Etching copper clad
Old December 28th 06, 12:33 AM posted to rec.aviation.homebuilt
Ernest Christley
Default Etching copper clad
Getting ferric chloride from Radio Shack is getting problematic. Is
there a common household chemical that I can use for etching a circuit
board or two? I seem to remember Jim Weir having an article about how
to do it in the not to distant past, but I can't find anything about it
in my back copies of Kitplanes.
Old December 28th 06, 12:55 AM posted to rec.aviation.homebuilt
Charlie[_2_]
How 'bout:
http://froogle.google.com/froogle?q=...en&btnG=Search
Charlie
Old December 28th 06, 02:22 AM posted to rec.aviation.homebuilt
Peter Dohm
RS seems to drift farther from their name with each passing day.
However, there are electronics parts suppliers in most urban areas and they
should have it in stock, along with a variety of circuit board blanks,
circuit board kits, and "breadboarding" kits. Try electronics, electronics
parts, and electronics supplies in the locat yellow pages. Usually, in that
sort of business, "professional" or "trade" means that you know the name or
description of what you want to buy.
Peter
Old December 28th 06, 02:35 AM posted to rec.aviation.homebuilt
tscheevel
A quick search on mouser.com yielded the following:
http://www.mouser.com/search/refine....erric+chloride
Old December 28th 06, 07:01 AM posted to rec.aviation.homebuilt
flybynightkarmarepair
You're thinking of this post:
http://groups.google.com/group/rec.a...+circuit+board
Scroll down for Jim's response to RS Hoover's intial post. Muratic
acid and Hydrogen Peroxide.
Old December 28th 06, 04:46 PM posted to rec.aviation.homebuilt
steveukman
I found a good source for it at All Electronics
(http://www.allelectronics.com)
They supply the solid stuff (ferric chloride) rather than the more
'spillable' solution. I found ferric chloride works better than
anything else I've tried. I have found them to be prompt and helpful.
They are also a treasure trove of 'odds and ends' for all kinds of
projects.
If you are making PCB's, they also stock 'transfer film'. Just print
on a laser printer and iron on to the PCB. It transfers better than
laser-anything else. I was getting really frustrated (trying all kinds
of papers and other materials) until I found this stuff ... never had a
bad board since!!!! I even do double-sided with it with great results.
There are a few schematic capture and PCB layout programs for free that
seve me well ... making it much easier than 20 years ago. Hmmmmm ...
can I produce an EFIS for under $1,000?
Hope this helps.
Steve
How 'bout:
Charlie
Old December 28th 06, 05:00 PM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
Laser print and iron onto a PCB? Wow. How things have changed. I've been
buying PCB's for my son's analog-music-synth-from-scratch project for months
now. Had I known, maybe I would have saved some money.... except I believe
ferric chloride is also a hazmat, no?
"steveukman" wrote in message
projects.
Hope this helps.
Steve
How 'bout:
Charlie
Posted via a free Usenet account from http://www.teranews.com
Old December 28th 06, 06:04 PM posted to rec.aviation.homebuilt
RST Engineering
September '06. Addendum...abrasion with 180 grit sandpaper/cloth does a
better and less hazmat job of removing the resist than does lacquer thinner.
"Ernest Christley" wrote in message
board or two? I seem to remember Jim Weir having an article about how to
do it in the not to distant past, but I can't find anything about it in
Old December 28th 06, 06:06 PM posted to rec.aviation.homebuilt
Morgans[_5_]
"Juan Jimenez" wrote
except I believe ferric chloride is also a hazmat, no?
As you recently said, get with the program. Do some reading (in this
thread, even) and report back.
Old December 28th 06, 06:29 PM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
"Morgans" wrote in message
Oh, did you go into "monkey see, monkey do" mode now? chuckle
Did ya miss the question mark? The difference between you and me is that I
ask, rather than pretend I know something about which I don't know squat.
The children's sandbox is -- thataway.
Copper in oil analysis ? [email protected] Owning 8 August 22nd 06 12:31 PM
Copper in oil analysis ? [email protected] Instrument Flight Rules 8 August 22nd 06 12:31 PM
high copper reading in oil analysis [email protected] Owning 1 March 26th 04 03:32 PM
