Static Discharge
Old March 23rd 07, 08:48 PM posted to rec.aviation.piloting
gman
Default Static Discharge
Hi Folks,
Here's an interesting phenomenon I observed recently and I was
wondering if anybody else has seen anything like it.
About two weekends ago, I was doing a cross country in actual (IMC)
with one of my Instrument Rating students near Cheyenne, WY. We were
at 11,000ft for a while and the temperature was near freezing but
there was no precipitation in the area. All of a sudden, there was a
sound like a pebble hitting the windshield. I explained to my student
that it was either an isolated hail pebble or ice coming off the
propeller. About ten minutes later, I heard the same sound but this
time it sounded more like an electric discharge similar to the one you
hear when you touch the door knob after walking on the carpet. I
rechecked the fuses and the alternator but everything was working
fine. The sound was definitely coming from the outside. Then about
five minutes later, we heard the same sound. But this time, I was
trying to read the mag compass which is mounted up high on the
windshield. I'm pretty sure that I saw a flash of light this time near
the top center of the windshield where the Plexiglas meets the
aluminum . This made me wonder: When flying in IMC over an extended
geographic area (Cheyenne to West of Denver) is it possible for the
airplane to start discharging by arcing? Has anybody else seen
something similar to this? I should mention that the winds were not
especially fast that day (about 160 @ 30kts).
Old March 23rd 07, 09:46 PM posted to rec.aviation.piloting
Jim Macklin
Most slow airplanes do not have static discharge wicks, but
in the correct conditions, they can build static which can
build to very high voltages. It is also possible that the
grounds [bonding] between components is not good and that
can lead to arcing across hinges and between ailerons and
wing, etc.
Snow and ice crystals cause the build up, the fix is proper
bonding and static wicks, even on a C172.
"gman" wrote in message
| Hi Folks,
was
actual (IMC)
WY. We were
freezing but
there was a
my student
off the
but this
the one you
carpet. I
working
Then about
time, I was
this time near
extended
possible for the
seen
winds were not
Old March 24th 07, 01:28 AM posted to rec.aviation.piloting
BDS
wing, etc.
Bonding and static wicks will not prevent a static charge from building on
an insulator such as the windscreen itself, but they certainly will keep the
entire airframe at the same potential as you mention. In fact,
theoretically you could have a ground plate on one side of the windscreen
and still build a static charge on the other side of the windscreen under
the right conditions. That's the nature of static charges on insulators.
BDS
Old March 24th 07, 03:33 AM posted to rec.aviation.piloting
Jim Macklin
The term is capacitor. Most plastic has an anti-static
coating and plastic airplanes have conductive elements
built-in.
Franklin must have said it, the key to electricity is ,
ouch!
"BDS" wrote in message
but
can
that
and
| wing, etc.
proper
from building on
fact,
the windscreen
windscreen under
on insulators.
| BDS
Old March 24th 07, 04:05 AM posted to rec.aviation.piloting
Morgans[_2_]
built-in.
ouch!
You know, the electricity is not what usually hurts me, though.
It is losing all of the skin off my knuckles, when I get jolted, and
involuntarily try to remove my hand from behind the panel, or from in ...
(insert your favorite location where your hand is when it gets shocked) far
too rapidly!
Same thing goes with being on a ladder and getting shocked. The shock will
not hurt nearly as much as falling off of the ten foot ladder you are
standing on, but it is hard to remember that, at the time it happens! g
Old March 23rd 07, 09:54 PM posted to rec.aviation.piloting
On Mar 23, 2:48 pm, "gman" wrote:
Hi Folks,
In the right atmospheric conditions, insulators like plexiglass can
build up a large static charge as air rushes past it. This is
basically an air-driven Van De Graff generator. The sound you were
hearing was most likely the charge arcing from the plexiglass to the
metal frame as it reached a high enough voltage to break down the air
and arc over.
Old March 24th 07, 03:11 AM posted to rec.aviation.piloting
Morgans[_2_]
toecutter wrote
Hawker 800's have plastic windscreens and a marginal ground path.
Think about cold, dry air at altitude.
They will indeed light you up if you aren't careful. Snap, Crackle and
Pop. BTW, you're usually standing on a stepladder when you get
poked...
You might need to explain that one, a little more.
What are you doing up around a windshield at altitude on a stepladder? g
Old March 24th 07, 04:25 AM posted to rec.aviation.piloting
TheSmokingGnu
poked...
Holding on for dear life!
TheSmokingGnu
Old March 24th 07, 05:41 PM posted to rec.aviation.piloting
Jim Logajan
and Pop. BTW, you're usually standing on a stepladder when you get
poked...
g
He must be one of these people:
http://www.youtube.com/watch?v=wBm8I5JRNlw
IFR static discharge [email protected] Home Built 0 April 2nd 06 08:06 PM
The Vanishing Honorable Discharge Otis Willie Naval Aviation 0 October 29th 04 02:58 AM
