Question on Baron 58 prop control
Old November 28th 06, 02:46 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Question on Baron 58 prop control
Robert M. Gary writes:
I can't imagine how/why you would feather the prop with the engine
still running.
Neither can I, but I was wondering if it would hurt anything.
Certainly not something I have or would try. On most all
planes pulling the prop level all the way back feathers them. On some
older planes there was a feather button but nothing I've flown (DC-3,
etc)
There's a red button on the sim, but it doesn't appear to be fully
simulated. It's the "minus" settings of the prop that puzzle me.
Old November 28th 06, 02:47 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Allen writes:
As Jim said the PW PT6 engine has no physical connection between the power
section and the drive section.
How does power get from one to the other?
Old November 28th 06, 02:51 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
TheSmokingGnu writes:
Yes, and yes. There is a procedure to check the prop speed mechanism
during run-up to briefly move the prop lever through it's travel.
Intentionally running a prop to feather on an engine doesn't do it any
good, however, and if it gets slow enough, the engine can stall, or
heaven forbid the lock pins can fall in place (and then you're really
FUBAR'd, time for a mechanic). On a (free-turning) turboprop, it's less
of a concern, although I imagine the turbine guys won't thank you for it
if you do it too often.
Thanks. Another thing that confuses me is: Is a feathered prop
always edge to the wind, or flat to the wind, or does it vary by
aircraft? Edge to the wind would minimize drag on the aircraft, but
flat to the wind would minimize drag on the engine.
Old November 28th 06, 02:53 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Jose[_1_]
Is a feathered prop
Feathered is edge to the wind. The other is called "flat pitch".
Jose
"There are 3 secrets to the perfect landing. Unfortunately, nobody knows
what they are." - (mike).
Old November 28th 06, 03:10 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
TheSmokingGnu
The turbine's output over a second series of fan blades, which are
connected to the propeller shaft. In effect, it's a giant torque
converter (if you're at all familiar with car technology).
In fact, you can hold, with your bare hand, the prop blade during start
up. Just don't let go of it, and don't try to catch it if it comes
loose! (Oh, and RUN!)
Is a feathered prop
Edge to the wind. The thought is that the engine has already failed in
some capacity, and a windmilling prop causes massive cavitation and
drag, so the blade edge is aligned with the relative wind to stop it
from turning (although not fully, due to mechanical positioning issues,
they get really, really close).
Old November 28th 06, 03:19 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Doug[_1_]
MT Propeller has a reversable prop the experimental guys put on Super
Cubs and that sort of plane. It is MOST useful with a Seaplane and can
be reversed on landing. It can't be reversed when you are over 1400 rpm
or some such and cant be reversed in the air. Both Beta (feather) and
reverse would be very useful in a Seaplane.
Old November 28th 06, 03:27 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Barrie
"TheSmokingGnu" wrote in message
connected to the propeller shaft. In effect, it's a giant torque converter
Interesting. Is that what gave rise to the old slang term "Propjet"?
How does this compare with the present form of propulsion, such as in the
B747, which I've heard being called "Fanjet"? Is it the same but turbine
blades replace propellor blades while serving a similar function?
Barrie
Old November 28th 06, 03:29 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Doug[_1_]
The "minus' button if what you push when you are in full speed cruise
:-) (Try it and see what happens!)
Nice thing about a sim, you can do stuff you CANT do on a real
airplane (like crash).
And that is why a sim will NEVER be like true flight. With a sim, if
you crash, you crashed and you are ok. With a real airplane, you
crashed, and that's IT! No more you. A different headspace, attitude,
whatever you want to call it.
Old November 28th 06, 03:45 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
BT
"Mxsmanic" wrote in message
Allen writes:
power
air pressure
Old November 28th 06, 04:16 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Barrie
"Doug" wrote in message
That echoes what I said when trying to explain what FS is to someone today.
That it's ultra-realistic but the big thing that's missing is any "fear
factor". If that was present, which of course it can't be, then our
decisions while simming would of course be very different.
Barrie
Question on prop cycle Frode Berg Owning 9 April 25th 06 07:36 AM
Prop Balancing Question A Lieberman Owning 3 February 2nd 06 12:25 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
IVO props... comments.. Dave S Home Built 16 December 7th 03 12:43 AM
