So what do we do with a snow-covered airplane to fly it? The snow pushes
off easily enough, so none of it appears to be stuck ice. Is it enough to push it off with a broom, or should I have the FBO give it some de-ice as well? Silly question, I know, but I've never done this before! Thanks... Andrew |
Andrew Gideon wrote: So what do we do with a snow-covered airplane to fly it? The snow pushes off easily enough, so none of it appears to be stuck ice. Is it enough to push it off with a broom, or should I have the FBO give it some de-ice as well? Push it off with a broom. If you intend to fly into an area of freezing air, also dry the wings off with a rag. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. |
off easily enough, so none of it appears to be stuck ice. Is it enough to push it off with a broom, or should I have the FBO give it some de-ice as well? I trained in a Cherokee 140 that was kept outside, tied down, in Wisconsin, in winter -- so this was a distressingly familiar situation for me. Everything depends on the amount and kind of snow. A light, fluffy snow can be easily brushed off with your gloves, if it's cold enough. If it's started to melt, you might still be okay, as the top layer may have become crusty, but the bottom (against the plane) is still fluffy. This type can also be brushed off. If you get a lot of snow, and it's wet, you've a real chore. Start with a push broom, to get the majority off. (I've even had to use a shovel, if it was completely encrusted -- but you've got to be incredibly careful.) Then I'd go back with a regular broom, to clear out the details. Be especially attentive to seams, hinges, and openings, as blowing snow can get inside them. If it's icy, you can beat the wings of a metal plane with a gloved hand, and the snow/ice will shatter. It can then be swept away. The object is to get the tops and leading edges of the wings and tail surfaces absolutely clear of any snow or ice. You don't have to be quite so picky with the fuselage, but get it as clean as you can. I never used de-icing fluid, mostly because the little airport I was flying at didn't have any. You can eventually remove just about any amount of snow and ice by hand -- it's just an exercise in patience and stamina. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Jay Honeck" wrote in message news:ldl6c.35129$1p.541233@attbi_s54... I never used de-icing fluid, mostly because the little airport I was flying at didn't have any. On frosty mornings I just used a dilute solution of anti-freeze dispensed from a garden sprayer. Doesn't seem to hurt the finish any. |
Andrew,
I'm digging out of the same snow (I'm at N07, I think you're at CDW right?). Jay pretty much covered the basics except for on a high wing a broom is pretty much mandatory (either that or a stepladder, or better yet both). I start with either a soft brush or gloved hands and I DO use deicer to help get some of the ice off. You can get the orange stuff (I think it's called "ice-off") from spruce or wag-aero, something like $20 a gallon. I have two knocks against ice-off: 1) It's orange and quite noticeable. Good when you're applying, but you'll want to wash the plane when it gets a little warmer. 2) It's not a miracle liquid, it relies on thermo as well as chemical properties to help remove ice. That is, for serious ice you'll need to apply it warm. They sell outrageously priced hot applicators if you want to go this route. I didn't, I bought a cheap plastic "fertilizer" applicator from home depot. I'm gradually coming to believe that the ice-off is a waste of money unless you buy the hot applicator. In actual use, I've usually had to resort to one of Jay's methods where you press lightly on the skin to pop the ice off. However, the ice-off works great for frost. Next year, I'm going to just bite the bullet and buy wing covers. Note that I don't have the FBO deice option. If they have a hot applicator and the price is reasonable, you may prefer that route (unless it's just wet snow in relatively warm temps, which is pretty easy to get off). Two last notes: 1) On a low wing, if one side is perpetually in shade (as in my spot), the ice accumulation takes serious effort to remove. This winter in particular a "warm" day would still leave ice encrusted on the wing walk. 2) Pay attention to BOTH sides of the stabilator/elevator as the bottom is the main flying surface (unless you own a canard?). Yes, ice can accumulate there as well. best of luck, mark "Jay Honeck" wrote in message news:ldl6c.35129$1p.541233@attbi_s54... So what do we do with a snow-covered airplane to fly it? The snow pushes off easily enough, so none of it appears to be stuck ice. Is it enough to push it off with a broom, or should I have the FBO give it some de-ice as well? I trained in a Cherokee 140 that was kept outside, tied down, in Wisconsin, in winter -- so this was a distressingly familiar situation for me. Everything depends on the amount and kind of snow. A light, fluffy snow can be easily brushed off with your gloves, if it's cold enough. If it's started to melt, you might still be okay, as the top layer may have become crusty, but the bottom (against the plane) is still fluffy. This type can also be brushed off. If you get a lot of snow, and it's wet, you've a real chore. Start with a push broom, to get the majority off. (I've even had to use a shovel, if it was completely encrusted -- but you've got to be incredibly careful.) Then I'd go back with a regular broom, to clear out the details. Be especially attentive to seams, hinges, and openings, as blowing snow can get inside them. If it's icy, you can beat the wings of a metal plane with a gloved hand, and the snow/ice will shatter. It can then be swept away. The object is to get the tops and leading edges of the wings and tail surfaces absolutely clear of any snow or ice. You don't have to be quite so picky with the fuselage, but get it as clean as you can. I never used de-icing fluid, mostly because the little airport I was flying at didn't have any. You can eventually remove just about any amount of snow and ice by hand -- it's just an exercise in patience and stamina. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Mark Astley wrote:
