#11
A real annual is when the AI actual looks at all the details
and the owner wants it done right, not just cheap. "Tim" wrote in message ... | See inline replies. | | Jim Macklin wrote: | An equipment list is required and lists all components and | accessories and parts installed, except for the airframe | itself. | | Where is the reg for this? I have not found it yet. Is there a | specified format? | | A really well done equipment list will include the | model and serial number for items and not just the name, | weight and station [location on the airplane]. This makes | researching and compliance with ADs much easier. | The engine, propeller, alternator, magnetos, battery, | radios, wheels, tires, brakes, seat belts should be listed. | | But older airplanes did not have a modern POH and the | owners' handbook would also sometime include a separate AFM | and the factory original W&B data should have had the | equipment list and the FAA should have a copy of that in the | registry in OKC. You can then survey the airplane [good | time to do a real annual] | | As opposed to an "unreal annual?" I am not sure what you mean by this. | | and verify that each item is | really installed, update to include serial numbers and | current AD status and add any items that have been added and | delete items that are no longer installed. | | I am most likely going to base mine on the log book entries and an | equipment list from a plane of the same year and model. | | thanks, tim | | | | | | "Tim" wrote in message | ... | | Mark Hansen wrote: | | On 03/01/07 21:44, Tim wrote: | | | | What is required as far as a formal equipment list for | part 91 | | operations? In reading 91.205 and listening to one | instructor I know, I | | cannot reconcile what he says with the FARs. He states | that an aircraft | | must have an equipment list. I cannot find an equipment | list for the | | plane I fly regularly. I see partial entries for | "equipment list" on | | W&B forms in the plane, but no formal equipment list | showing all the | | arms/moments and weights of all the items in the | aircraft. I have seen | | examples of this for various aircraft in the POH. | | | | I fly an older AA5A and the POH is not even close to | what I would call a | | useful document for the airplane. It is very brief, | contains errors and | | contains self-contradictory information. I am not | surprised to seem to | | be missing a required document. | | | | Is this a required document? If so, how can I recreate | it or obtain a | | new one? I was considering recreating from an account | of the logs. | | | | The manufacturer is no longer in business. | | | | Any idea where I would find "equipment list" | requirements in the regs? | | | | thanks, | | tim | | | | | | There was a recent article by Mike Busch at AVWeb on | this topic. AVWeb | | members can see the article he | | | | http://www.avweb.com/news/savvyaviator/194428-1.html | | | | If you're not a member already, join! It's free and | there's lots of great | | stuff there. | | | | | | After posting this I found the article. Thanks. | | |
FAR 125 requires actual weighing the aircraft on a schedule.
New aircraft are assumed to be accurate, but not all airplanes are weighed. "Travis Marlatte" wrote in message ... | "Jim Macklin" wrote in message | ... | An equipment list is required and lists all components and | accessories and parts installed, except for the airframe | itself. A really well done equipment list will include the | | As a general statement, I don't think so. A great idea? I agree. Required by | a reg? Where? | | An equipment list may be required for the certification but I don't see any | reg that says that you have to keep it up to date. All that is required is | updated W&B. The FAA publication that Mike Busch quotes is somewhat | ambiguous but it is only advisory, anyway. | | Having said all that, I did download Mike's spreadsheet and I plan to create | an equipment list - just for fun. However, I'm quite sure that I won't be | able to match the current W&B which will leave a perpetual puzzle until I | pay to have the plane re-weighed. | ------------------------------- | Travis | Lake N3094P | PWK | | |
All my annuals are real annuals. I might almost be insulted by this
