#11
![]() DonMorrisey wrote: Hey Everyone. I am looking for a good quality insulating material for my firewall. I am interested in something that will effectively block sound and heat. I've looked at what Spruce and Wicks has available but I'm wondering what some other builders may have used that has worked well and is relatively easy to install. All comments and leads appreciated, especially anyone that has flown their application and is happy with the result. I guess I need to insulate the rest of the airplane too, so any comments on that are welcome as well. Thanks. Don... While I haven't used it on an aircraft, my mechanic used a thin foil insulation material on my car after I experimented with how well it would float. (It didn't). After the interior was all out and treated, he told me this stuff he got at the hardware store was better than the original foam matting. It was about 1/4" thick with foil on both sides and a sort of bubble tape center section. It came prepared with adhesive on one side so you could peel-and-stick. He got it at home depot or lowes or something. He was right, it works, and it was cheap. Not sure what it was, but you might just buy a bit of it at the store and hold it over a candle to see if it fits the bill. -Matt |
What adhesive did you use on this material?
I used a 3m spray adhesive to attach some PVC foam insulation to the firewall of my RV-6 and have had problem after problem with the adhesive releasing. I believe it is heat related. KB wrote in message oups.com... DonMorrisey wrote: Hey Everyone. I am looking for a good quality insulating material for my firewall. I am interested in something that will effectively block sound and heat. I've looked at what Spruce and Wicks has available but I'm wondering what some other builders may have used that has worked well and is relatively easy to install. All comments and leads appreciated, especially anyone that has flown their application and is happy with the result. I guess I need to insulate the rest of the airplane too, so any comments on that are welcome as well. Thanks. Don... While I haven't used it on an aircraft, my mechanic used a thin foil insulation material on my car after I experimented with how well it would float. (It didn't). After the interior was all out and treated, he told me this stuff he got at the hardware store was better than the original foam matting. It was about 1/4" thick with foil on both sides and a sort of bubble tape center section. It came prepared with adhesive on one side so you could peel-and-stick. He got it at home depot or lowes or something. He was right, it works, and it was cheap. Not sure what it was, but you might just buy a bit of it at the store and hold it over a candle to see if it fits the bill. -Matt |
Earlier, Kyle Boatright wrote:
I used a 3m spray adhesive to attach some PVC foam insulation... I have a couple hundred pounds of PVC foam sheet at the shop, but I don't think I'd use it for firewall insulation. When burned, PVC releases toxic hydrogen chloride gas. I think I'd prefer to use a more inert and fire-resistant insulator at a firewall. Thanks, Bob K. |
![]() "Bob Kuykendall" wrote in message oups.com... Earlier, Kyle Boatright wrote: I used a 3m spray adhesive to attach some PVC foam insulation... I have a couple hundred pounds of PVC foam sheet at the shop, but I don't think I'd use it for firewall insulation. When burned, PVC releases toxic hydrogen chloride gas. I think I'd prefer to use a more inert and fire-resistant insulator at a firewall. Thanks, Bob K. Aah, but all PVC ain't the same... My employer used to manufacture a huge line of floorcovering products which used PVC as a major ingredient. With the right additive package in the PVC, it passed every flame and smoke test required to be installed in residential, commercial, or even healthcare property. I'm sure purpose built PVC insulation sold through major aviation suppliers uses the same additives. KB |
Airplane insulation | Andreas Warberg | Piloting | 6 | April 26th 06 07:45 PM |
18 Oct 2005 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | October 19th 05 02:19 AM |
Firewall Insulation | Marv Hamm | Home Built | 2 | August 31st 04 02:14 AM |
Firewall Insulation | Kyle Boatright | Home Built | 1 | August 27th 04 01:11 AM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
