#11
![]() Your description of the way to give a student a look at the picture they shoul see and therefore the attitude they should have is spot on. In addition I used to point out that the point to which they raise their eyes from looking at the reference point before they make the attitude change must be as far as their percieved horizon. If they choose a point too close I would point out that when they pitch the nose up if the point is too close they will not be able to see it and therefore there is a tendency not to pitch up far enough in order keep their chosen point in view. At 13:12 09 September 2006, Papa3 wrote: Cats wrote: I am one of those people with ongoing intermittent landing problems. I have good patches - managed to get solo recently - and then bad patches. The bad patches probably co-incide with forgetting to look up as I start the round-out, so there is no hold-off and a rather heavy landing, sometimes with a bounce. I have students sit in the glider while two other folks stand outside: one levels the wings, the other one stands at the tail. We then lift the tail to the pitch attitude that approximates approach speed to get a good feel for that sight picture. I ask the student to carefully pick some reference points and try to ingrain those in his/her mind. We then rotate to landing attitude and to the same. I really want the person to get the idea that they rotat to a certain attitude and then hold there while speed bleeds off. Obviously, this isn't perfect, since the rotation really needs to happen a little bit higher up (grin), but it does give the sense for the amount of pitch change required. Depending on the aircraft, the rotation can be pretty significant (e.g. a 2-33) or pretty subtle (e.g. a G103). I definitely agree that getting yourself to focus on a point in the distance (e.g. tree tops at the far end of the runway) makes this whole process easier. Whatever you do, spend some time on the ground in the airplane fooling around with this. Erik Mann LS8-18 P3 p.s. A good friend of mine did the same thing for me when I was trying to learn to fly taildraggers in a J3 Cub. It was really helpful to get a sense for the min and max pitch attitudes required. |
Private wrote:
It is said by many that the route to good landings is practice, practice, practice. The key is not to keep practicing your mistakes. Learning to land in gliders is difficult because it is hard (and expensive) to do enough of them. I didn't find this to be true when I was an active CFIG; in fact, our tow pilot (an airplane instructor) once remarked at how quickly glider pilots learned to land compared to a student in airplanes. I think the biggest difference, at least when I was teaching, was we had a 5 to 10 minute discussion after every landing as we pushed the glider back to the launch point, and sometimes continued the discussion at the launch point, even if the tow plane was back and ready to tow. This discussion was very important, because the student had some time to think about the previous landing, then learned to identify what when wrong and why, and decide how to correct it. Most students could do a decent landing in our Blanik after 15 flights, starting with deciding when to break off the airwork and return to the airport, entering the pattern, and finally, the actual "landing". I say "landing" because I think the landing starts with the decision to land, not the flare. Contrast this with the "airplane" method, which often involves landing after landing (touch and goes), with little discussion or time for reflection. Eventually, the student is able to manage a landing, but isn't really confident that he/she knows what is right. Tows are expensive and we seldom make more than a small number of landings in a training day. IMHE the best way to learn to land is with a GOOD CFI, in a light tailwheel aircraft and at a small quiet airport. This will allow you to make many landings in an hour and is much more cost and time effective than purchasing tows. I haven't tried this technique, so I can't compare it to the glider-only method, but the $$ will depend greatly on details of charges for the tows, glider, and CFIG. Gliders require ground crews for assistance and it is hard to get more than 4 landings /hr. We did it with the student, the instructor (me), and the tow pilot, using unassisted takeoffs. Easy in the Blanik on 75'-100' wide pavement. The first 3 launches were usually with a wing runner, though. An aircraft needs no assistance and can easily make 12 or more landings in an hour, and the cost per landing will be a small fraction of the cost of gliders + tows. If the discussion and reflection take place between the landings, I think this would be effective. I know Derek Piggot thinks a motorglider is ideal for initial training for the reasons mentioned. -- Note: email address new as of 9/4/2006 Change "netto" to "net" to email me directly Eric Greenwell - Washington State, USA "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
