alt. static.
Old November 2nd 07, 10:55 PM posted to rec.aviation.piloting
Andrew Sarangan
Default alt. static.
On Nov 1, 12:58 am, wrote:
I was preparing to fly a cessna 172SP the other day and as I usually
do I pulled the alt.static expecting a small wiggle in the gauges. And
got nothing. This was the first time I i got no response from the
gauges. I was told by somebody at the front desk this was common and
that many of the 172's show no movement at all. But.. if this is so..
how can I be certain the alt.static would work when I needed it.
Thanks in advance.
I have seen some airplanes show a small wiggle, and some that don't
when the static port is turned on or off. There is no easy way to
positively verify that your alternate static is working. If you are up
to it, you could suck on the static port and ask someone to verify
whether the VSI is showing a climb. Then repeat with the alt static
open. The latter should not show a climb. Or get a suction for this
purpose. Just a thought. I have never done it this way.
Old November 3rd 07, 12:05 AM posted to rec.aviation.piloting
JGalban via AviationKB.com u32749@uwe wrote:
begin speculation
Now it could be that after some serial number Cessna changed something
and the later models don't do that, and that would be OK as long as
I have something at least quasi offical to tell me that.
end speculation
Do you have something quasi official that tells you the VSI must wiggle
when alt static is checked on the ground? If so, then your question would
appear to be answered.
Every CFI I had while a student said to do it and every 172 I've ever
flown does it.
Specifically, at the beginning of the preflight walk around, after
ensuring the master is off, pull the alternate static control out, then
shove it in to make sure it is off; the VSI should wiggle.
That's while standing in the open door.
Seriously, I suspect that the 172 you're talking about probably does have a
static leak into the cabin.
I am not the one that posed the original question nor have I flown a 172
newer than a P model.
If you want to verify that in order to get it
fixed, flipping to the alt static at speed will be most convincing to
maintenance personnel. Another way to check for a cabin static leak is to
open a window (if allowed) in flight. If your VSI, airspeed and altimeter
needles jump, you've got a leak in the cabin.
On the ground, some aircraft do not experience a perceptable indication due
to the location of the exterior static port.
Maybe, but the original poster was talking specifically about a 172.
Jim Pennino
Remove .spam.sux to reply.
Old November 3rd 07, 03:05 PM posted to rec.aviation.piloting
Peter Clark wrote:
begin speculation
end speculation
flown does it.
Same for every 172 and 182 I've flown. Isn't the action of actuating
the flaper in the selector box (or t or whatever it is that it's
moving) creating a little pressure wave which is what makes the
needles move?
That's what I was told and that if the systems working, the needle
bounces one way when opened and the other when closed.
Jim Pennino
Old November 3rd 07, 06:48 PM posted to rec.aviation.piloting
Thanks in advance.
To clarify i have flown - rented - this aircraft a lot and it always
wiggled. The aircraft is a 172SP.
I would not cancel a VFR flight in the area for the lack of
alt.static, but as my CFI said - I asked him this question too - IFR
would be a different story.
Old November 3rd 07, 07:01 PM posted to rec.aviation.piloting
C J Campbell[_1_]
Thanks in advance.
You don't want to, either. I have had avionics guys tell me that this
can damage the instruments.
Waddling Eagle
World Famous Flight Instructor
Static Discharge gman Piloting 12 March 24th 07 07:56 PM
KX-155 static Robert M. Gary Piloting 3 September 13th 06 03:40 AM
KX-155 static Robert M. Gary Owning 4 September 13th 06 03:40 AM
IFR static discharge [email protected] Home Built 0 April 2nd 06 08:06 PM
static wicks keepitrunning Home Built 6 January 1st 06 01:01 AM
