Etching copper clad
Old December 28th 06, 08:02 PM posted to rec.aviation.homebuilt
Ernest Christley
Default Etching copper clad
flybynightkarmarepair wrote:
Ernest Christley wrote:
Getting ferric chloride from Radio Shack is getting problematic. Is
there a common household chemical that I can use for etching a circuit
board or two? I seem to remember Jim Weir having an article about how
to do it in the not to distant past, but I can't find anything about it
in my back copies of Kitplanes.
You're thinking of this post:
http://groups.google.com/group/rec.a...+circuit+board
Scroll down for Jim's response to RS Hoover's intial post. Muratic
acid and Hydrogen Peroxide.
Ah, yes! That's it.
Thank you...and Jim...and Mr. Hoover.
Ferric chloride is good, and I figured it could be had; but, it would be
a hazardous, special purpose chemical that would sit around for a very
long time with very little likelihood of ever being used again. Muriatic
acid and hydrogen peroxide are both useful for all sorts of things.
Old December 28th 06, 09:08 PM posted to rec.aviation.homebuilt
Dear Ernest (and the Group),
Definitely go with the acid over the Ferric Chloride. I only use the
stuff because I'm already set-up to do so. The acid-peroxide stuff
sounds like a good idea.
-R.S.Hoover
PS -- I'll post pix of the thang I use for drilling on the Chugger site
then copy an edited version of the March posting to my blog.
Old December 28th 06, 09:09 PM posted to rec.aviation.homebuilt
-R.S.Hoover
Old December 29th 06, 12:42 AM posted to rec.aviation.homebuilt
Ernest Christley
RST Engineering wrote:
September '06. Addendum...abrasion with 180 grit sandpaper/cloth does a
better and less hazmat job of removing the resist than does lacquer thinner.
Duly noted. I'm working on one of the capacitive fuel gauges. You
wouldn't happen to have the PCB artwork laying around, perchance?
I've started laying it out in gEDA, an open-source
design/simulation/production system.
"Ernest Christley" wrote in message
board or two? I seem to remember Jim Weir having an article about how to
do it in the not to distant past, but I can't find anything about it in
Copper in oil analysis ? [email protected] Owning 8 August 22nd 06 12:31 PM
Copper in oil analysis ? [email protected] Instrument Flight Rules 8 August 22nd 06 12:31 PM
high copper reading in oil analysis [email protected] Owning 1 March 26th 04 03:32 PM