![]() "Eric Greenwell" wrote in message news:JaMMg.924$FS.290@trnddc04... Private wrote: It is said by many that the route to good landings is practice, practice, practice. The key is not to keep practicing your mistakes. Learning to land in gliders is difficult because it is hard (and expensive) to do enough of them. I didn't find this to be true when I was an active CFIG; in fact, our tow pilot (an airplane instructor) once remarked at how quickly glider pilots learned to land compared to a student in airplanes. I think the biggest difference, at least when I was teaching, was we had a 5 to 10 minute discussion after every landing as we pushed the glider back to the launch point, and sometimes continued the discussion at the launch point, even if the tow plane was back and ready to tow. This discussion was very important, because the student had some time to think about the previous landing, then learned to identify what when wrong and why, and decide how to correct it. Most students could do a decent landing in our Blanik after 15 flights, starting with deciding when to break off the airwork and return to the airport, entering the pattern, and finally, the actual "landing". I say "landing" because I think the landing starts with the decision to land, not the flare. Contrast this with the "airplane" method, which often involves landing after landing (touch and goes), with little discussion or time for reflection. Eventually, the student is able to manage a landing, but isn't really confident that he/she knows what is right. I was advised against making touch and goes as they rob the student of needed practice in the rollout which is the most important part of a tailwheel landing. I was advised to do stop and goes, and while my stops were seldom complete they did give me time to reconfigure the aircraft properly for takeoff. I often notice that pilots doing T&Gs land too fast and are unable to hold the nosewheel off in a proper (improperly named, full stall) mains first landing. Some say this is the difference between tricycle gear (a perfect approach but where the pilot quits flying when the wheels touch) and a tailwheel (where the wheels touch and then the pilot gets busy). I did find that the best practice was chopping power on downwind and making a curving 180 to spot landing (with only a brief power burst for engine clearing) and using slips for altitude control. At a controlled field it is called a simulated engine failure and (if approved by ATC) can allow slipping in front of other aircraft on a typical long circuit. Tows are expensive and we seldom make more than a small number of landings in a training day. IMHE the best way to learn to land is with a GOOD CFI, in a light tailwheel aircraft and at a small quiet airport. This will allow you to make many landings in an hour and is much more cost and time effective than purchasing tows. I haven't tried this technique, so I can't compare it to the glider-only method, but the $$ will depend greatly on details of charges for the tows, glider, and CFIG. Agreed. Many club operations have very resonable glider rental rates and the CFIG is often a volunteer but some would suggest that 'you get the quality you pay for'. Gliders require ground crews for assistance and it is hard to get more than 4 landings /hr. We did it with the student, the instructor (me), and the tow pilot, using unassisted takeoffs. Easy in the Blanik on 75'-100' wide pavement. The first 3 launches were usually with a wing runner, though. An aircraft needs no assistance and can easily make 12 or more landings in an hour, and the cost per landing will be a small fraction of the cost of gliders + tows. If the discussion and reflection take place between the landings, I think this would be effective. I know Derek Piggot thinks a motorglider is ideal for initial training for the reasons mentioned. I did not feel that I had really learned to land properly and consistently until I had made several hundred solo landings in several types of aircraft and in a wide variety of wind and weather. Both the mistakes and the improvements are now smaller but I am still learning and every landing is self critiqued. |
![]() Most students could do a decent landing in our Blanik after 15 flights, starting with deciding when to break off the airwork and return to the airport, entering the pattern, and finally, the actual "landing". I say "landing" because I think the landing starts with the decision to land, not the flare. Your "landing" is what most folks would call the pattern or circuit, depending on your country of reference. I was advised against making touch and goes as they rob the student of needed practice in the rollout which is the most important part of a tailwheel landing. I was advised to do stop and goes, and while my stops were seldom complete they did give me time to reconfigure the aircraft properly for takeoff. I often notice that pilots doing T&Gs land too fast and are unable to hold the nosewheel off in a proper (improperly named, full stall) mains first landing. They each have their place. I like touch and goes, if the runway length is sufficient (don't ask :-) ), because it teaches a student to perform multiple tasks in a short amount of time - plan and perform the landing, maintain directional control, add power (torque, and other forces change), maintain directional control, clean up the flaps, maintain directional control, re-trim the aircraft, maintain directional control, ..... These are useful skills, IMHO. As for T&G pilots landing too fast or in an improper attitude, that's the instructors fault, I think. Tony V. |
