#11
![]() Scott wrote: Quick question for the group. When setting the torque on prop bolts (I have bolts with nuts), if the hole for the cotter pin doesn't line up with the castleated nut at the proper torque setting, is it better to go tighter or looser to get the hole lined up. My gut instinct says tighter, but.... Scott Use a pair of Belleville washers rated for about 2000 lb under each bolt head, installed with their conacave sides facing each other. See if you can get to the recently-deceased Vance Jaqua's web site, and see his write-up on the Belleville use. |
That is the answer I was looking for (a quote from AC 43.13)...I can't
find my copy. Now, can you define "friction drag" ? If I know what that is, I'll have 'er whipped! Thanks! Scott Jester wrote: Scott wrote: Quick question for the group. When setting the torque on prop bolts (I have bolts with nuts), if the hole for the cotter pin doesn't line up with the castleated nut at the proper torque setting, is it better to go tighter or looser to get the hole lined up. My gut instinct says tighter, but.... Scott From chapter 7 of the AC 43.13-1B "f. When installing a castle nut, start alignment with the cotter pin hole at the minimum recommended torque plus friction drag torque. NOTE: Do not exceed the maximum torque plus the friction drag. If the hole and nut castellation do not align, change washer or nut and try again. Exceeding the maximum recommended torque is not recommended." This is also what I remember from school. Jesse M. PP-ASEL A&P |
![]() Scott wrote: That is the answer I was looking for (a quote from AC 43.13)...I can't find my copy. Now, can you define "friction drag" ? If I know what that is, I'll have 'er whipped! Thanks! Scott Friction drag is the drag exerted by the locking feature of the nut, whether it's a nylon ring or a crimped metal collar. The amount of torque required to turn the nut on the threads before any tension is put on the bolt is added to the torque spec so that the proper tension is achieved in the bolt (or stud). It can be critical especially with all-metal locknuts; they are pretty tight on the threads. Dan |
Thanks! Got it! So I think there would be hardly any friction drag
with a castleated nut since there is no inherant locking mechanism built into the nut... Scott wrote: Scott wrote: That is the answer I was looking for (a quote from AC 43.13)...I can't find my copy. Now, can you define "friction drag" ? If I know what that is, I'll have 'er whipped! Thanks! Scott Friction drag is the drag exerted by the locking feature of the nut, whether it's a nylon ring or a crimped metal collar. The amount of torque required to turn the nut on the threads before any tension is put on the bolt is added to the torque spec so that the proper tension is achieved in the bolt (or stud). It can be critical especially with all-metal locknuts; they are pretty tight on the threads. Dan |
"jerry wass" wrote in message
.. . pbc76049 wrote: Hey, never thot of swappin nuts--thanx My Pleasure... It's the simple stuff that makes life a joy. Have a great say..... Scott. |
Torque Value for Mounting an O-320 wide deck. | Ebby | Home Built | 2 | May 31st 06 01:00 AM |
VW 1.2 Diesel. What does MAX TORQUE 18k-24k mean ??? | Montblack | Home Built | 6 | April 17th 06 07:03 PM |
Proper Torque for Fuel Fittings | Steve Waltner | Home Built | 10 | February 20th 05 12:46 AM |
Bolt torque | Neal Fulco | Home Built | 1 | October 16th 04 06:57 AM |
Prop bolt torque setting | Whunicut | Home Built | 2 | September 4th 03 12:12 PM |