comment. Jim Macklin wrote: A real annual is when the AI actual looks at all the details and the owner wants it done right, not just cheap. "Tim" wrote in message ... | See inline replies. | | Jim Macklin wrote: | An equipment list is required and lists all components and | accessories and parts installed, except for the airframe | itself. | | Where is the reg for this? I have not found it yet. Is there a | specified format? | | A really well done equipment list will include the | model and serial number for items and not just the name, | weight and station [location on the airplane]. This makes | researching and compliance with ADs much easier. | The engine, propeller, alternator, magnetos, battery, | radios, wheels, tires, brakes, seat belts should be listed. | | But older airplanes did not have a modern POH and the | owners' handbook would also sometime include a separate AFM | and the factory original W&B data should have had the | equipment list and the FAA should have a copy of that in the | registry in OKC. You can then survey the airplane [good | time to do a real annual] | | As opposed to an "unreal annual?" I am not sure what you mean by this. | | and verify that each item is | really installed, update to include serial numbers and | current AD status and add any items that have been added and | delete items that are no longer installed. | | I am most likely going to base mine on the log book entries and an | equipment list from a plane of the same year and model. | | thanks, tim | | | | | | "Tim" wrote in message | ... | | Mark Hansen wrote: | | On 03/01/07 21:44, Tim wrote: | | | | What is required as far as a formal equipment list for | part 91 | | operations? In reading 91.205 and listening to one | instructor I know, I | | cannot reconcile what he says with the FARs. He states | that an aircraft | | must have an equipment list. I cannot find an equipment | list for the | | plane I fly regularly. I see partial entries for | "equipment list" on | | W&B forms in the plane, but no formal equipment list | showing all the | | arms/moments and weights of all the items in the | aircraft. I have seen | | examples of this for various aircraft in the POH. | | | | I fly an older AA5A and the POH is not even close to | what I would call a | | useful document for the airplane. It is very brief, | contains errors and | | contains self-contradictory information. I am not | surprised to seem to | | be missing a required document. | | | | Is this a required document? If so, how can I recreate | it or obtain a | | new one? I was considering recreating from an account | of the logs. | | | | The manufacturer is no longer in business. | | | | Any idea where I would find "equipment list" | requirements in the regs? | | | | thanks, | | tim | | | | | | There was a recent article by Mike Busch at AVWeb on | this topic. AVWeb | | members can see the article he | | | | http://www.avweb.com/news/savvyaviator/194428-1.html | | | | If you're not a member already, join! It's free and | there's lots of great | | stuff there. | | | | | | After posting this I found the article. Thanks. | | |
Thanks - I should know better than to use a reference that is
abbreviated. All the part 91 stuff is no problem - it is the part 23 I need to double check. Jim Macklin wrote: Look in part 23 and 91. § 23.1589 Loading information. The following loading information must be furnished: (a) The weight and location of each item of equipment that can be easily removed, relocated, or replaced and that is installed when the airplane was weighed under the requirement of §23.25. (b) Appropriate loading instructions for each possible loading condition between the maximum and minimum weights established under §23.25, to facilitate the center of gravity remaining within the limits established under §23.23. [Doc. No. 4080, 29 FR 17955, Dec. 18, 1964, as amended by Amdt. 23-45, 58 FR 42167, Aug. 6, 1993; Amdt. 23-50, 61 FR 5195, Feb. 9, 1996] § 91.417 Maintenance records. (a) Except for work performed in accordance with §§91.411 and 91.413, each registered owner or operator shall keep the following records for the periods specified in paragraph (b) of this section: (1) Records of the maintenance, preventive maintenance, and alteration and records of the 100-hour, annual, progressive, and other required or approved inspections, as appropriate, for each aircraft (including the airframe) and each engine, propeller, rotor, and appliance of an aircraft. The records must include- (i) A description (or reference to data acceptable to the Administrator) of the work performed; and (ii) The date of completion of the work performed; and (iii) The signature, and certificate number of the person approving the aircraft for return to service. (2) Records containing the following information: (i) The total time in service of the airframe, each engine, each propeller, and each rotor. (ii) The current status of life-limited parts of each airframe, engine, propeller, rotor, and appliance. (iii) The time since last overhaul of all items installed on the aircraft which are required to be overhauled on a specified time basis. (iv) The current inspection status of