![]() "Eric Greenwell" wrote in message news:JaMMg.924$FS.290@trnddc04... Private wrote: It is said by many that the route to good landings is practice, practice, practice. The key is not to keep practicing your mistakes. Learning to land in gliders is difficult because it is hard (and expensive) to do enough of them. I didn't find this to be true when I was an active CFIG; I agree. Learning how to do a safe takeoff and tow are harder for most glider students to grasp than the landing itself. With few exceptions, by the time I felt good enough to solo a student safe landings had ceased to be a serious issue several flights back; with the final issues involving the takeoff/tow, consistency, or general judgment . Vaughn |
![]() Cats wrote: intermittent landing grief OK guys, maybe I wasn't clear. It's not a question of not being able to do it at all, it's a question of slipping into back into getting fixated on the reference point and rounding out too late and hitting the ground hard enough to bounce and make the guy in the back cringe. After the problem came back, my own diagnosis was failure to look along the field once I start the roundout - that after a number of good landings, I was maybe getting cocky about it and forgetting what I was doing that worked. Tried it out today - carefully reminded myself of the need to look along the field, and produced a good landing every time with & without the man in the back seat, including my first flight in a single-seater. My own solution at present is to at least mentally add it on to the end of 'eventualities' - 'and when I reach the round-out look along the field'. |
Try the exercise where you stand alongside (or on) the runway, and bend
at the knees while you look down the runway several times. Do it again from time to time, especially before a flight. Get used to seeing the perspective change. Then, when you are landing, you will know to expect this, and it will help you remember to look up, rather than fixating on the spot. Cats wrote: Cats wrote: intermittent landing grief OK guys, maybe I wasn't clear. It's not a question of not being able to do it at all, it's a question of slipping into back into getting fixated on the reference point and rounding out too late and hitting the ground hard enough to bounce and make the guy in the back cringe. After the problem came back, my own diagnosis was failure to look along the field once I start the roundout - that after a number of good landings, I was maybe getting cocky about it and forgetting what I was doing that worked. Tried it out today - carefully reminded myself of the need to look along the field, and produced a good landing every time with & without the man in the back seat, including my first flight in a single-seater. My own solution at present is to at least mentally add it on to the end of 'eventualities' - 'and when I reach the round-out look along the field'. |
"Tony Verhulst" wrote in message
. .. ... They each have their place. I like touch and goes, if the runway length is sufficient (don't ask :-) ), because it teaches a student to perform ... I've been known to do 3 or 4 "touch and go's" before the final full stop landing. And all on the same approch. :-) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Derek Piggott did exactly the same thing as Tom Knauff, especially when
training instructors. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Doug Haluza" wrote in message oups.com... Sounds like you have identified the most likely cause. I tell students to watch the spot on approach, then when it is in "point blank range" there is no need to look at it any more, and it's time to look at the other end of the runway. Tom Knauff has students stand near the runway and bend at the knees to simulate the last part of the landing hold-off. You look down the runway and note the perspective changes that are the cues you need to maintain a slow descent. For a comparison you can also look at the ground near your feet to see how ineffective this is. |
Get yourself an instructor.
Don't think that you can learn how to fly by reading posts on a newsgroup. "Cats" wrote in message ps.com... I am one of those people with ongoing intermittent landing problems. I have good patches - managed to get solo recently - and then bad patches. The bad patches probably co-incide with forgetting to look up as I start the round-out, so there is no hold-off and a rather heavy landing, sometimes with a bounce. I've got my own ideas on how to address this, was curious if anyone else here has had the same problem and if so, how did you deal with it? Unfortunately I reckon I developed the bad habit fairly early in my flying, as it was well-established by the time someone pointed out what was going on. Since I seem to be reasonably good at doing what I'm told to do, via a route from ears to hands & feet that misses my brain, I suspect I've flattered to deceive in the front seat. |
A question on Airbus landings | [email protected] | Piloting | 17 | July 18th 06 09:05 PM |
Precision Landings and practice | [email protected] | Piloting | 34 | December 17th 04 02:08 PM |
Night landings vs. day landings | Gerald Sylvester | Piloting | 15 | February 12th 04 06:38 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Tailwheel endorsement | John Harper | Piloting | 58 | December 12th 03 01:48 PM |
