About avoiding airspace and cruising
Old April 21st 07, 12:33 AM posted to rec.aviation.piloting
Thomas Borchert
Default About avoiding airspace and cruising
Erik,
The smart
thing would have been to call tower and tell them that I didn't have
the traffic,
So you learned. WHatever you do, don't let them fly the plane. "Unable"
and "unfamiliar" are magic words for you to use.
Thomas Borchert (EDDH)
Old April 21st 07, 02:35 AM posted to rec.aviation.piloting
John Clear
Erik wrote:
Jose wrote:
I'm always afraid of sounding like a dumbs417 calling towers, though.
I avoid it at every opportunity.
You should practice it at every (reasonable) opportunity. They don't
bite.
Jose
Unless you do something really dumb.
Even when you do something really dumb, they don't bite.
I was flying into SAC one time, and the tower told me to report
left downwind. I had a brainfart and had my left and right confused,
so I flew a right pattern. The guys in the tower noticed my mistake,
but cleared me to land anyway. I'm sure they made some comments
about my intelligence to each other, but nothing was said over the
radio.
I heard someone else do something similar at PAO, and when it was
pointed out, they responded with "I always get confused when I fly
inverted" and tower replied with "happens to me all the time too".
Talking to tower or approach just takes practice to get comfortable
with it.
John
John Clear - http://www.clear-prop.org/
Old April 20th 07, 08:08 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 20 Apr 2007 10:00:07 -0700, Erik
wrote in :
Larry Dighera wrote:
On Fri, 20 Apr 2007 09:29:58 -0700, Erik
wrote in :
What's the safest way to do this?
If you are _sure_ of remaining outside of Class D airspace, contact
the tower and advise them that you will be conducting a photo-shoot at
the coordinates of the location (expressed as distance from a VOR on a
given radial). It would also be good to request Radar Traffic
Advisory Service (flight following) from the appropriate approach
control facility prior to alerting the tower controllers.
Outside of Class A, B, and C airspace, you are the Pilot In Command
(PIC) of your flight operations, and it would be inappropriate for you
to request permission from ATC for the flight you describe.
Thanks.
You're welcome. And thank you for taking the vindictive to inform
yourself before venturing forth.
That's what I thought.
Other's may have other good ideas too, like the excellent suggestion
to take along an observer or two. A person to act as photographer or
a second pilot would be even better. Try circling at low level over a
ground feature out in uncongealed airspace, and simulate taking the
photographs in a safer environment first. You'll be better prepared
for the demands of scanning for traffic, controlling the aircraft, and
finding time to frame and focus the camera all simultaneously.
Calling the tower when I'm not entering their airspace seemed wierd to me.
I understand what you mean, but using common sense to enhance flight
safety in every way possible is the objective, the way I see it.
There is a GPS in the
aircraft I rent whenever I figure I'm going to do something in the
proximity of airspace so that I know where I'm at positively.
It might not be a bad idea to have plotted out the VOR radial and
distance on the ground during your flight planning just in case
there's a Solar Mass Ejection of something that renders the GPS
inoperative. Plan for all the possible contingencies that you are
able to foresee. That's what a reasonable and prudent airman does,
anything less could be construed by the FAA as reckless and careless
under FAR Part 91 Sec. 91.13:
http://www.airweb.faa.gov/Regulatory...6?OpenDocument
I thought calling the tower and telling them that some jackass will
be flying circles just outside of their airspace was a good idea, too,
I presume you are just being candid among fellow airmen, but in
dealing with ATC and the public, I would always don the most
professional demeanor of which I was capable. That means remaining
dignified, knowing the pertinent regulations, and acting accordingly.
In my opinion, factitiousness is inappropriate when lives are on the
line; dignity and respect will serve better.
That is unfortunate. Communication when it can reduce risk is a
valuable tool.
I suffered from "mike fright" too until I read Bob Gardener's book:
http://www.amazon.com/Say-Again-Plea...dp/1560275731/
Say Again, Please: Guide to Radio Communications
Old April 20th 07, 08:19 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 20 Apr 2007 18:08:22 GMT, Larry Dighera
wrote in :
vindictive == initiative
Old April 20th 07, 08:52 PM posted to rec.aviation.piloting
Jose
Calling a tail a leg doesn't help a horse to walk.
That's two strikes.
Jose
Get high on gasoline: fly an airplane.
Old April 21st 07, 01:52 AM posted to rec.aviation.piloting
Rich Ahrens
wrote in :
And "uncongealed airspace"? Beats the opposite, I guess.
Old April 20th 07, 08:36 PM posted to rec.aviation.piloting
Erik
I find that when I am vindictive with ATC, they tend to treat me a
little poorly. :P
That is the optimal, occasionally another person isn't available, but
it isn't like this is an emergency, so it can be put off until it can
be done safely. I really do want to wind up landing the plane at
home base. Not the hardware store, though.
Safety.
Absolutely. I don't call ATC and tell them, "Some jackass will be
making turns around a point 6 miles to your west".... Although,
depending on the controller, there are some there with pretty good
senses of humor and may get the joke, but a bona fide call would be
forthcoming.
Thomas Borchert
Larry,
I'll second that recommendation strongly.
Thomas Borchert
Erik,
Big mistake. Huge! Many accident reports where one just has to think:
Why didn't he just tell them?
Your original question is the perfect example. Imagine the controllers
have a radar screen and there comes this blip flying in real close to
their airspace and starts circling right where the planes come in. You
better believe they'd love to know what that blip has in mind, however
awkward the guy piloting the blip might explain it ;-) Even if
something like that can't be found in the standard phraseology, if you
make it concise and to the point, everybody will win.
Go become a talker! It's better for you and for everyone around.
Old April 23rd 07, 06:52 PM posted to rec.aviation.piloting
Erik
Thomas Borchert wrote:
Erik,
Yep, that's my thought. I'd rather be awkward than dead, or worse yet
living while other people got killed in some horrible accident that
was easy to prevent.
Wichita Airspace Question and overlapping airspace Owen[_4_] Piloting 1 February 14th 07 10:35 PM
Two airspace classes for one airspace? (KOQU) John R Piloting 8 June 30th 04 05:46 AM
763 Cruising Speed. [email protected] General Aviation 24 February 9th 04 10:30 PM
Cessna 150 Cruising Anony Mouse Owning 3 July 4th 03 03:27 AM
Cessna 150 Cruising Matthew P. Cummings Owning 1 July 2nd 03 01:45 AM