the aircraft, including the time since the last inspection required by the inspection program under which the aircraft and its appliances are maintained. (v) The current status of applicable airworthiness directives (AD) including, for each, the method of compliance, the AD number, and revision date. If the AD involves recurring action, the time and date when the next action is required. (vi) Copies of the forms prescribed by §43.9(a) of this chapter for each major alteration to the airframe and currently installed engines, rotors, propellers, and appliances. (b) The owner or operator shall retain the following records for the periods prescribed: (1) The records specified in paragraph (a)(1) of this section shall be retained until the work is repeated or superseded by other work or for 1 year after the work is performed. (2) The records specified in paragraph (a)(2) of this section shall be retained and transferred with the aircraft at the time the aircraft is sold. (3) A list of defects furnished to a registered owner or operator under §43.11 of this chapter shall be retained until the defects are repaired and the aircraft is approved for return to service. (c) The owner or operator shall make all maintenance records required to be kept by this section available for inspection by the Administrator or any authorized representative of the National Transportation Safety Board (NTSB). In addition, the owner or operator shall present Form 337 described in paragraph (d) of this section for inspection upon request of any law enforcement officer. (d) When a fuel tank is installed within the passenger compartment or a baggage compartment pursuant to part 43 of this chapter, a copy of FAA Form 337 shall be kept on board the modified aircraft by the owner or operator. (Approved by the Office of Management and Budget under control number 2120-0005) § 43.9 Content, form, and disposition of maintenance, preventive maintenance, rebuilding, and alteration records (except inspections performed in accordance with part 91, part 125, §135.411(a)(1), and §135.419 of this chapter). (a) Maintenance record entries. Except as provided in paragraphs (b) and (c) of this section, each person who maintains, performs preventive maintenance, rebuilds, or alters an aircraft, airframe, aircraft engine, propeller, appliance, or component part shall make an entry in the maintenance record of that equipment containing the following information: (1) A description (or reference to data acceptable to the Administrator) of work performed. (2) The date of completion of the work performed. (3) The name of the person performing the work if other than the person specified in paragraph (a)(4) of this section. (4) If the work performed on the aircraft, airframe, aircraft engine, propeller, appliance, or component part has been performed satisfactorily, the signature, certificate number, and kind of certificate held by the person approving the work. The signature constitutes the approval for return to service only for the work performed. (b) Each holder of an air carrier operating certificate or an operating certificate issued under Part 121 or 135, that is required by its approved operations specifications to provide for a continuous airworthiness maintenance program, shall make a record of the maintenance, preventive maintenance, rebuilding, and alteration, on aircraft, airframes, aircraft engines, propellers, appliances, or component parts which it operates in accordance with the applicable provisions of Part 121 or 135 of this chapter, as appropriate. (c) This section does not apply to persons performing inspections in accordance with Part 91, 125, §135.411(a)(1), or §135.419 of this chapter. (d) In addition to the entry required by paragraph (a) of this section, major repairs and major alterations shall be entered on a form, and the form disposed of, in the manner prescribed in appendix B, by the person performing the work. [Amdt. 43-23, 47 FR 41085, Sept. 16, 1982, as amended by Amdt. 43-37, 66 FR 21066, Apr "Tim" wrote in message ... | See inline replies. | | Jim Macklin wrote: | An equipment list is required and lists all components and | accessories and parts installed, except for the airframe | itself. | | Where is the reg for this? I have not found it yet. Is there a | specified format? | | A really well done equipment list will include the | model and serial number for items and not just the name, | weight and station [location on the airplane]. This makes | researching and compliance with ADs much easier. | The engine, propeller, alternator, magnetos, battery, | radios, wheels, tires, brakes, seat belts should be listed. | | But older airplanes did not have a modern POH and