Total Air Temperature question
Old December 13th 04, 05:06 PM
Mike Rapoport
"Peter" wrote in message
news
"Mike Rapoport" wrote:
Either way, the Shadin should be reading the same or lower than the OEM
OAT
guage.
I am sorry but I still don't get that. Total Air Temp should be SAT,
adjusted UPwards for the airflow heating. But different parts of the
aircraft will have different mach numbers. Which bit is TAT supposed
to represent?
Exactly, TAT represents SAT adjusted upwards for Mach. The problem with
your senario (160ktas, 10K', ISA and Shadin reads 3C higher) ) is that the
difference in readings is the same as the *total* calculated difference
between SAT and TAT. The OAT guage would need to have a local flow of
*zero* and the Shadin would need to have a local flow equal to the
freestream Mach number. Think about it this way:
Possibility #1 Both OEM OAT and Shadin displaying TAT and Shadin reads 3C
higher (stated condition)
Since total difference between SAT and TAT is 3C (calculated by Julian
earlier in thread) and the Shadin reads 3C higher, for the OEM guage to be
reading correctly the mach number at its location would have to be 0. To be
exact, the difference in Mach number has to be exactly the same as the speed
of the airplane, pretty unlikely.
Possibility #2 The OEM OAT is displaying TAT and the Shadin is displaying
SAT.
SAT is always lower than TAT so the Shadin should show a lower temp.
You could be right, which would presumably mean the stock OAT probe
has a higher mach number than anything else.
Two possibilities, either the airflow over the OEM OAT probe is zero or one
(or both) temperature readings are inaccurate, a much more likely senario.
MU-2
Old December 13th 04, 06:14 PM
Mike Rapoport
I need to wait for a reply from Shadin as to what their "True Air
Temp" is supposed to mean.
Lets us know what they say.
MU-2
Old December 14th 04, 06:20 PM
Mike Rapoport
Thanks. This is consistant with what I observe in my airplane. It is
unfortunate that they chose to name things differently from everyone else,
and particularly inappropriate to use TAT to mean SAT when there is a "TAT"
in common use.
MU-2
Shadin's reply:
Shadin's OAT = = Other's TAT (Total Air Temp)
Shadin's TAT (True Air Temp) = = Other's SAT (Static Air Temp)
They also sent me the installation manuals for models 200 and 2000.
Peter.
Return address is invalid to help stop junk mail.
E-mail replies to but remove the X and the Y.
Please do NOT copy usenet posts to email - it is NOT necessary.
Oil Temperature sending unit Corky Scott Home Built 2 October 19th 04 12:58 AM
'Room Temperature' Anthony Home Built 11 August 23rd 04 07:36 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