I'm digging out of the same snow (I'm at N07, I think you're at CDW right?). Jay pretty much covered the basics except for on a high wing a broom is pretty much mandatory (either that or a stepladder, or better yet both). Yes, CDW. Yes, High-wing. I bought a broom on the way out to the airport. It worked well. There was a little piece here or there when I was done with one wing. I did the other wing. When I returned to the first, all the remainder had melted off. No de-ice necessary. [...] 1) On a low wing, if one side is perpetually in shade (as in my spot), the ice accumulation takes serious effort to remove. This winter in particular a "warm" day would still leave ice encrusted on the wing walk. I've seen this on the elevator which is in the shade of the rudder, even on my macho high-wings. So now my club has a broom. Thanks... Andrew |
You might want to try propylene glycol (*not* ethylene glycol) which is sold
as RV antifreeze. It is probably the same stuff as the "ice-off" that Sportys sells (but way cheaper at the auto parts store). Mike MU-2 "Mark Astley" wrote in message ... Andrew, I'm digging out of the same snow (I'm at N07, I think you're at CDW right?). Jay pretty much covered the basics except for on a high wing a broom is pretty much mandatory (either that or a stepladder, or better yet both). I start with either a soft brush or gloved hands and I DO use deicer to help get some of the ice off. You can get the orange stuff (I think it's called "ice-off") from spruce or wag-aero, something like $20 a gallon. I have two knocks against ice-off: 1) It's orange and quite noticeable. Good when you're applying, but you'll want to wash the plane when it gets a little warmer. 2) It's not a miracle liquid, it relies on thermo as well as chemical properties to help remove ice. That is, for serious ice you'll need to apply it warm. They sell outrageously priced hot applicators if you want to go this route. I didn't, I bought a cheap plastic "fertilizer" applicator from home depot. I'm gradually coming to believe that the ice-off is a waste of money unless you buy the hot applicator. In actual use, I've usually had to resort to one of Jay's methods where you press lightly on the skin to pop the ice off. However, the ice-off works great for frost. Next year, I'm going to just bite the bullet and buy wing covers. Note that I don't have the FBO deice option. If they have a hot applicator and the price is reasonable, you may prefer that route (unless it's just wet snow in relatively warm temps, which is pretty easy to get off). Two last notes: 1) On a low wing, if one side is perpetually in shade (as in my spot), the ice accumulation takes serious effort to remove. This winter in particular a "warm" day would still leave ice encrusted on the wing walk. 2) Pay attention to BOTH sides of the stabilator/elevator as the bottom is the main flying surface (unless you own a canard?). Yes, ice can accumulate there as well. best of luck, mark "Jay Honeck" wrote in message news:ldl6c.35129$1p.541233@attbi_s54... So what do we do with a snow-covered airplane to fly it? The snow pushes off easily enough, so none of it appears to be stuck ice. Is it enough to push it off with a broom, or should I have the FBO give it some de-ice as well? I trained in a Cherokee 140 that was kept outside, tied down, in Wisconsin, in winter -- so this was a distressingly familiar situation for me. Everything depends on the amount and kind of snow. A light, fluffy snow can be easily brushed off with your gloves, if it's cold enough. If it's started to melt, you might still be okay, as the top layer may have become crusty, but the bottom (against the plane) is still fluffy. This type can also be brushed off. If you get a lot of snow, and it's wet, you've a real chore. Start with a push broom, to get the majority off. (I've even had to use a shovel, if it was completely encrusted -- but you've got to be incredibly careful.) Then I'd go back with a regular broom, to clear out the details. Be especially attentive to seams, hinges, and openings, as blowing snow can get inside them. If it's icy, you can beat the wings of a metal plane with a gloved hand, and the snow/ice will shatter. It can then be swept away. The object is to get the tops and leading edges of the wings and tail surfaces absolutely clear of any snow or ice. You don't have to be quite so picky with the fuselage, but get it as clean as you can. I never used de-icing fluid, mostly because the little airport I was flying at didn't have any. You can eventually remove just about any amount of snow and ice by hand -- it's just an exercise in patience and stamina. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
If you do choose to deice, make sure you find out how much the FBO charges
for deicing - it can be unbelievably expensive. Michael "Andrew Gideon" wrote in message online.com... So what do we do with a snow-covered airplane to fly it? The snow pushes off easily enough, so none of it appears to be stuck ice. Is it enough to push it off with a broom, or should I have the FBO give it some de-ice as well? Silly question, I know, but I've never done this before! Thanks... Andrew |
"Michael 182" wrote in message
news:djl6c.35143$Cb.556887@attbi_s51... If you do choose to deice, make sure you find out how much the FBO charges for deicing - it can be unbelievably expensive. It's wise to check the price before, of course. But it should be rare to find it's anything other than reasonable. The only story I've heard of with respect to expensive deice was the one posted here, where a tiny airplane received a deluge of deicer, on the scale normally used for business jets and the like. Pete |
So what do we do with a snow-covered airplane to fly it? The snow pushes off easily enough, so none of it appears to be stuck ice. Is it enough to push it off with a broom, or should I have the FBO give it some de-ice as well? At 7B3 Hampton New Hampshire, we used to have a very large squeegee that did a pretty good job of removing snow. I haven't seen it in use for several years, because the planes are always hangared now in winter. I think the squeegee was supplemented with towels. Snow on the aircraft is very serious business, evidently. all the best -- Dan Ford email: (requires authentication) see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
| Thread Tools | |
| Display Modes | |
| Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 03:54 AM |
| The Best Airplane | Veeduber | Home Built | 1 | February 13th 04 06:43 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 3rd 04 12:41 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 10:02 PM |
