In flight recorder
Old March 22nd 07, 12:41 AM posted to rec.aviation.piloting
Morgans[_2_]
Default In flight recorder
"Lou" wrote
Ok, Ok, I was just thinking the worst possible ending of a flight.
The
safe was to protect the recorder from fire.
Lou
So I watch too much tv.
IF things did go really badly, and you WERE killed in a crash, I don't think
I would want the survivors in my family to have a tape of my last flight,
and dieing words and painful screaming.
If it did go badly, let there be no record of the end; only memories of the
good times. That is just me, though.
Old March 22nd 07, 02:09 AM posted to rec.aviation.piloting
**THE-RFI-EMI-GUY**
Put it way back in the tail!
;-P
Gig 601XL Builder wrote:
Lou wrote:
On Mar 21, 12:45 pm, "Longworth" wrote:
On Mar 21, 12:58 pm, "Lou" wrote:
Has anyone ever made their own in-flight recorder? I'm curious how
I did it during my IFR training week. I used a small mp3 player/
recorder and put the tiny mic inside my earcup of my headset. It
worked fine.
Hai Longworth
Thats perfect. It's a long way off, but when I finish my plane I
thought it would be cool to
record the first flights.
Lou
P.S., the safe was incase of disaster.
I have no problem with the idea of a recorder in the cockpit. I just see no
use for the safe.
Joe Leikhim K4SAT
"The RFI-EMI-GUY"©
"Treason doth never prosper: what's the reason?
For if it prosper, none dare call it treason."
"Follow The Money" ;-P
**THE-RFI-EMI-GUY**
;-P
worked fine.
Hai Longworth
Lou
use for the safe.
Joe Leikhim K4SAT
"The RFI-EMI-GUY"©
Maxwell
"Lou" wrote in message
this would be done. I don't think it would be that difficult if you
use a regular cassette in one of those small fire safes. Just
drill a small hole to accomadate the mic wire. But how would you hook
it up to the intercom?
Or would you have a small lapel mic attatched to your headset? Anyway,
has anyone tried this?
Lou
I just bought a 72 digital recorder from Radio Shack for $69, weighs about
2.5 ounces and half the size of the old micro cassettes.
Seems very unlikely you would need fire proofing, but if so:
Grab some 1/2" or 1" thick ceramic fiber blanket from a local industral
gasket company. Use it to wrap or bag the recorder somehow. A bank bag lined
with the fiber and a plastic bag inside it, to keep the recorder out of the
fiber might do.
You could probably do it all for less than a pound.
Old March 22nd 07, 08:58 AM posted to rec.aviation.piloting
Christopher Brian Colohan
"Lou" writes:
My understanding is that fire safes are designed to protect documents.
They are lined with a chemical which produces water when it is heated,
which stops documents from lighting on fire. Water probably won't do
a lot of good for electronics.
Chris
Old March 22nd 07, 10:04 AM posted to rec.aviation.piloting
Morgans[_2_]
Lining produces water? Where did you hear that poppycock?
They insulate, plain and simple, to keep the document below ignition
temperature.
Old March 22nd 07, 01:54 PM posted to rec.aviation.piloting
Andrew Sarangan
I use that technique on all my dual flights and give to the student
for review. A couple of years ago I wrote it up as an article and sent
it to AOPA Flight Training magazine, but they did not seem very
interested. Here is a copy:
http://www.sarangan.org/aviation/art...er-article.pdf
On Mar 21, 8:39 pm, Richard Turner wrote:
Back when I was working as a flight test instrumentation engineer at the
USAF Test Pilot School, we were trying to figure out an easy way to
record audio. The easiest way we found, short of doing a modification
to the airplanes and including expensive flight-qualified recorders, was
to take a little audio-activated voice recorder and ran a small
microphone inside the ear cup of one of our headsets. We'd put the
small recorder in our pockets. It worked really well at catching
everything that was said through the intercom.
It's not a "fireproof" solution, but hopefully this might get you
thinking in other areas.
Rich
N734BV @ 75FL
Lou- Hide quoted text -
- Show quoted text -
Old March 22nd 07, 03:26 PM posted to rec.aviation.piloting
Bladerunner
interested. Here is a copy:http://www.sarangan.org/aviation/art...er-article.pdf
Rich
N734BV @ 75FL
Nice Article , Wish I had read it as a ppl student. I'm going to use
this technique for my IR rating
Old March 22nd 07, 04:26 PM posted to rec.aviation.piloting
Dylan Smith
I hooked up a video camera to the intercom. I made up a special cable
with a potentiometer in it to attenuate the level coming out of the
intercom - it was massively too high for the camera's audio input, and
that worked fine (the proper way to do it would probably be an impedance
matching transformer).
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old March 22nd 07, 05:08 PM posted to rec.aviation.piloting
Lou
Good article, why did you stop with AOPA?
There are other aviation publications.
Lou
How to Share a Flight Recorder in a Club? ContestID67 Soaring 17 September 26th 06 02:23 AM
Backup Flight Data Recorder? Fox Two Soaring 14 August 27th 06 09:42 AM
EW B-Model flight recorder BDS Soaring 12 August 19th 06 04:39 PM
US: Flight Recorder Alert Judy Ruprecht Soaring 8 July 19th 04 09:04 PM
who does Flight Recorder calibration... ken ward Soaring 4 March 5th 04 02:28 AM
