Andrew Sarangan wrote:
Sam Spade wrote: paul kgyy wrote: Both of these options require a WAAS receiver, I presume? Yes, and if WAAS is not available to the standards required by the specs then the 146 box will not accept the WAAS solution, which means (using Garmin as an example) LPV, L/VNAV, and LNAV+V will not be available; only LNAV will be available. Something I never understood is why LNAV approaches don't automatically show a glideslope so that the airplane arrives at the MDA at the VDP. With the 146 spec you will often have an advisory glideslope to MDA. That is the LNAV+V mode and will be provided if Jeppesen has coded that capability into the approach's database string. As Garmin says in the W handbood, not all LNAV-only IAPs have been so coded. |
test
"paul kgyy" wrote in message ups.com... Can someone explain to me the difference between these two approach types, and how they relate to WAAS? A sample approach that has both is KARR RNAV(GPS) RWY 9. LPV DA is 956, LNAV/VNAV DA is 990. |
LNAV, VNAV and LPV | Andrew Sarangan | Instrument Flight Rules | 5 | January 14th 07 01:57 PM |
LNAV preferable over LNAV/VNAV | [email protected] | Instrument Flight Rules | 4 | October 16th 05 06:34 PM |
GPS approaches with VNAV vertical guidance | Doug | Instrument Flight Rules | 18 | November 2nd 04 10:36 PM |
CNS-80 VNAV | John R. Copeland | Instrument Flight Rules | 17 | October 28th 04 04:24 AM |
Which GPS Support LNAV/VNAV? | C Kingsbury | Instrument Flight Rules | 1 | October 23rd 04 12:28 AM |
