#11
On Jul 23, 12:46 pm, Michael
wrote: On Jul 23, 12:33 pm, B A R R Y wrote: I've been told this is a violation. The person who tells me this can't cite a FAR, and I can't find one in my own search. The world is full of 'experts' who will tell you that something is against the FAR's. When pressed, they will tell you to call the FSDO if you don't believe them. Those experts can't ever seem to quote the relevant FAR. They are best ignored. There is no such regulation in the Part 91 world. Michael I have to agree with Michael, there are a lot of experts who know rules that don't exist. FSDO's aren't the experts and are often the source of such myths. Locally we have had a FSDO inspector tell us we could not carry passengers while towing gliders. He reversed this after I inquired to he and is boss as to where this rule came from. Recently another FSDO inspector told a local 141 flight school that all the gas caps on their aircraft needed to be painted Red. I am still trying to figure out which hat or book he might have pulled that rule out of. Maybe someone here knows? Brian CFIIG/ASEL |
![]() "B A R R Y" wrote in message . net... Does anyone know of a FAR that prohibits removing fuel, avgas in this case, and then putting it back into the same plane? The plane is flown for part 91 service only. Examples: 1.) The plane is 50 pounds overweight for conditions. 10 gallons is siphoned out into a clean, single-purpose, approved for gasoline container. The sealed container is stored in a safe place. 2-3 hours later, upon completing the trip and returning to the field, I pour it back into the tank. 2.) I want to calibrate a fuel dipstick, so I remove a gallon at a time while taking readings. After I read the tank, I return the fuel to the tank. I've been told this is a violation. The person who tells me this can't cite a FAR, and I can't find one in my own search. I hope it is not a violation, I've had to do this at remote mountain airstrips for years. I have seen tanks calibrated(Sticks & Gauges) in an approved shop. Al G |
Greater likelihood is that you may be violating an AIRPORT rule. If your
field does not permit self-fueling, then the activity you note would probably be considered a violation. But FAR's???? Naahh ! "Al G" wrote in message ... "B A R R Y" wrote in message . net... Does anyone know of a FAR that prohibits removing fuel, avgas in this case, and then putting it back into the same plane? The plane is flown for part 91 service only. Examples: 1.) The plane is 50 pounds overweight for conditions. 10 gallons is siphoned out into a clean, single-purpose, approved for gasoline container. The sealed container is stored in a safe place. 2-3 hours later, upon completing the trip and returning to the field, I pour it back into the tank. 2.) I want to calibrate a fuel dipstick, so I remove a gallon at a time while taking readings. After I read the tank, I return the fuel to the tank. I've been told this is a violation. The person who tells me this can't cite a FAR, and I can't find one in my own search. I hope it is not a violation, I've had to do this at remote mountain airstrips for years. I have seen tanks calibrated(Sticks & Gauges) in an approved shop. Al G |
An FAA ops inspector at HQ once gave me a list of all of the regulatory
agencies pilots have to answer to. One of them was the EPA. If there is any prohibition against doing what you suggest you will find it in EPA regs, not FARs. The FARs are only the tip of the iceberg. Bob Gardner "B A R R Y" wrote in message . net... Does anyone know of a FAR that prohibits removing fuel, avgas in this case, and then putting it back into the same plane? The plane is flown for part 91 service only. Examples: 1.) The plane is 50 pounds overweight for conditions. 10 gallons is siphoned out into a clean, single-purpose, approved for gasoline container. The sealed container is stored in a safe place. 2-3 hours later, upon completing the trip and returning to the field, I pour it back into the tank. 2.) I want to calibrate a fuel dipstick, so I remove a gallon at a time while taking readings. After I read the tank, I return the fuel to the tank. I've been told this is a violation. The person who tells me this can't cite a FAR, and I can't find one in my own search. |
Pilots frequently say "I can't find it in the regulations" after limiting
their search to Parts 1, 61, 67, 91, and (occasionally) 119/135. An FAA ops inspector at HQ once gave me a list of all of the agencies whose regulations impact pilots. I no longer have the list, but as I recall there were about 20. We know about the NTSB Part 830 accident/incident regs because they are on the knowledge exams, and we know that there are National Park Service, Bureau of Land Management, and Interior Department regs affecting both airspace and landing areas because they show up on sectionals and things like the Grand Canyon SFAR. What I am leading up to is a guess that the Environmental Protection Agency may very well have a reg that speaks to the operation you propose. The airport management and/or the governmental entity operating the airport might have local regulations on the subject. Bottom line is that you can't just look to the FARs when contemplating an action. Bob Gardner "B A R R Y" wrote in message . net... Does anyone know of a FAR that prohibits removing fuel, avgas in this case, and then putting it back into the same plane? The plane is flown for part 91 service only. Examples: 1.) The plane is 50 pounds overweight for conditions. 10 gallons is siphoned out into a clean, single-purpose, approved for gasoline container. The sealed container is stored in a safe place. 2-3 hours later, upon completing the trip and returning to the field, I pour it back into the tank. 2.) I want to calibrate a fuel dipstick, so I remove a gallon at a time while taking readings. After I read the tank, I return the fuel to the tank. I've been told this is a violation. The person who tells me this can't cite a FAR, and I can't find one in my own search. |
Sorry about the double post...senior moment.
