Landing on snow-covered grass
Old November 25th 07, 02:38 PM posted to rec.aviation.piloting
Jay Honeck
Default Landing on snow-covered grass
I must not be visualizing correctly what you are talking about. I was
thinking it was like a J laying on its side with the long leg being the
runway and the short leg being beside the runway (assuming a pretty wide
takeoff area). You start point away from the direction of takeoff and
then make a sweeping turn onto the runway. However, if you do that wide
enough to be at 20 knots when aligned with the runway, you will have a
fairly large radius of turn and I'll bet you lose nearly as much as you
gain.
You're right, if done incorrectly, you don't gain much -- although
even sloppily done, you still gain a bit.
The trick is to maintain your momentum around the "J" turn. You have
to hit the speed fast enough to maintain momentum, but not so fast
that you tip your tricycle over! As someone mentioned, Cherokees
are good for this, thanks to their wide stance. (A Tri-Pacer, for
instance, might not fare as well, with its tall, more closely spaced
gear...)
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 25th 07, 08:00 PM posted to rec.aviation.piloting
Matt Whiting
gain.
gear...)
Ok, got it. Since I fly mainly Cessna airplanes, this may not help as
much. I've found that making a tight turn with my tail as close to the
end of runway as possible and then running to full throttle and RPM
before brake release works quite well, assuming the field isn't soft.
Matt
Old November 25th 07, 09:14 PM posted to rec.aviation.piloting
Dale[_3_]
Matt
Food for thought. That holding the brakes and bringing the power up is
very costly in propellors if you operate from
dirt/grass/gravel/rock/sand/etc.
I much prefer having even 5 knots from a rolling start than any power
added before brake release.
Old November 25th 07, 09:15 PM posted to rec.aviation.piloting
Dale[_3_]
Matt
Hit enter too soon on the other post.
This strip is about 700' long and exactly the width of Cessna main gear.
G
http://home.gci.net/~sncdfalk/flypics/ghshortfinal.jpg
Old November 25th 07, 09:38 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Dale wrote in news:notme-E6348E.12154125112007
@news.gci.net:
Matt
G
Cool.
Bertie
Old November 26th 07, 02:53 AM posted to rec.aviation.piloting
Morgans[_2_]
G
That does meet the definition of a "back country strip", doesn't it.
Thing that jumped out at me was, "and it isn't even straight, when it just
as easily could have been. There must have been alcohol involved when it
got roughed out!"
Old November 26th 07, 03:31 AM posted to rec.aviation.piloting
Matt Whiting
Matt
I've heard this mentioned before, but frankly consider it an urban
legend. I've never seen a prop on a Skylane pick up anything given the
fairly generous prop clearance and I've seen many takeoff on gravel and
grass strips and made many such takeoffs myself with nary a nick.
Matt
Old November 26th 07, 08:10 AM posted to rec.aviation.piloting
Dale[_3_]
Matt
LOL. Now that's funny. I've witnessed props on two occasions suffer
serious damage due to picking up a rock from the surface. Once on a
182, the other a 206.
Old November 26th 07, 08:12 AM posted to rec.aviation.piloting
Dale[_3_]
G
got roughed out!"
The really run part is the big whoop-dee-doo about 2/3 down the strip.
If you have much speed it throws you back into the air.
Old November 26th 07, 03:40 PM posted to rec.aviation.piloting
Jay Honeck
Me, too. In fact, one of the reasons I started "Friends of Iowa City
Airport" was because our taxiway was returning to gravel, and my prop
and stabilator were getting ruined.
We learned to keep the RPMs under 1000, because rocks and pebbles
won't be moved at that speed.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Kiev crewmen waiting next to a tarpaulin covered Yak-36 Dave Kearton Aviation Photos 0 March 2nd 07 06:12 AM
Grass Strips, Landing Technique, etc. Orval Fairbairn Piloting 31 June 20th 06 10:03 PM
FAA Physical covered by health insurance? abripl Piloting 7 August 18th 05 10:03 AM
Snow-covered airplane Andrew Gideon Piloting 11 March 21st 04 06:25 PM
Fabric Covered Dreams Jim Austin Home Built 4 August 13th 03 03:32 PM