the | owners' handbook would also sometime include a separate AFM | and the factory original W&B data should have had the | equipment list and the FAA should have a copy of that in the | registry in OKC. You can then survey the airplane [good | time to do a real annual] | | As opposed to an "unreal annual?" I am not sure what you mean by this. | | and verify that each item is | really installed, update to include serial numbers and | current AD status and add any items that have been added and | delete items that are no longer installed. | | I am most likely going to base mine on the log book entries and an | equipment list from a plane of the same year and model. | | thanks, tim | | | | | | "Tim" wrote in message | ... | | Mark Hansen wrote: | | On 03/01/07 21:44, Tim wrote: | | | | What is required as far as a formal equipment list for | part 91 | | operations? In reading 91.205 and listening to one | instructor I know, I | | cannot reconcile what he says with the FARs. He states | that an aircraft | | must have an equipment list. I cannot find an equipment | list for the | | plane I fly regularly. I see partial entries for | "equipment list" on | | W&B forms in the plane, but no formal equipment list | showing all the | | arms/moments and weights of all the items in the | aircraft. I have seen | | examples of this for various aircraft in the POH. | | | | I fly an older AA5A and the POH is not even close to | what I would call a | | useful document for the airplane. It is very brief, | contains errors and | | contains self-contradictory information. I am not | surprised to seem to | | be missing a required document. | | | | Is this a required document? If so, how can I recreate | it or obtain a | | new one? I was considering recreating from an account | of the logs. | | | | The manufacturer is no longer in business. | | | | Any idea where I would find "equipment list" | requirements in the regs? | | | | thanks, | | tim | | | | | | There was a recent article by Mike Busch at AVWeb on | this topic. AVWeb | | members can see the article he | | | | http://www.avweb.com/news/savvyaviator/194428-1.html | | | | If you're not a member already, join! It's free and | there's lots of great | | stuff there. | | | | | | After posting this I found the article. Thanks. | | |
... Look in part 23 and 91. § 23.1589 Loading information. The following loading information must be furnished: So we are all agreed that an up to date equipment list is not a regulatory requirement, right? ------------------------------- Travis Lake N3094P PWK |
![]() "Tim" wrote All my annuals are real annuals. I might almost be insulted by this comment. You might be rightfully insulted, but the sad fact remains that many annuals are "pencil whipped" annuals. -- Jim in NC |
There are many annuals done each year that are pencil
whipped. You get what you want and pay for, more power to you for doing it right. "Tim" wrote in message ... | All my annuals are real annuals. I might almost be insulted by this | comment. | | | | Jim Macklin wrote: | A real annual is when the AI actual looks at all the details | and the owner wants it done right, not just cheap. | | | | "Tim" wrote in message | ... | | See inline replies. | | | | Jim Macklin wrote: | | An equipment list is required and lists all components | and | | accessories and parts installed, except for the airframe | | itself. | | | | Where is the reg for this? I have not found it yet. Is | there a | | specified format? | | | | A really well done equipment list will include the | | model and serial number for items and not just the name, | | weight and station [location on the airplane]. This | makes | | researching and compliance with ADs much easier. | | The engine, propeller, alternator, magnetos, battery, | | radios, wheels, tires, brakes, seat belts should be | listed. | | | | But older airplanes did not have a modern POH and the | | owners' handbook would also sometime include a separate | AFM | | and the factory original W&B data should have had the | | equipment list and the FAA should have a copy of that in | the | | registry in OKC. You can then survey the airplane [good | | time to do a real annual] | | | | As opposed to an "unreal annual?" I am not sure what you | mean by this. | | | | and verify that each item is | | really installed, update to include serial numbers and | | current AD status and add any items that have been added | and | | delete items that are no longer installed. | | | | I am most likely going to base mine on the log book | entries and an | | equipment list from a plane of the same year and model. | | | | thanks, tim | | | | | | | | | | | | "Tim" wrote in message | | ... | | | Mark Hansen wrote: | | | On 