Oxygen equipment
Old May 9th 05, 07:34 AM
Roger Worden
Default Oxygen equipment
On the advice of fellow club members I ordered an oxygen-saving cannula,
flow meter, and connector to use O2 in a club ship. When I placed the order
I was advised by the vendor that regulations require a MASK in the ship, not
just a cannula. He mentioned some situations wherein a mask would be better,
e.g. if one has a head cold, if one is panicking and breathing through the
mouth, etc. Makes sense, but that doesn't mean it's required by the FAA. I
looked it up in FAR/AIM, but I'm not finding a CFR that requires a mask in
an unpressurized aircraft. 91.211(b)(ii) does, but it's for pressurized
cabin aircraft.
I haven't bought a mask bit I might if it's wise or required. Seems to me
that to switch from cannula to mask you'd either need a Y and shutoff
valves, or quick-connects.
Comments? Advice?
Old May 9th 05, 03:59 PM
It's very important to remember to breathe through your nose. My older
nose doesn't always stay open and I frequently find myself breathing
through my mouth. I added a little plastic band with 2 holes in it, to
the nasial tubes so that they are spread out a bit. Works great. Don't
forget to gently blow back into these tubes when pre-flighting your
oxygen equipment, should get resistance, easy flow means one of the
little bladders is ruptured. These things are only good for 200 hours
of use, so about every 4 years, through it away and buy a new one.
Nelson says it's good up to 18K, above that he recommends a mask,
believe the Feds agree.
JJ
cannula,
order
ship, not
better,
through the
FAA. I
mask in
pressurized
cabin aircraft.
to me
Comments? Advice?
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 08:35 PM
Reprise - Oxygen concerns Neptune Soaring 20 May 27th 04 04:27 PM
Need oxygen information Neptune Soaring 3 May 10th 04 07:06 AM
Need oxygen information Neptune Soaring 4 May 6th 04 09:11 PM
Catastrophic Decompression; Small Place Solo Aviation Piloting 193 January 13th 04 09:52 PM
