Hawai Airport Piston Engine indentification question ...
Old February 22nd 07, 11:27 PM posted to rec.aviation.piloting,rec.aviation.military,rec.aviation.homebuilt
Morgans[_2_]
Default Hawai Airport Piston Engine indentification question ...
"weasel" wrote
My bad-
Yes, it's an R-2800, Pratt&Whitney 18 cylinder radial.
(It would've been nice if the second row was visible!!)
Indeed.
It looks like the view of the picture in question, with the angle given,
makes it difficult to get depth of the engine.
If it was a straight on view, the offset of a couple second row cylinders
could have been seen and made it easy to identify the engine.
If the view had been taken at a 90 degree angle from the shaft, then the
second row could have been identified from the offset of crank main throws.
It has always been my view that technical pictures should be taken with
straight views, like a 3 view drawing. It is much easier to take
measurements from a 3 view, if you are interested in taking measurements for
reproducing the object as a model, or whatever.
Angles like the picture given are best left for artistic presentations, as
was probably intended.
Hawai Airport Piston Engine indentification question ... DONOTREPLY Piloting 7 February 22nd 07 11:27 PM
Learning piston engine basics [email protected] Owning 9 December 24th 05 09:19 PM
Lancair Columbia 400: The World's Fastest Certified Piston Single Engine Aircraft! David Ross Aviation Marketplace 0 August 24th 04 07:13 PM
How to ACCURATELY measure fuel/gas in a single-engine piston aircraft? NoSpam Piloting 31 January 9th 04 01:45 AM
Piston engine 101 Course? [email protected] Owning 9 October 28th 03 02:35 PM
