Volatility Question about Mixing Fuels
Old April 5th 07, 03:07 PM posted to rec.aviation.homebuilt
GeorgeB
Default Volatility Question about Mixing Fuels
On Wed, 4 Apr 2007 18:26:52 -0400, "Capt. Geoffrey Thorpe" The Sea
Hawk at wow way d0t com wrote:
The volatility should be the average of the two.
I don't know that I would assume that - vapor pressure can have some
non-linear behavior. Example: When you add ethanol, the vapor pressure with
10% is higher than the vapor pressure at either 0% or 85%...
I am not disagreeing, but do wonder where this information is
available?
Thanks, George
Old April 5th 07, 09:57 PM posted to rec.aviation.homebuilt
"GeorgeB" wrote in message
with
available?
Thanks, George
I've seen it at work - no help to you, eh?
There are a number of SAE papers covering this. e.g.
http://www.sae.org/technical/papers/852116
http://www.sae.org/technical/papers/2000-01-1712
Geoff
Alternate Fuels john smith Piloting 0 September 25th 05 03:10 AM
Mixing PPG delta and PPG Durathane.....??? Randall Shimizu Home Built 3 November 5th 04 05:07 AM
U-2 fuels ? Lynn Coffelt Military Aviation 2 May 29th 04 04:48 PM
mixing 80 and 100 and autogas...? R. Wubben Owning 5 March 15th 04 03:28 AM
Mixing construction materials Neal Fulco Home Built 3 October 7th 03 01:55 PM
