![]() Robert M. Gary wrote: On Apr 10, 9:12 pm, Jim Stewart wrote: Does an engine past TBO make an aircraft non-airworthy? I can't seem to find a straight answer on the web. Assuming you can find an IA willing to sign an annual then no. Have you found that to be a problem? I haven't. My mechanic flies his 180 on pipeline patrol and is 1000 over TBO on his 470. Another friend also flies pipeline in his PA12 and went 3600 hours before he topped it and 7000 hours before he finally majored it, that's a lot of 100 hour inspections. |
On Apr 11, 10:16 am, Newps wrote:
Robert M. Gary wrote: On Apr 10, 9:12 pm, Jim Stewart wrote: Does an engine past TBO make an aircraft non-airworthy? I can't seem to find a straight answer on the web. Assuming you can find an IA willing to sign an annual then no. Have you found that to be a problem? I haven't. My mechanic flies his 180 on pipeline patrol and is 1000 over TBO on his 470. Another friend also flies pipeline in his PA12 and went 3600 hours before he topped it and 7000 hours before he finally majored it, that's a lot of 100 hour inspections. Yes, many IA's I've worked with refuse to sign after 200 over TBO. Its probably a liability issue. -robert |
![]() "Robert M. Gary" wrote in message oups.com... On Apr 11, 10:16 am, Newps wrote: Robert M. Gary wrote: On Apr 10, 9:12 pm, Jim Stewart wrote: Does an engine past TBO make an aircraft non-airworthy? I can't seem to find a straight answer on the web. Assuming you can find an IA willing to sign an annual then no. Have you found that to be a problem? I haven't. My mechanic flies his 180 on pipeline patrol and is 1000 over TBO on his 470. Another friend also flies pipeline in his PA12 and went 3600 hours before he topped it and 7000 hours before he finally majored it, that's a lot of 100 hour inspections. Yes, many IA's I've worked with refuse to sign after 200 over TBO. Its probably a liability issue. Sounds like a competency issue - on what basis did they 'fail" the aircraft? |
![]() Yes, many IA's I've worked with refuse to sign after 200 over TBO. Its probably a liability issue. Sounds like a competency issue - on what basis did they 'fail" the aircraft? They don't have to fail anything. If it's not returned to service, the owner is at liberty to find another IA who is willing to return it to service. An IA is not obligated to explain why he chooses not to return an aircraft to service. |
![]() "Robert M. Gary" wrote in message ups.com... On Apr 10, 9:12 pm, Jim Stewart wrote: Does an engine past TBO make an aircraft non-airworthy? I can't seem to find a straight answer on the web. Assuming you can find an IA willing to sign an annual then no. Pardon? |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Restricted Airworthiness | Brad Mallard | Aviation Marketplace | 1 | May 20th 04 05:18 PM |
Airworthiness Cert Still Valid? | Carl Orton | Owning | 12 | February 13th 04 10:21 PM |
Teaching airworthiness | Roger Long | Piloting | 28 | October 2nd 03 09:08 PM |
Airworthiness certification of an experimental | Ace Pilot | Home Built | 0 | July 16th 03 03:26 PM |
