#11
Sheesh! Airplanes are apparently a bargain....
Thanks for the information about a second class of bike wrenches. Peter "Cy Galley" wrote in message news:nia7h.148036$aJ.132191@attbi_s21... They make some very nice thin tool steel wrenches for Bikes. And they are NOT for emergency use. Check at your local bike shop and look at the bikes for $5 to 10 thousand dollars. -- Cy Galley - Webmaster www.qcbc.org "Peter Dohm" wrote in message ... That's WRENCH, not wench you dirty minded garlic guzzling cigar chomping old pharts. I've got a very thin (0.050") 3/8" wrench that has been in my toolbox since Eisenhower. Over the years, it has rounded its jaws off to the point where it is fairly useless. The maker of the wrench, one H.H. Smith in Brooklyn NY no longer makes this tool. Other than taking an ignition wrench and grinding it down, does anybody have a source for stamped thin metal wrenches? Jim I don't know where to buy a good one; but if you do have to grind down an ignition wrench, which is quite likely, be sure to use plenty of coolant! Otherwise the result is a very soft wrench, which is little better than those stamped and punched things that are sold for emergency repair of bicycles. :-( Peter |
Flight wrench question | R.H. | Piloting | 14 | June 25th 06 03:48 PM |
FAA Fat Man on thin Ice | StopPoliticallyCorrectTyranny | Piloting | 1 | August 22nd 05 02:00 AM |
Wrench size for KI214 & KI201 OBS knob | Roy Page | Owning | 7 | March 11th 05 10:07 PM |
Descending through a thin icing layer | Wyatt Emmerich | Instrument Flight Rules | 70 | December 31st 03 05:17 AM |
Thin flexible solar panels | Eric Greenwell | Soaring | 11 | November 28th 03 04:35 PM |
