Many transponders in close proximity
Old September 1st 06, 05:15 AM posted to rec.aviation.soaring
Yuliy Gerchikov
Default Many transponders in close proximity
"jettester" wrote in message
#1. Transponders would not solve the mid air problem unless you were
the only one in close proximity to the attacking aircraft. Typically,
TCAS can't factor multiple threats?!? Even the lowly Zaon MRX can.
they set MTI (moving target indicator) to above 60K or higher
(especially if near a large amount of highway ground traffic), so once
you start thermalling they lose you unless you are given a discrete
squawk other than 1200 (for non participating VFR Traffic)
TCAS filtering out "highway ground traffic" ...squawking 1200?
The biggest benefit of transponder is not that people on the ground will see
you -- after all, they are not the ones that are going to hit you. My
transponder is on not as much for the ATC, but for the TCAS/TPAS flying out
there.
Yuliy
Old September 1st 06, 06:00 PM posted to rec.aviation.soaring
Ron Natalie
I think he's talking about ground radar. TCAS gives not a hoot about
mode A codes.
Old September 1st 06, 06:36 PM posted to rec.aviation.soaring
jettester
there.
Yuliy
This is why I love these websites....
The Zaeon MRX Unit is intriguing for several reasons...
1. Its relatively cheap $500
2. It uses 2 self contained batteries (from 5.8 to 7 hrs duration)
3. The ATC radar interogates the other aircraft and the MRX just
listens to the replies
4. You don't have to have a transponder or Mode C
5. Its small and lightweight
6. It gives relative altitude from your altitude (built in digital
altimeter)
7. I don't mess ATC up if I'm not talking or participating with
them.
Draw backs are... it still only helps with finding other aircraft with
transponders and mode C.
I'm glad to hear that at places like Minden and Arizona you guys are
using a discrete code with ATC's blessing. It still would mean you are
talking with the ATC controllers on their freq.
.... Incidentally, we (USAF) did tests with fibreglas gliders to see if
we could "see" them with ATC radars.. you typically could not unless
they increased their power above the rated power they were authorized
at the time... yet, if we put wadded up tin foil (Reynolds Aluminum
wrap) in the wings, they showed up like gang busters.
Jettester (UP)
Old September 1st 06, 10:43 PM posted to rec.aviation.soaring
Eric Greenwell[_1_]
No talking for code 0440 is required at Minden, anymore than is required
for code 1200. You just punch it in and use it while VFR.
Seattle center and the local approaches don't seem to have problems
seeing our gliders, especially if we announce our prescence. Perhaps
your tests predate the newer radars?
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
Old September 1st 06, 11:08 PM posted to rec.aviation.soaring
jettester
Operation"
I did a Electronics Counter Measures test in the late 1980's against
their (Seattle's) radar, and their's is the newest in the country and
the most capable.
Jettester (UP)
Old September 2nd 06, 12:14 AM posted to rec.aviation.soaring
Andy[_1_]
Tucson approach had no problem seeing my ASW-19B, and vectoring airline
traffic round me as a climbed. I was not squawking anything except
"please let me stay here long enough to get enough altitude to get
home".
Andy
Old September 2nd 06, 05:07 AM posted to rec.aviation.soaring
5Z
home".
They could see a Kestrel back in the mid 1970's at 30 miles or so if I
recall correctly. One of the Tcson Soaring Club members did some
testing with them.
-Tom
Old September 2nd 06, 08:29 PM posted to rec.aviation.soaring
James D'Andrea
I do not know what radar band ATC uses, but couldn't one suspend a
metalic reflector like sailboats use to provide a radar return? Of
course, space would be consideration depending on the glider model (see
http://www.tri-lens.com/trilensweb12002002.htm)
Jettester (UP)
Old September 4th 06, 01:55 AM posted to rec.aviation.soaring
Mike Schumann
That doesn't provide altitude data, and the radar return would potentially
be filtered out as ground traffic due to the slow speeds involved.
Mike Schumann
"James D'Andrea" wrote in message
ps.com...
Jettester (UP)
Old September 1st 06, 05:59 PM posted to rec.aviation.soaring
Ron Natalie
jettester wrote:
#4. MODE S transponders have a discrete ID code embedded in the
transponder that is supposed to be set to your aircraft registry ID
(look on the FAA website for your aircraft registry information and you
will find that ID for your aircraft). Mode S talks to other mode S
equipped transponders, and is typically used to provide TCAS (Traffic
Collision Avoidance System) information to issue the advisories to each
aircraft. If you have this feature, and were to pullup rapidly with
another mode S aircraft overhead, it could set off his traffic warning
system.
A mode S transponder is not required for an aircraft to be detected
by TCAS. The conflicting traffic only needs mode C for the TCAS
to give an RA. The only advantage mode S gives is that if you have
TWO TCAS equipped aircraft, they use the mode S datalink to coordinate
a resolution (one climbs the other descends).
Batteries, Solar Panels, Transponders, etc. JS Soaring 7 August 31st 06 10:12 PM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
It was really close... Jay Honeck Piloting 166 May 22nd 05 02:30 PM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 5th 04 12:55 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
