Power Supply in 98 C182S
Old April 16th 07, 03:06 PM posted to rec.aviation.owning,rec.aviation.piloting
Dave Butler
Default Power Supply in 98 C182S
Dan wrote:
What are the options here? How difficult and/or expensive would it be
to have one of these installed? The avionics are relatively new, but I
prefer to use my Garmin 396 for weather, XM, etc. and would really
like to have a place to plug it in.
We'll probably have the plane in the shop soon for a Garmin 430
installation.
Have the avionics shop install a 4-pin connector to power the 396,
connect the audio output from the 396 to the audio panel, and the flight
plan output from the 430 to the 396. That's what I have (except mine's a
GNS480). They made up a special cable for the 396. One plug/cable does
it all, no cables dangling all over the cockpit.
Dave
Old April 16th 07, 03:53 PM posted to rec.aviation.owning,rec.aviation.piloting
Maxwell
"Dan" wrote in message
We haven't finalized purchase of the aircraft yet, but
having flown Pipers for about 95% of my flight time to date, the
downward visibility and shade offered by the high wing were definate
pluses.
I thought I wasn't going to like high wing, but it's not that bad
actually...
They have always been my preference for the exact same reason. I usually fly
172s because of the price and availibility in my area, but the 182 is
actually my preference. I think you might find that high wing a bit
addictive, I have.
Old April 16th 07, 06:40 PM posted to rec.aviation.owning,rec.aviation.piloting
xyzzy
On Apr 16, 1:04 am, "Dan" wrote:
Doesn't it have one of those weird 4 pin ARINC plugs that you need an
adapter for (a-lahttp://tinyurl.com/2erxr6) in the center pedestal?
Well, I didn't see that, but I was looking on the right side, mainly.
I'll have to check on the center panel. Does anyone know definatively
if late 90s 182s have this connector?
I believe it was optional. My flying club had a fleet of 3 C172S's
ranging from 2000-2002 model year, and two of them had the 4-pin ARINC
plug and one did not. Coincidently (or not?) the one without the 4-
pin plug was the one with the single (rather than dual) axis KAP-140
and was also the oldest of the 3 (model year 2000).
I suppose I can look in the
manual...
I don't think the manual will tell you, especially if it was optional
equipment. Why not just ask the seller?
Goddard Cables & Power supply FS Discus 44 Soaring 0 February 1st 07 05:48 PM
Strobe Power Supply Mounting Plate Mike Spera Owning 0 January 1st 07 05:06 PM
B2431 CAN YOU E-MAIL ME ABOUT GYRO POWER SUPPLY Tony Home Built 3 March 8th 06 12:24 AM
WANTING GYRO POWER SUPPLY ???? Tony Home Built 5 March 7th 06 07:17 PM
12VDC - 115V 3 PHASE 400HZ POWER SUPPLY Tony Home Built 1 March 5th 06 05:12 PM
