All,
Our club is in the final stages of purchasing a 1998 Cessna 182S. Much to my dismay, I noticed the lack of a 12-volt cigarette lighter (or it's 24-volt equivalent) anywhere to be found. (am I just not looking in the right place?) What are the options here? How difficult and/or expensive would it be to have one of these installed? The avionics are relatively new, but I prefer to use my Garmin 396 for weather, XM, etc. and would really like to have a place to plug it in. We'll probably have the plane in the shop soon for a Garmin 430 installation. Between this issue and the annoying chart clip holder on the yoke, it sure isn't very compatible with portable GPS equipment. ![]() --Dan |
My 296 says it operates on 11-35 volts. So plug it in, you're good to go.
Dan wrote: All, Our club is in the final stages of purchasing a 1998 Cessna 182S. Much to my dismay, I noticed the lack of a 12-volt cigarette lighter (or it's 24-volt equivalent) anywhere to be found. (am I just not looking in the right place?) What are the options here? How difficult and/or expensive would it be to have one of these installed? The avionics are relatively new, but I prefer to use my Garmin 396 for weather, XM, etc. and would really like to have a place to plug it in. We'll probably have the plane in the shop soon for a Garmin 430 installation. Between this issue and the annoying chart clip holder on the yoke, it sure isn't very compatible with portable GPS equipment. ![]() --Dan |
Newps wrote:
My 296 says it operates on 11-35 volts. So plug it in, you're good to go. Dan wrote: All, Our club is in the final stages of purchasing a 1998 Cessna 182S. Much to my dismay, I noticed the lack of a 12-volt cigarette lighter (or it's 24-volt equivalent) anywhere to be found. (am I just not looking in the right place?) What are the options here? How difficult and/or expensive would it be to have one of these installed? The avionics are relatively new, but I prefer to use my Garmin 396 for weather, XM, etc. and would really like to have a place to plug it in. We'll probably have the plane in the shop soon for a Garmin 430 installation. Between this issue and the annoying chart clip holder on the yoke, it sure isn't very compatible with portable GPS equipment. ![]() --Dan Except he doesn't have a plug ... or at least he can't find one. Matt |
Dan wrote:
All, Our club is in the final stages of purchasing a 1998 Cessna 182S. Much to my dismay, I noticed the lack of a 12-volt cigarette lighter (or it's 24-volt equivalent) anywhere to be found. (am I just not looking in the right place?) /snip/ Dan, You're right, the late '90's Cessna singles did not have cigarette lighter jacks installed. There is plenty of room on the panel to install one (or better yet, two), just like the older models. I've seen this done on several aircraft. Happy Flying! Scott Skylane |
You can have your mechanic install a cig lighter up under the panel
where you can't see it so you can keep the cord clutter to a minimum. Scott Skylane wrote: Dan wrote: All, Our club is in the final stages of purchasing a 1998 Cessna 182S. Much to my dismay, I noticed the lack of a 12-volt cigarette lighter (or it's 24-volt equivalent) anywhere to be found. (am I just not looking in the right place?) /snip/ Dan, You're right, the late '90's Cessna singles did not have cigarette lighter jacks installed. There is plenty of room on the panel to install one (or better yet, two), just like the older models. I've seen this done on several aircraft. Happy Flying! Scott Skylane |
On Sun, 15 Apr 2007 14:04:52 -0800, Scott Skylane
wrote: Dan wrote: All, Our club is in the final stages of purchasing a 1998 Cessna 182S. Much to my dismay, I noticed the lack of a 12-volt cigarette lighter (or it's 24-volt equivalent) anywhere to be found. (am I just not looking in the right place?) /snip/ Dan, You're right, the late '90's Cessna singles did not have cigarette lighter jacks installed. There is plenty of room on the panel to install one (or better yet, two), just like the older models. I've seen this done on several aircraft. Doesn't it have one of those weird 4 pin ARINC plugs that you need an adapter for (a-la http://tinyurl.com/2erxr6 ) in the center pedestal? |
