Torque for prop bolts
Old August 27th 06, 12:56 PM posted to rec.aviation.homebuilt
Scott[_1_]
Default Torque for prop bolts
Quick question for the group. When setting the torque on prop bolts (I
have bolts with nuts), if the hole for the cotter pin doesn't line up
with the castleated nut at the proper torque setting, is it better to go
tighter or looser to get the hole lined up. My gut instinct says
tighter, but....
Scott
Old August 27th 06, 02:29 PM posted to rec.aviation.homebuilt
jerry wass
tighter, but....
Scott
Try various thicknesses of washers. Jerry
Old August 27th 06, 03:41 PM posted to rec.aviation.homebuilt
pbc76049
"jerry wass" wrote in message
tighter, but....
Scott
Also shuffle the nuts around. the threads do not all start in the same
place relative the slots in the
castlleations.
Scott
Old August 27th 06, 08:36 PM posted to rec.aviation.homebuilt
jerry wass
pbc76049 wrote:
Hey, never thot of swappin nuts--thanx
Old August 29th 06, 02:58 PM posted to rec.aviation.homebuilt
pbc76049
My Pleasure... It's the simple stuff that makes life a joy.
Have a great say.....
Scott.
Old August 27th 06, 03:47 PM posted to rec.aviation.homebuilt
abripl[_1_]
If you have a metal mini lathe, you can shave a little off the nuts to
get them to line up exactly with the cotter pin.
SQ2000 canard http://www.abri.com/sq2000
tighter, but....
Scott
Old August 27th 06, 05:47 PM posted to rec.aviation.homebuilt
Stuart & Kathryn Fields
I heard somewhere (from a "knowledgeable source"; probably at the bar
somewhere) that it is acceptable to go to the next castellation to get the
hole lined up and to never loosen. One place to check is with the pros.
There is an engineering forum called www.eng-tips.com that has a forum on
fasteners where discussions of details about fasteners will give you a brand
new appreciation for these little thingies that we take for granted.
Stuart Fields
Experimental Helo magazine
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
(760) 408-9747 general and layout cell
(760) 608-1299 technical and advertising cell
www.vkss.com
www.experimentalhelo.com
"Scott" wrote in message
tighter, but....
Scott
Old August 27th 06, 05:57 PM posted to rec.aviation.homebuilt
Kyle Boatright
"Stuart & Kathryn Fields" wrote in message
brand
Stuart Fields
P. O. Box 1585
Inyokern, CA 93527
I'd stick with changing washers, bolts, or nuts to achieve the spec'd torque
value. Torque limits are defined for a reason.
KB
Old August 27th 06, 08:37 PM posted to rec.aviation.homebuilt
Morgans[_4_]
torque
I am absolutely against absolute statements. g
I would have to say a little commons sense has to apply, here.
If the specified torque is 75 foot pounds, and it would line up if you went
to 76 foot pounds, go for it. Your torque wrench could be out of spec that
much, and it would still be legal.
Old August 27th 06, 06:09 PM posted to rec.aviation.homebuilt
Why are you using castlelated nuts? Does the airframe or prop
manufactuer require their use?
Diamond aircraft uses fiberlock nuts on the DA-20 C1 which uses a wood
prop on the IO-240 engine.
My glider club uses fiberlock nuts on the Hoffman 4 bladed wood prop of
a PA-25 Pawnee 250 used for towing gliders.
Both these aircraft are type certificated, if fiberlock are good enough
for them.....
If you check the torque on a regular basis as all wood prop
manufactuers I know of require than you whill have no problems with
loose bolts.
Robert Mudd
Moriarty, NM
A&P I.A.
tighter, but....
Scott
Torque Value for Mounting an O-320 wide deck. Ebby Home Built 2 May 31st 06 01:00 AM
VW 1.2 Diesel. What does MAX TORQUE 18k-24k mean ??? Montblack Home Built 6 April 17th 06 07:03 PM
Proper Torque for Fuel Fittings Steve Waltner Home Built 10 February 20th 05 12:46 AM
Bolt torque Neal Fulco Home Built 1 October 16th 04 06:57 AM
Prop bolt torque setting Whunicut Home Built 2 September 4th 03 12:12 PM
