First "real" hold (long)
Old October 4th 04, 02:08 PM
Thomas Borchert
Dan,
Evidently, I didn't.
Got it. Oh, and as others have said: Thanks for sharing the story!
Thomas Borchert (EDDH)
Old October 4th 04, 03:12 PM
Michael
Thomas Borchert wrote
Then let me ask what Scott implied: How did you manage a CAT I approach
with minimums of 200 and a half mile (3000 feet!) in that? Seems
impossible to me - 400 and 3000 are quite a difference.
Not to pick nits (OK, to pick nits) but CAT I mins can have an RVR as
low as 1800 ft.
Not 400 though.
Michael
Old October 4th 04, 04:47 PM
Dave Butler
Dan Luke wrote:
Yesterday, for the first time since I got the instrument rating 5 years
ago, I had to hold for real.
It was a reposition flight from Mobile Downtown to Pensacola to pick up
an Angel Flight. When I checked the weather at home at 6am, fog was
reported everywhere on the central Gulf Coast - the nearest legal
alternate I found was Birmingham. Mobile was below minimums, but PNS
was just at minimums and forecast to improve slightly. When I took off,
BFM was still below minimums for the ILS, and when I checked the PNS
ATIS it was 1/4, indefinite ceiling 100.
Did you consider postponing the flight until PNS was reporting weather that you
would need to complete the approach? According to my calculations, this was only
a 46 mile flight, so it wouldn't have delayed your arrival at PNS by much, and
would have saved you a bunch of fuel used in holding, not to mention the risk
exposure of being airborne with nowhere to land.
snip
That problem dealt with, I headed down
the glide slope with more than usual concentration on keeping the
needles centered; I wanted to make this one. This time I saw enough
lights at DH to give me 100 more feet, and that was it: made it.
.... and you also had the required flight visibility?
snip
Dave Butler, software engineer 919-392-4367
Old October 4th 04, 11:07 PM
Chip Jones
"Roy Smith" wrote in message
"Dan Luke" wrote:
I suppose so. I always have this feeling my old CFII is sitting in the
right seat, shaking his head when I don't do something "by the book."
Single-pilot IFR is all about task prioritization. Take care of the
important stuff, and don't waste time on the **** that doesn't matter.
As long as you stay in the protected airspace, nobody cares what your
holds look like, or how perfectly timed the legs are.
From an ATC stand-point, most controllers certainly could care less what a
hold looks like when flown. Personally, I just want you to maintain
assigned altitude and meander in orbit somewhere over the fix in the general
direction assigned. We controllers get really conservative around holding
patterns, and a tightly-flown pattern really doesn't matter. Likely, no one
in ATC-land will even notice if you nail the turns and the times, because
they are looking at a lot of other stuff on the scope. The prudent
controller will be using vertical separation below and above your protected
airspace, and he/she will be adding a lot of extra lateral protection around
your bubble too, just in case.
Chip, ZTL
Old October 5th 04, 12:07 AM
Roy Smith
direction assigned.
One thing I have noticed is that while ATC doesn't seem to care much
about where you go on the holding side of the fix, if you meander just a
little bit PAST the holding fix, you're likely to get a call politely
enquiring if you have any idea where the hell you are.
Old October 5th 04, 02:23 AM
Dan Luke
that you would need to complete the approach? According to my
calculations, this was only a 46 mile flight, so it wouldn't have
delayed
your arrival at PNS by much, and would have saved you a bunch
of fuel used in holding, ...
Good question. Yes, I did consider it, but at the time I took off, my
information was that PNS was at minimums with improvement forecast. I
wanted to get the first leg of the Angel Flight started on time if
possible, because there were other people - next leg pilot, patient's
relatives, etc. - waiting on the flight.
...not to mention the risk exposure of being
Well, the airplane has 6+ hours endurance at max range power, so I
wasn't _too_ worried.
This time I saw enough lights at DH to give me 100 more feet, and
To be honest, I must say I did not count how many markings I could see
down the runway. I was spring-loaded for another miss if it didn't look
good to me. At DH I had the threshold lights; 100' lower, it looked to
me like I had plenty of vis.
This was not the first ILS I ever flew to minimums but it was the first
one where I _really_ needed the extra 100' to get in. It was a very
rapid transition from total whiteout to not-so-bad.
