![]() "Shawn" wrote in message . .. Gary Emerson wrote: For the benefit of the group, let's hear about what works for re-attaching mylar. Now that we've established that the only solvent safe to use on a composite glider is the sweat from a virgin Las Vegas showgirl, can anyone answer Gary's question? Thx, Shawn Hmmm, let me get the mental image here . . . Nah, ain't gonna find one of those I bet! I sort of thought we had answered Gary's question, but will add: If the double sided tape has come loose in just one spot, simply pushing it back down will not work or work for long. You might get away with raising the Mylar seal and quickly wiping the detached surfaces with a Q-tip dipped in Acetone. Then warm the surface and use pressure to re-bond the tape. This will work for a while . . . but is not a long term fix. If the debonded area is at the end of the tape, then remove the top seal tape and peel back the Mylar until you get past the debonded area (the Mylar doesn't come off easily). Tape the Mylar out of the way. Remove the old double sided tape in the affected area. If there's adhesive residue to deal with, before trying solvents, try using some packing tape or cloth tape like a "tack strip" - - apply tape to old residue, push down and then pull straight up. In many cases, sometimes after several applications of the tack strip, the old adhesive residue will be cleanly removed. Sand, clean, replace double sided tape as previously noted and as you would if replacing Mylars. all the best, bumper |
![]() bumper wrote: "Shawn" wrote in message . .. Gary Emerson wrote: For the benefit of the group, let's hear about what works for re-attaching mylar. Now that we've established that the only solvent safe to use on a composite glider is the sweat from a virgin Las Vegas showgirl, can anyone answer Gary's question? Thx, Shawn Hmmm, let me get the mental image here . . . Nah, ain't gonna find one of those I bet! I sort of thought we had answered Gary's question, but will add: If the double sided tape has come loose in just one spot, simply pushing it back down will not work or work for long. You might get away with raising the Mylar seal and quickly wiping the detached surfaces with a Q-tip dipped in Acetone. Then warm the surface and use pressure to re-bond the tape. This will work for a while . . . but is not a long term fix. If the debonded area is at the end of the tape, then remove the top seal tape and peel back the Mylar until you get past the debonded area (the Mylar doesn't come off easily). Tape the Mylar out of the way. Remove the old double sided tape in the affected area. If there's adhesive residue to deal with, before trying solvents, try using some packing tape or cloth tape like a "tack strip" - - apply tape to old residue, push down and then pull straight up. In many cases, sometimes after several applications of the tack strip, the old adhesive residue will be cleanly removed. Sand, clean, replace double sided tape as previously noted and as you would if replacing Mylars. all the best, bumper I have had experience removing tape adhesive using adhesive remover made by PPG and 3M. I don't have the part number in hand for these, but you can get information on the web. The adhesive remover does not contain acetone or MEK and is not nearly as volitile, however it is flammable. It states that it does not leave a residue. It must have time to evaporate thoroughly, before any new tape should be applied. Another possible adhesive remover is a citrus based "goof-off" or another citrus cleaner. Gel coat is micro porous, but the volitile fluids like acetone if used very sparingly on a clean rag should not cause issues with the sub structure. I agree to use caution if you are not sure, don't use it. When placing the new tape be sure the surface has no wax or any other residue. My tapes have held on fine for several years. I used the TESA tape from W& W's and new mylar with the seal tape over as described at length above. I used a plastic squeegee to smooth the pressure on the tape and had no voids in the adhesion. The whole assembly was then rubbed down and allowed to sit a couple of days before flying. This allowed the tape to achieve maximum adhesion charachteristics. I think the operative condition is clean and dry before applying new tape and seals. |
I don't think you'll find any styrofoam in your glider's structure. The
R/C gliders, a different story... Most aircraft structural foams are PVC. Some are urethane. Acetone used on the surface will not hurt either the finish nor the structure. Don't get me wrong - please don't pour a bunch of it on. A paper towel damp with acetone will not wet the surface or structure sufficiently to cause damage... depending on the finish. Most gel coats and urethane will be impervious to acetone. On the other hand, if you're working on the original lacquer finish of a Schweizer 1-35, leave the acetone in the can... don't ask me how I know... at least I had the good sence to test it on a small, out of sight spot. I'd recommend that before you use any solvent. MEK on the other hand has such a bad reputation that I leave it alone. The only time that gets used is in extremely small quantities of patch gel coat I got from an RV dealer. Protect your health - we have too few glider pilots already - use gloves and ventilation. Regards Jack Womack |
. .. Gary Emerson wrote: For the benefit of the group, let's hear about what works for re-attaching mylar. ... Now that we've established that the only solvent safe to use on a composite glider is the sweat from a virgin Las Vegas showgirl, can anyone answer Gary's question? Ok, I hate it when some clueless moron comes along and says "I've never tried this, but..." So, I've never tried this, but what about the 3M stripe off wheel? Essentially a rubber wheel you mount in a drill designed to "erase" trim stripes and the adhesive without solvents. A picture is at: http://www.imperialinc.com/items.asp?item=0726310 (I've never dealt with this company, they just came up near the top of the search) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
![]() Capt. Geoffrey Thorpe wrote: "Shawn" wrote in message . .. Gary Emerson wrote: For the benefit of the group, let's hear about what works for re-attaching mylar. ... Now that we've established that the only solvent safe to use on a composite glider is the sweat from a virgin Las Vegas showgirl, can anyone answer Gary's question? Ok, I hate it when some clueless moron comes along and says "I've never tried this, but..." So, I've never tried this, but what about the 3M stripe off wheel? Essentially a rubber wheel you mount in a drill designed to "erase" trim stripes and the adhesive without solvents. A picture is at: http://www.imperialinc.com/items.asp?item=0726310 (I've never dealt with this company, they just came up near the top of the search) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. I have used this 3m Stripe Remover on my RV (Winnabago) recently. It works very well. I removed a badly deteriorated wide stripe on it. This side of the motorhome is fiberglass, and it did not damage the surface. It does take a delicate touch, and the process is like using an electric eraser. It works using friction and an sacrificial elastomeric compound while removing the decal stripe. The caution here is to be careful not to heat up your gel coat when using this. Also for the purpose of removing tape residue on your wing so close to your ailerons hinge line this may not be a good idea. I can imagine a slip up where damage can occur. On my ship, the area where the tape is located is a thin section where the aileron is fitted. I would try the liquid residue remover first. I haven't tried this stuff, but it looks like it may work well. http://www.youroil.net/adhesive_remover.html |
Re-curving mylar on a glider | Eric Greenwell | Soaring | 32 | October 18th 06 03:20 PM |
Mylar (again) | JJ Sinclair | Soaring | 0 | December 11th 03 10:40 PM |
Mylar "form 1" vs "form 2" | John | Soaring | 1 | November 27th 03 01:20 AM |
Looking for sand paper rolls and adhesive | Roger Halstead | Home Built | 9 | August 8th 03 08:58 AM |
Structural adhesive question | BD5ER | Home Built | 1 | August 3rd 03 06:03 AM |
