Your in charge of flying the president to Baghdad
Your choices are a 747 or a C-17. The G5 is out since you have to make a refueling stop which could blow security. Clinton flew to Kosovo in a C-17 Which do you choose and why. Points to ponder. The C-17 will require several aerial refuelings. AF1 may or may not need to refuel in the air. The more tanker crews the more people who know the president is going somewhere. AF1 is a giant Billboard on the ground saying GWB is here. The C-17 is much more discreet |
AF1 has IR jammers on the engines. The C-17 only has flares, and they wouldn't be good for stealth arrival. "Leadfoot" wrote in message news:ZBTxb.15791$o9.3280@fed1read07... Your in charge of flying the president to Baghdad Your choices are a 747 or a C-17. The G5 is out since you have to make a refueling stop which could blow security. Clinton flew to Kosovo in a C-17 Which do you choose and why. Points to ponder. The C-17 will require several aerial refuelings. AF1 may or may not need to refuel in the air. The more tanker crews the more people who know the president is going somewhere. AF1 is a giant Billboard on the ground saying GWB is here. The C-17 is much more discreet |
Gene Storey wrote:
747. AF1 has IR jammers on the engines. The C-17 only has flares, and they wouldn't be good for stealth arrival. Can you give me a few clues on this? I don't understand how IR jammers would work. If the radiation is being emitted, then it is being emitted. It's not like swamping a signal with a whole bunch of noise, like radar jammers. IE the radar needs the discrete frequency returns to decode the signal, but IR just needs IR emmissions from a point source and then zeroes in on the point source. Thanks, Nick |
Nick Coleman wrote:
Gene Storey wrote: 747. AF1 has IR jammers on the engines. The C-17 only has flares, and they wouldn't be good for stealth arrival. Can you give me a few clues on this? I don't understand how IR jammers would work. If the radiation is being emitted, then it is being emitted. It's not like swamping a signal with a whole bunch of noise, like radar jammers. IE the radar needs the discrete frequency returns to decode the signal, but IR just needs IR emmissions from a point source and then zeroes in on the point source. Thanks, Nick Most missile guidance systems don't work in quite that manner. They have various algorithms for both aiming the seeker head and determining the validity of the received IR source. IRCM techniques include both fooling the logic of the algorithm as well as overwhelming or blinding the missile's IR sensor itself. Mike |
Nick Coleman wrote in message ...
Gene Storey wrote: 747. AF1 has IR jammers on the engines. The C-17 only has flares, and they wouldn't be good for stealth arrival. Can you give me a few clues on this? I don't understand how IR jammers would work. If the radiation is being emitted, then it is being emitted. It's not like swamping a signal with a whole bunch of noise, like radar jammers. IE the radar needs the discrete frequency returns to decode the signal, but IR just needs IR emmissions from a point source and then zeroes in on the point source. Thanks, Nick See the JUNE/JULY 2003 issue of Air and Space Smithsonian for a description. It has to do with the fact that the missiles use a segmented, spinning disk (sort of like a pie with every other slice removed) to determine which direction the IR source is from. It creates a pulse pattern that the seeker then uses to read direction. An IR jammer sends an alternate pulse pattern that overwhelms the natural pulse pattern that would be created by an airplane in a certain location. The article has some diagrams and pictures that make it much more clear than my word description. It may be at your local library. I tried www.airspacemag.com, but it is not on there. |
Thanks for those replies, that makes sense,
Nick |
"Gene Storey" wrote in message news:%HTxb.2754$US3.2199@okepread03... 747. AF1 has IR jammers on the engines. The C-17 only has flares, and they wouldn't be good for stealth arrival. R U sure there aren't a couple of C-17's equipped with IR Jammers? Seems like it would be prudent to have a couple or so for spec ops. "Leadfoot" wrote in message news:ZBTxb.15791$o9.3280@fed1read07... Your in charge of flying the president to Baghdad Your choices are a 747 or a C-17. The G5 is out since you have to make a refueling stop which could blow security. Clinton flew to Kosovo in a C-17 Which do you choose and why. Points to ponder. The C-17 will require several aerial refuelings. AF1 may or may not need to refuel in the air. The more tanker crews the more people who know the president is going somewhere. AF1 is a giant Billboard on the ground saying GWB is here. The C-17 is much more discreet |
"Leadfoot" wrote in message news:XRYxb.16304$o9.10698@fed1read07... "Gene Storey" wrote in message news:%HTxb.2754$US3.2199@okepread03... 747. AF1 has IR jammers on the engines. The C-17 only has flares, and they wouldn't be good for stealth arrival. R U sure there aren't a couple of C-17's equipped with IR Jammers? Seems like it would be prudent to have a couple or so for spec ops. Not sure how many have it, but they are equipping them with LAIRCM (Large Aircraft IR Countermeasures) which is supposed to be a more powerful (laser based possibly) version of Nemisis. I would think that any C-17 heading into Baghdad would be equipped with such a system. I'm not sure the USAF is keen on throwing a $100 Million plane and it's crew away. |
"Leadfoot" wrote in message news:ZBTxb.15791$o9.3280@fed1read07... Your in charge of flying the president to Baghdad Your choices are a 747 or a C-17. The G5 is out since you have to make a refueling stop which could blow security. Clinton flew to Kosovo in a C-17 How about throwing the E-4B National Airborne Operations Center aircraft into the mix? Tex |
"Tex Houston" wrote
"Leadfoot" wrote Your in charge of flying the president to Baghdad Your choices are a 747 or a C-17. The G5 is out since you have to make a refueling stop which could blow security. Clinton flew to Kosovo in a C-17 How about throwing the E-4B National Airborne Operations Center aircraft into the mix? It spends all of its time off the coast of Langley AFB, and never goes anywhere. |
| Thread Tools | |
| Display Modes | |
| Trip to Disney | mickey | Aerobatics | 0 | November 28th 04 05:55 PM |
| Juan Jiminez is a liar and a fraud (was: Zoom fables on ANN | ChuckSlusarczyk | Home Built | 105 | October 8th 04 01:38 AM |
| Bush's guard record | JDKAHN | Home Built | 13 | October 3rd 04 10:38 PM |
| Families of soldiers condemn Bush's war | Mark Test | Military Aviation | 40 | November 16th 03 09:29 AM |
| Reflections on first trip to Canada from US | Mike & Janet Larke | Instrument Flight Rules | 1 | August 9th 03 01:57 AM |