Dan
C172RG at BFM
Old October 5th 04, 02:48 AM
Michelle P
Dan,
You have me beat by about 30 minutes. I had to hold once for 30 minutes
to start and approach into Potomac Airfield near Washington, DC.
Michelle
The PNS approach controller reported the RVR as 100 with that "are you
sure you want to do this?" tone (don't you just hate to hear that tone
from a controller?), so I told him I'd try one ILS, then go hold a while
if I missed. Sure enough, at DH there was no sign of any lights, so off
to the Saufley VOR I went to wait.
Holding is boring. After a couple of turns to get it nailed, ones
attention tends to wander. It becomes a real effort to remember to
restart the clock outbound each time. I must admit I missed the
outbound flag drop a couple of times in the first 30 minutes and had to
check the GPS to know when to turn back inbound.
It was about this time that a series of technical problems started.
First, the HI bug started sticking, then the portable GPS started losing
satellite link every time I keyed the radio (fixed that by moving the
antenna to a different spot on the glareshield). There were more
problems later.
30 minutes' wait only got the RVR up to 200, so I told Approach I wanted
30 more. I could see the fog becoming patchy south and west of the
airport, but I still had to start considering my fuel state: I might
actually have to fly 250 miles to find somewhere to land with reserves.
Unlikely, but ya gotta go with it. The thought of being above a
thousand square miles of 100' ceilings with low fuel is enough to make
me very conservative.
In the event, after about 20 minutes a C-208 came in and completed the
approach and the rvr was up to 400, so I asked for vectors for another
try. The next technical glitch appeared at the outer marker when the
flaps refused to work until I toggled the handle a few times (at least
it wasn't the landing gear!). That problem dealt with, I headed down
By the time the Angel Flight pax were loaded (something of an ordeal)
the field had gone from socked-in to VFR. Very typical Gulf Coast
autumn morning.
Post script: more tech problems.
The pax Lightspeed 25XL headset wouldn't power up - no big deal, I'm
used to things like that with that headset. The next thing was more
serious. My WxWorx setup, which has been solid for a year, crapped out
on me. Actually, it was the Sony notebook it's hosted on. The USB com
port the WxWorx receiver is plugged into went away. I like to do a lot
of things in airplanes, but troubleshooting pc com port problems while
IFR with a couple of nervous pax aboard isn't one of them. I wrapped
the cables up and stowed the pc. This might have been a flight killer
if there had been a lot of convective stuff around. Still, it made me
realize how much I like having other features of the system available,
particularly METARs and TAFs.
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old October 5th 04, 12:55 PM
Barry
This time I saw enough lights at DH to give me 100 more feet, and that was
it: made it.
To be honest, I must say I did not count how many markings I could see down
the runway. I was spring-loaded for another miss if it didn't look good to
me. At DH I had the threshold lights; 100' lower, it looked to me like I
had plenty of vis.
On a standard ILS, at DH on the glide slope you're 3000 feet from the
threshold, so (though slant visibility is not quite the same as forward
visibility) you probably had the required 1/2 mile vis. A lot of pilots don't
understand that the rule about going down to 100' on the approach lights
doesn't remove the visibility requirement. If you see only a few approach
lights at DH, you almost certainly do not have the required visibility, and
should go missed.
Old October 5th 04, 03:45 PM
Newps
And unless you are in a charted holding pattern the idea of a protected
side and unprotected side is pretty funny too.
Old October 5th 04, 05:13 PM
Dan Luke
Save the mental effort for important things like making sure your fuel
planning is right, getting a good picture of the weather from flight
watch so you know when to divert (and where), and briefing the approach
you're about to fly.
Good points, I know, but after 20 minutes of holding you've done all that
and you'e really in need of something else to do! The PNS controller was
doing a good job of updating aircraft on the freq. about conditions at
nearby airports, but calling FW would have been a good idea.
Dan
C-172RG at BFM
Checkride bust (long) Wizard of Draws Instrument Flight Rules 9 July 14th 04 12:53 AM
Flight test update - long nauga Home Built 1 June 5th 04 03:09 AM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
IFR Long X/C and the Specter of Expectations David B. Cole Instrument Flight Rules 0 February 24th 04 07:51 PM
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 03:19 PM
