#11
If I were the pres and I was making the decision, for obvious reasons,
I wouldn't want to go anywhere without AF-1 being within a Limo rides distance!!!, Including stateside. Pavement??? Most international airports (baghdad included) have cement parking ramps just to avoid that sinking. Your right about parking on a 140 degree asphalt runway though. On Sat, 29 Nov 2003 03:23:00 GMT, "Bjørnar Bolsøy" wrote: "Leadfoot" wrote in news:ZBTxb.15791$o9.3280@fed1read07: Your in charge of flying the president to Baghdad Your choices are a 747 or a C-17. The G5 is out since you have to make a refueling stop which could blow security. Wouldn't it also sink into the pavement on many runways when parked for more than a few hours? Regards... |
![]() "Bjørnar Bolsøy" wrote in message ... "Leadfoot" wrote in news:ZBTxb.15791$o9.3280@fed1read07: Your in charge of flying the president to Baghdad Your choices are a 747 or a C-17. The G5 is out since you have to make a refueling stop which could blow security. Wouldn't it also sink into the pavement on many runways when parked for more than a few hours? G5 is Gulfstream 5. occasionally used by the president. Regards... |
![]() "Ragnar" wrote in message ... "Leadfoot" wrote in message news:ZBTxb.15791$o9.3280@fed1read07... The C-17 will require several aerial refuelings. AF1 may or may not need to refuel in the air. The more tanker crews the more people who know the president is going somewhere. How would the tanker crews "know" who was on the C-17? There's no sign on the tail, is there? Good point, I was a little tired when I wrote it. |
![]() "Gene Storey" wrote in message news:%HTxb.2754$US3.2199@okepread03... 747. AF1 has IR jammers on the engines. The C-17 only has flares, and they wouldn't be good for stealth arrival. R U sure there aren't a couple of C-17's equipped with IR Jammers? Seems like it would be prudent to have a couple or so for spec ops. "Leadfoot" wrote in message news:ZBTxb.15791$o9.3280@fed1read07... Your in charge of flying the president to Baghdad Your choices are a 747 or a C-17. The G5 is out since you have to make a refueling stop which could blow security. Clinton flew to Kosovo in a C-17 Which do you choose and why. Points to ponder. The C-17 will require several aerial refuelings. AF1 may or may not need to refuel in the air. The more tanker crews the more people who know the president is going somewhere. AF1 is a giant Billboard on the ground saying GWB is here. The C-17 is much more discreet |
![]() "Tex Houston" wrote in message ... "Leadfoot" wrote in message news:ZBTxb.15791$o9.3280@fed1read07... Your in charge of flying the president to Baghdad Your choices are a 747 or a C-17. The G5 is out since you have to make a refueling stop which could blow security. Clinton flew to Kosovo in a C-17 How about throwing the E-4B National Airborne Operations Center aircraft into the mix? Don't they have an identical paint job as AF1? Tex |
Since a British pilot spotted AF1, you have a good point about it
being a billboard. It's not a slam dunk decision, but AF1 is more capable as a flying office than some generic C-17. I suspect that may have been part of the decision process. "Leadfoot" wrote in message news:ZBTxb.15791$o9.3280@fed1read07... Your in charge of flying the president to Baghdad Your choices are a 747 or a C-17. The G5 is out since you have to make a refueling stop which could blow security. Clinton flew to Kosovo in a C-17 Which do you choose and why. Points to ponder. The C-17 will require several aerial refuelings. AF1 may or may not need to refuel in the air. The more tanker crews the more people who know the president is going somewhere. AF1 is a giant Billboard on the ground saying GWB is here. The C-17 is much more discreet |
![]() "Leadfoot" wrote in message news:XRYxb.16304$o9.10698@fed1read07... "Gene Storey" wrote in message news:%HTxb.2754$US3.2199@okepread03... 747. AF1 has IR jammers on the engines. The C-17 only has flares, and they wouldn't be good for stealth arrival. R U sure there aren't a couple of C-17's equipped with IR Jammers? Seems like it would be prudent to have a couple or so for spec ops. Not sure how many have it, but they are equipping them with LAIRCM (Large Aircraft IR Countermeasures) which is supposed to be a more powerful (laser based possibly) version of Nemisis. I would think that any C-17 heading into Baghdad would be equipped with such a system. I'm not sure the USAF is keen on throwing a $100 Million plane and it's crew away. |
![]() "miso" wrote in message om... Since a British pilot spotted AF1, you have a good point about it being a billboard. It's not a slam dunk decision, but AF1 is more capable as a flying office than some generic C-17. I suspect that may have been part of the decision process. I'm betting it also has a better suite of countermeasures. The C-17 can take off at a rather steep angle though. |
![]() "Leadfoot" wrote in message news:2TYxb.16305$o9.9528@fed1read07... "Tex Houston" wrote in message ... "Leadfoot" wrote in message news:ZBTxb.15791$o9.3280@fed1read07... Your in charge of flying the president to Baghdad Your choices are a 747 or a C-17. The G5 is out since you have to make a refueling stop which could blow security. Clinton flew to Kosovo in a C-17 How about throwing the E-4B National Airborne Operations Center aircraft into the mix? Don't they have an identical paint job as AF1? I don't think so. The blue and white paint scheme with "United States of America" on the two VC-25s is pretty distinctive. I haven't seen the E-4 for many years however. Tex |
It's not exactly the same, but unless you see both aircraft
side-by-side, you would swear they were the same. KenG Tex Houston wrote: "Leadfoot" wrote in message news:2TYxb.16305$o9.9528@fed1read07... "Tex Houston" wrote in message ... "Leadfoot" wrote in message news:ZBTxb.15791$o9.3280@fed1read07... Your in charge of flying the president to Baghdad Your choices are a 747 or a C-17. The G5 is out since you have to make a refueling stop which could blow security. Clinton flew to Kosovo in a C-17 How about throwing the E-4B National Airborne Operations Center aircraft into the mix? Don't they have an identical paint job as AF1? I don't think so. The blue and white paint scheme with "United States of America" on the two VC-25s is pretty distinctive. I haven't seen the E-4 for many years however. Tex |
Trip to Disney | mickey | Aerobatics | 0 | November 28th 04 04:55 PM |
Juan Jiminez is a liar and a fraud (was: Zoom fables on ANN | ChuckSlusarczyk | Home Built | 105 | October 8th 04 12:38 AM |
Bush's guard record | JDKAHN | Home Built | 13 | October 3rd 04 09:38 PM |
Families of soldiers condemn Bush's war | Mark Test | Military Aviation | 40 | November 16th 03 08:29 AM |
Reflections on first trip to Canada from US | Mike & Janet Larke | Instrument Flight Rules | 1 | August 9th 03 12:57 AM |
