![]() wrote I'd rather have the toggles in my Jodel but it makes the airplane so much easier to steal. If you can get in you can go. You could rig up a cover to put over the toggles, with a place to put a padlock on the cover, as long as it is not a certified plane. Would altering a plane in that manner be against the rules for certified planes? It would be in the certified plane's regular certified condition, while it was being flown, after all! -- Jim in NC |
"Jon Woellhaf" wrote in message
... And I've been trying to learn for years why R is on the left and L is on the right. My recollection from the last time this was discussed is that the labeles used to be the other way around so that "L" on the left meant that the left mag was grounded and, therefore, the right mag was firing. Then, to keep it more consistent with the "Off" and "Both" labeling, they switched the labeling but left the right key position which grounded the right mag so that the left mag was firing now labeled "L"? Doesn't bother me a bit. If one mag fails an RPM drop, I'm gonna check the wiring to both any. What is more important to me is that the left key position has the bottom plugs firing. That's important so that I can pull the correct plugs the first time to clear an unusually stubborn fouling. Say, why don't they label them "Off", "B", "T", and "Both"? ------------------------------- Travis Lake N3094P PWK |
![]() "Travis Marlatte" wrote Say, why don't they label them "Off", "B", "T", and "Both"? Excellent suggestion! Why not? It might make too much sense, that way! One could put an "auxiliary label" on panel next to the "L" and "R" with a Dyno Label, or with another favorite method, though. -- Jim in NC |
"Travis Marlatte" wrote in
t: What is more important to me is that the left key position has the bottom plugs firing. That's important so that I can pull the correct plugs the first time to clear an unusually stubborn fouling. I thought that one mag controlled the top plugs on one side and the bottom on the other side. |
On Mar 4, 12:53 am, Jackal24 wrote:
"Travis Marlatte" wrote . net: What is more important to me is that the left key position has the bottom plugs firing. That's important so that I can pull the correct plugs the first time to clear an unusually stubborn fouling. I thought that one mag controlled the top plugs on one side and the bottom on the other side. Yup, on Lycoming. Continental, at least on the smaller engines, will have the right mag firing the top plugs and the left firing the bottom. The impulse mag (right) fires the top plugs, since they're less likely to get wet with oil or fuel. Dan |
Tony Cox wrote:
Here's a question that until yesterday I'd have thought was obvious. Cessna-style (and no doubt other) ignition switches have five settings -- Off/Right/Left/Both/Start. When you're on the "Right" setting, does it mean you are firing on the right magneto or does it mean the right magneto is grounded? Is this covered in the plane's POH? |
On Mar 4, 8:55 am, Stubby
wrote: Tony Cox wrote: Here's a question that until yesterday I'd have thought was obvious. Cessna-style (and no doubt other) ignition switches have five settings -- Off/Right/Left/Both/Start. When you're on the "Right" setting, does it mean you are firing on the right magneto or does it mean the right magneto is grounded? Is this covered in the plane's POH? Good question. It isn't. It isn't covered in the shop manual either. |
Nav radio settings in FMC | Mxsmanic | Piloting | 5 | January 10th 07 08:39 PM |
74 Archer ignition switch question | Mike Noel | Owning | 9 | September 10th 06 10:46 PM |
Ignition switch, what happen when Left or Right is selected | Martin B | Piloting | 41 | May 21st 05 04:55 AM |
ATC Altimeter Settings | O. Sami Saydjari | Instrument Flight Rules | 81 | April 11th 05 08:07 PM |
Just Ordered: An Ignition Switch and Oil Filter from ACS | Larry Smith | Home Built | 30 | October 22nd 03 07:41 AM |
