup
Default Warrior cruise RPM settings
I rent a Warrior from a local FBO and usually set the RPMs to 2400 in
cruise. It gets about 110kts at
2400. But that seems too slow. Heck I've been getting 110kts from one of
their C152s. Rereading the
POH I see that the cruise RPM settings can be 2500 or 2600. So I'm curious.
Where do others run their
Warriors while in cruise. I'm not concerned about fuel burn because fuel is
included in the rental price
and my typical flight is around 2 hours. I know an old Warrior is no SR-71,
but I want to at least try for
some more speed. Thanks.
Old October 4th 05, 05:53 PM
In my experience with rental Warriors, 110kt is about right considering
these planes often have tired higher time engines subjected to endless
T&G landings and are often missing wheel fairings. However, I've flown
one with a new engine (no wheel fairings) and saw 120 indicated in
level cruise.
Old October 4th 05, 08:16 PM
Jay Honeck
We ran our old Warrior pretty much wide open most of the time, unless
we weren't in a hurry. The Lycoming O-320 is a bulletproof, detuned
engine that was designed to turn 2700 RPM all the way to TBO -- and
does.
Unless you're trying to save gas, there's not much point in throttling
back in a Warrior.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 4th 05, 11:54 PM
Nick
When I used to rent a Warrior 160hp, I would usually fly it with the
throttle firewalled.
Does the Warrior you fly have wheel pants on? If not that would cost
you a least 5 knots.
Nick
PA28-180 'D'
Old October 5th 05, 08:28 AM
Seth Masia
This is one reason I no longer lease back my airplane -- because people ran
it without regard for fuel burn, and the FBO charged me for the waste. When
I fly it, I get 150knots at 10.5 gph, but I saw renters burn 40 gal every
three hours. Nuts.
Seth
Comanche N8100R
"Nick" wrote in message
Does the Warrior you fly have wheel pants on? If not that would cost you
a least 5 knots.
Nick
PA28-180 'D'
of
curious.
is
SR-71,
Old October 5th 05, 09:43 AM
Mortimer Schnerd, RN
three hours. Nuts.
I generally run at 65-75% power, with whatever fuel burn keeps the mags from
loading up. And if I'm flying something with a constant speed prop, I try to
run the power at whatever combination will allow the slowest RPM (for reduced
noise). 2100 RPM is quite a bit easier on my ears than 2400 RPM.... and I can
still pull 65% power if I don't go too high.
I never saw much sense in running balls to the wall on a rental. Sure, I'm
paying for it, but I'm also depending on it.
Old October 5th 05, 02:49 PM
John Clonts
What does "mags loading up" mean?
John
Old October 5th 05, 02:41 PM
Hmmpf. Gotta get me one of those Comanches. The Lance I fly burns 16gph
at that speed and I'm carrying two extra empty seats... Is that a
PA-24-180?
I can think of several other reasons not to leaseback a Comanche - fuel
being the least of them grimace
Transmittion Noise - High Power Settings Paul Smedshammer Owning 6 August 20th 05 06:17 PM
Lycoming's views on best economy settings [email protected] Piloting 37 July 8th 04 04:00 PM
Power settings for 182RG Andrew Gideon Piloting 19 March 3rd 04 07:41 PM
Cessna 404 Cruise settings Katia General Aviation 0 December 19th 03 05:04 PM
L-nav Settings Ventus 2ct-18 Oliver Peters Soaring 4 July 18th 03 04:14 AM