Bob "Bob Gardner" wrote in message . .. An FAA ops inspector at HQ once gave me a list of all of the regulatory agencies pilots have to answer to. One of them was the EPA. If there is any prohibition against doing what you suggest you will find it in EPA regs, not FARs. The FARs are only the tip of the iceberg. Bob Gardner "B A R R Y" wrote in message . net... Does anyone know of a FAR that prohibits removing fuel, avgas in this case, and then putting it back into the same plane? The plane is flown for part 91 service only. Examples: 1.) The plane is 50 pounds overweight for conditions. 10 gallons is siphoned out into a clean, single-purpose, approved for gasoline container. The sealed container is stored in a safe place. 2-3 hours later, upon completing the trip and returning to the field, I pour it back into the tank. 2.) I want to calibrate a fuel dipstick, so I remove a gallon at a time while taking readings. After I read the tank, I return the fuel to the tank. I've been told this is a violation. The person who tells me this can't cite a FAR, and I can't find one in my own search. |
On Mon, 23 Jul 2007 12:52:18 -0700, Brian wrote:
I have to agree with Michael, there are a lot of experts who know rules that don't exist. There's even a FAR which states this. I don't recall which, off hand, but you could get it by calling your local FSDO. - Andrew |
: Recently another FSDO inspector told a local 141 flight school that
: all the gas caps on their aircraft needed to be painted Red. I am : still trying to figure out which hat or book he might have pulled that : rule out of. Maybe someone here knows? Perhaps the same theorem we used in a math course in graduate school.... the "CRE." Complete-Rectal-Extraction ;-) -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
In rec.aviation.owning pgbnh wrote:
: Greater likelihood is that you may be violating an AIRPORT rule. If your : field does not permit self-fueling, then the activity you note would : probably be considered a violation. But FAR's???? Naahh ! : "Al G" wrote in message : ... My friendly-neighborhood AIRPORT manager tried to mandate no self-fueling of aircraft shortly after we shelled out just shy of $2000 for an autogas STC for our PA-28-180. I pointed him in the direction of the regulations regarding restrictions on public airports that accept federal funding. Included in those (can't find the link at the moment) is a requirement that pilots can fuel their own aircraft for non-commercial use. Non-issue after that. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Some FBOs have a policy that prohibits fuel that has been removed from
an aircraft from going into any other aircraft. They'll use the "used" fuel for AGE (ground equipment) but won't pump it back into an airplane for liability reasons (could have become contaminated in the airplane they took it from, perhaps?). I don't know of anything that prohibits a private owner from defueling his part 91 aircraft and refueling it with the properly stored "used" fuel. Common sense requires the fuel to be kept free of contamination and proper safety measures utilized in the refueling process. |
Temporarily removing fuel and replacing it into the same aircraft | B A R R Y[_2_] | Piloting | 39 | August 2nd 07 04:30 AM |
Removing 100LL Fuel Stain | Jeff | Home Built | 7 | September 20th 05 08:45 PM |
FOLO: Replacing fuel cut-off valve with non-a/c part??? | Michael Horowitz | Owning | 10 | February 23rd 05 04:35 AM |
Fuel quality control standards for aircraft rental/fuel sales... | [email protected] | Owning | 19 | January 19th 05 04:12 AM |
Replacing fuel cut-off valve with non-a/c part??? | Michael Horowitz | Owning | 46 | January 15th 05 10:20 PM |
