homemade external/internal antenna for handheld.
Old December 21st 06, 03:25 AM posted to rec.aviation.homebuilt
john smith
Default homemade external/internal antenna for handheld.
"RST Engineering" wrote:
You could have saved yourself half the price of the "commercially available
antenna base" by using a bulkhead BNC female connector, mounting it to the
same piece of aluminum and feeding one side with connector/coax to the radio
and the other side with a BNC connector on the other side with a brass
brazing rod of your choice in diameter for the radiating rod.
True, but this was a time-saving step.
(Red/white striped package, cannot remember the manufacturer. Larson?)
It was a HAM antenna base. Punch a 1" hole in the metal, unscrew the cap
from the base, insert base through hole, screw on cap. Whip set in a
well in the cap and secured with a set screw. The base had the coax
attached at a right-angle and fit the shallow area between the top and
bottom fairings.
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
Homemade Antenna Carl J. Hixon Home Built 2 October 27th 04 08:54 AM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 03:27 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
comm's RX antenna acepilot Home Built 5 March 3rd 04 05:34 PM