03/01/07 21:44, Tim wrote: | | | | | | What is required as far as a formal equipment list | for | | part 91 | | | operations? In reading 91.205 and listening to one | | instructor I know, I | | | cannot reconcile what he says with the FARs. He | states | | that an aircraft | | | must have an equipment list. I cannot find an | equipment | | list for the | | | plane I fly regularly. I see partial entries for | | "equipment list" on | | | W&B forms in the plane, but no formal equipment list | | showing all the | | | arms/moments and weights of all the items in the | | aircraft. I have seen | | | examples of this for various aircraft in the POH. | | | | | | I fly an older AA5A and the POH is not even close to | | what I would call a | | | useful document for the airplane. It is very brief, | | contains errors and | | | contains self-contradictory information. I am not | | surprised to seem to | | | be missing a required document. | | | | | | Is this a required document? If so, how can I | recreate | | it or obtain a | | | new one? I was considering recreating from an | account | | of the logs. | | | | | | The manufacturer is no longer in business. | | | | | | Any idea where I would find "equipment list" | | requirements in the regs? | | | | | | thanks, | | | tim | | | | | | | | | There was a recent article by Mike Busch at AVWeb on | | this topic. AVWeb | | | members can see the article he | | | | | | | http://www.avweb.com/news/savvyaviator/194428-1.html | | | | | | If you're not a member already, join! It's free and | | there's lots of great | | | stuff there. | | | | | | | | | After posting this I found the article. Thanks. | | | | | | |
No, it is required by part 43 et al.
"Travis Marlatte" wrote in message t... | "Jim Macklin" wrote in message | ... | Look in part 23 and 91. | § 23.1589 Loading information. | The following loading information must be furnished: | | | | So we are all agreed that an up to date equipment list is not a regulatory | requirement, right? | ------------------------------- | Travis | Lake N3094P | PWK | | |
... No, it is required by part 43 et al. This thread is in reference to an equipment list with weight and balance information. I don't see that in the portions of part 43 that you quoted (or anywhere else). What you have shown is that work must be documented. Log book entries and an updated W&B would satisfy those regs. That implies to me that one could construct an equipment list from the records but not that an up to date equipment list is to be maintained. I really am not trying to be confrontational. In fact, I assume that I'm missing something because both Steve Ellis and Mike Busch claim that it is necessary. I just don't see it. And, apparently, neither to many pilots and A&P's because I have never seen such a list kept up to date (in my admitedly limited exposure to such things). ------------------------------- Travis Lake N3094P PWK |
Travis Marlatte wrote:
"Jim Macklin" wrote in message ... No, it is required by part 43 et al. This thread is in reference to an equipment list with weight and balance information. I don't see that in the portions of part 43 that you quoted (or anywhere else). What you have shown is that work must be documented. Log book entries and an updated W&B would satisfy those regs. That implies to me that one could construct an equipment list from the records but not that an up to date equipment list is to be maintained. I really am not trying to be confrontational. In fact, I assume that I'm missing something because both Steve Ellis and Mike Busch claim that it is necessary. I just don't see it. And, apparently, neither to many pilots and A&P's because I have never seen such a list kept up to date (in my admitedly limited exposure to such things). ------------------------------- Travis Lake N3094P PWK It isn't exactly clear to me - the only thing I see is a reference for it in part 23 (from Jim's earlier post)- that it has to be part of the airplane manual. I guess then all other fars about the airplane manual then come into play. I see nothing in part 91 about it. I could be wrong. Not a lot of information on this. Certainly not something that I was taught as a PP student. (And the usual FAR books that are sold don't even have a part 23 section - I had to look it up online) |
Oxygen equipment | Roger Worden | Soaring | 1 | May 9th 05 02:59 PM |
For Sale O2 equipment | MC | Soaring | 1 | May 4th 05 01:17 AM |
ac manufacturing equipment fs | Dr. Hibbert | Aviation Marketplace | 0 | May 11th 04 01:48 PM |
Equipment List Required Documentation | O. Sami Saydjari | Owning | 9 | April 21st 04 02:57 AM |
tso equipment | Air Methods Corporation | Home Built | 0 | September 21st 03 07:41 PM |
