Glider definition (span^2/weight)
Old April 30th 07, 07:06 PM posted to rec.aviation.soaring
Default Glider definition (span^2/weight)
"Al Eddie" wrote in message
At 12:42 30 April 2007, Wayne Paul wrote:
Al,
In the US formula is used to determine whether a fixed
wing aircraft with an
engine is classified as a glider or as an airplane.
HP-14 '6F'
http://www.soaridaho.com/
All very well but, when the engine(s) fail(s), no number
of formulae will ever determine that aircraft to be
anything other than a glider...
True; however, the formula is used to determine it is and therfore what type
rating you must have to fly it when the engine is running.
Old May 1st 07, 04:01 AM posted to rec.aviation.soaring
Doug Hoffman
Al Eddie wrote:
Isn't a glider simply defined as an aircraft with no
motive power..?
Any aircraft can become a 'glider', whereas a sailplane
is a glider built specifically for soaring.
What a motorglider is, I have no idea...
One reason it can be important to know
the precise definition of a motorglider(and Wayne
has provided the correct definition),
is for pilot licensing. One can legally
pilot a "motorglider" with just a glider
certificate with a self-launch endorsement.
Doug via Treo handheld
Posted via a free Usenet account from http://www.teranews.com
Old May 1st 07, 01:59 PM posted to rec.aviation.soaring
Andy[_1_]
That may explain why many airplane engine failure incidents turn out
badly. Airplane rated pilot flying an airplane loses engine. Pilot
is no longer rated to fly since it is now a glider. Pilot, in fear of
FAA reprisal, releases the controls and becomes a passenger.
If only he had known that the aircraft category had nothing to do with
whether the engine was running or not he might have survived.
Andy
Glider definition (span^2/weight) Bob C Soaring 0 April 29th 07 04:19 AM
D.C. anti-war rally on C-SPAN today at 8:15 AM on the west coast of US and at 11:15 AM on east coast - President Carter at Brandeis on C-SPAN 2's 'Book TV' today at 12:30 PM (on the west coast and at 3:30 PM on the east coast): [email protected] Naval Aviation 0 January 27th 07 02:18 PM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Glider weight Miguel Lavalle Soaring 8 December 17th 03 03:00 PM
Subject: Glider weight Jim Culp Soaring 0 December 17th 03 05:11 AM