In rec.aviation.owning Peter Clark wrote:
On Sun, 15 Apr 2007 14:04:52 -0800, Scott Skylane wrote: Dan wrote: All, Our club is in the final stages of purchasing a 1998 Cessna 182S. Much to my dismay, I noticed the lack of a 12-volt cigarette lighter (or it's 24-volt equivalent) anywhere to be found. (am I just not looking in the right place?) /snip/ Dan, You're right, the late '90's Cessna singles did not have cigarette lighter jacks installed. There is plenty of room on the panel to install one (or better yet, two), just like the older models. I've seen this done on several aircraft. Doesn't it have one of those weird 4 pin ARINC plugs that you need an adapter for (a-la http://tinyurl.com/2erxr6 ) in the center pedestal? I would think that it should, and if it does, the adapter for cigarette plugs will be a lot cheaper than having one installed. -- Jim Pennino Remove .spam.sux to reply. |
adapter for (a-la http://tinyurl.com/2erxr6 ) in the center pedestal? I would think that it should, and if it does, the adapter for cigarette plugs will be a lot cheaper than having one installed. SPORTY'S sells the 12V adaptor that fits the four-pin receptacle. |
On Apr 15, 5:02 pm, Peter Clark
wrote: On Sun, 15 Apr 2007 14:04:52 -0800, Scott Skylane wrote: Dan wrote: All, Our club is in the final stages of purchasing a 1998 Cessna 182S. Much to my dismay, I noticed the lack of a 12-volt cigarette lighter (or it's 24-volt equivalent) anywhere to be found. (am I just not looking in the right place?) /snip/ Dan, You're right, the late '90's Cessna singles did not have cigarette lighter jacks installed. There is plenty of room on the panel to install one (or better yet, two), just like the older models. I've seen this done on several aircraft. Doesn't it have one of those weird 4 pin ARINC plugs that you need an adapter for (a-lahttp://tinyurl.com/2erxr6) in the center pedestal? Well, I didn't see that, but I was looking on the right side, mainly. I'll have to check on the center panel. Does anyone know definatively if late 90s 182s have this connector? I suppose I can look in the manual... We haven't finalized purchase of the aircraft yet, but having flown Pipers for about 95% of my flight time to date, the downward visibility and shade offered by the high wing were definate pluses. I thought I wasn't going to like high wing, but it's not that bad actually... --Dan |
On Apr 15, 10:04 pm, "Dan" wrote:
On Apr 15, 5:02 pm, Peter Clark wrote: On Sun, 15 Apr 2007 14:04:52 -0800, Scott Skylane wrote: Dan wrote: All, Our club is in the final stages of purchasing a 1998 Cessna 182S. Much to my dismay, I noticed the lack of a 12-volt cigarette lighter (or it's 24-volt equivalent) anywhere to be found. (am I just not looking in the right place?) /snip/ Dan, You're right, the late '90's Cessna singles did not have cigarette lighter jacks installed. There is plenty of room on the panel to install one (or better yet, two), just like the older models. I've seen this done on several aircraft. Doesn't it have one of those weird 4 pin ARINC plugs that you need an adapter for (a-lahttp://tinyurl.com/2erxr6) in the center pedestal? Well, I didn't see that, but I was looking on the right side, mainly. I'll have to check on the center panel. Does anyone know definatively if late 90s 182s have this connector? I suppose I can look in the manual... We haven't finalized purchase of the aircraft yet, but having flown Pipers for about 95% of my flight time to date, the downward visibility and shade offered by the high wing were definate pluses. I thought I wasn't going to like high wing, but it's not that bad actually... --Dan- Hide quoted text - - Show quoted text - OK, anyone know where I can find an online manual for a 98 182S? : ) --Dan |
Goddard Cables & Power supply FS | Discus 44 | Soaring | 0 | February 1st 07 05:48 PM |
Strobe Power Supply Mounting Plate | Mike Spera | Owning | 0 | January 1st 07 05:06 PM |
B2431 CAN YOU E-MAIL ME ABOUT GYRO POWER SUPPLY | Tony | Home Built | 3 | March 8th 06 12:24 AM |
WANTING GYRO POWER SUPPLY ???? | Tony | Home Built | 5 | March 7th 06 07:17 PM |
12VDC - 115V 3 PHASE 400HZ POWER SUPPLY | Tony | Home Built | 1 | March 5th 06 05:12 PM |
