Portable Aircraft HF Radio Build (Going to Be Long) Multiple Posts....
Old January 26th 08, 01:58 AM posted to rec.aviation.piloting
NW_Pilot
Default Portable Aircraft HF Radio Build (Going to Be Long) Multiple Posts....
"Larry Dighera" wrote in message
On Fri, 25 Jan 2008 13:02:12 -0800, "NW_Pilot"
wrote in
Here is the cessna 172 Antenna is 3 strands of magnet wire twisted and
inserted in to a yellow heatshrink and 1" red was added about every 2'for
visibility (hurts to walk in to a wire. With my radio set up it will tune
3-5mhz good on as little as 14'
http://www.aircraftdelivery.net/me/HF1ANT.JPG
http://www.aircraftdelivery.net/me/HF2ANT.JPG
http://www.aircraftdelivery.net/me/HF3ANT.JPG
http://www.aircraftdelivery.net/me/HF4ANT.JPG
What method do you use to prevent the trim screws from backing
themselves out? I don't see any safety wire or other obvious means in
the photographs.
This is temporarry install havent herd of them backing out I do use a dab of
locktight
The lead out is high voltage automotive spark plug wire connected to the
antenna.
Of course, that high-tension lead has a copper conductor in it, not
the noise-suppression type with graphite impregnated cotton cord (or
whatever it is), right?
Yes copper plug wire out the fuselage.
Old January 26th 08, 09:09 AM posted to rec.aviation.piloting
NW_Pilot
No time to play today been busy will post more on build in the morning....
"NW_Pilot" wrote
in message . ..
Hello, Usenet, Jay, Marry, Montblack, And Friends!!!
Since Comcast is so lame and Lost the HF thread will start my own.
HF-Box build project, Goal is to simplify next flight T182T to Qatar next
week!!! and return airline flight home with equipment not broken.
Most all you know what I do for a living fun, fun, fun, :-) yep mostly
Single Engine Piston Aircraft Over Oceans it some times requires an HF
Radio!
Well I got tired of always fumbling with HF wiring Special Flight Permit
Allows!! A Power Drop For HF When Tanked!! So I decided to package it all
in to one small portable airline carry on size case case. I used a Pelican
case just incase I may be harassed and asked to check it as I have in the
past (Thanks!! Delta, Virgin, and TSA A-holes)
This Case Will Not Be Water Tight It Requires Drilling Holes!!!! Pelican
Unconditional Warranty Still Applies Leaving Holes To Min. MADE IN USA
WITH GREAT WARRANTY!!!
Supply List,
Pelican 1450 Case About $75.00 Shipped (No Foam)
HF Radio ICOM 706MKIIG 100 Watt $949.00 On Sale Ham Radio Outlet (Remote
Mount Kit Required It's UsuallyFree + a $50 to $100 Rebate) Look Here
http://www.icomamerica.com/amateur/hf/index.html#706
Automatic Antenna Tuner SGC 237 100 Watt (or 239) $359.00
Astron 24 to 12V Converter 20 Amp 24 Peak About $150.00
2 Nice Size Pieces Of Aluminum ($ Varies Mine Was Donated By Horizon Air
Trash Can! Yea, I Dumpster Diving Again!!)
A Bunch Of Mics. Items Don't feel like Listing them All Use Your Brain!!!
(Jacks PL235 1000UF 25V Cap And 10K Resister, 1 or 2 Computer Fans Etc.)
MCM, Norvac, Etc. ($$ Varies)
Tools, Tin Snips Left, Right, Straight, Soldering Iron, Solder, Drill And
Assorted Bits, Rivet's And Rivnuts...Lots of Heat Shrink, Epoxy, Your
Brain, and Harbor Freight If you have a local one!!! (My Case Friends
Snap-On Truck & My Own Good Tool Collection)
You will need Soldering Skills, An Adult Beverage I Like Whiskey, Kitchen
(Aka, Workshop) And AN Understanding Wife!!! For making a Big Mess!!!
This Pelican Case will give you enough Space to Pack The Radio, Long Wire
Antenna, Tools, And Universal Mounting Hardware Cessna, Piper, Grumman,
Etc... Single And Multi All Connections Antenna's. Power, Ground And
Control head will be External Mount Quick Connect.
Photos Will Be Out Of Numerical Order,
The Case, Pelican 1450 Perfect Size About $70.00 No Foam
http://www.internationalferryflights...X/S4010546.JPG
http://www.internationalferryflights...X/S4010544.JPG
Take You Sheet Of Aluminum Cut it To Fit The Bottom Of the Pelican Case.
Don't Cut your Fingers....I did not want to use my CNC mill for this to
much work to clean the Garage to get to the dam thing. Ok, Mount the Radio
Mount To This!!! I Used 1/8" Pop Rivets...
http://www.internationalferryflights...X/S4010541.JPG
http://www.internationalferryflights...X/S4010542.JPG
Verify Fit In Case, Looks Ok!
http://www.internationalferryflights...X/S4010545.JPG
Remove Frome Case and Mount Radio
http://www.internationalferryflights...X/S4010547.JPG
http://www.internationalferryflights...X/S4010548.JPG
Verify Fit In Case, You want About 1/2 Inch for Cable Clearance On Front
Remote Mount Cable.
http://www.internationalferryflights...X/S4010549.JPG
http://www.internationalferryflights...X/S4010550.JPG
Time To Mount The Antenna Tuner, Ok I used scotch bright pads with a right
angel die grinder to remove the paint off the bottom of the SGC-237 (No
Photo) because if you have not guessed it by now we are using the aluminum
sheet as a ground for this project. A good ground with a wire antenna is
key for this set up.
http://www.internationalferryflights...X/S4010552.JPG
Verify Fit In Case, Make Another Adult Beverage!!!
http://www.internationalferryflights...X/S4010553.JPG
http://www.internationalferryflights...X/S4010554.JPG
Find A Spot For Cooling Fan Placement, (I Do Have A Guard For The Fan)
http://www.internationalferryflights...X/S4010555.JPG
Remove Lid Re Clock 180 Degrees Add Auto Tune Cap & Resister To the Inside
Of Tuner At The Terminal Connector.
http://www.internationalferryflights...X/S4010559.JPG
More Inside the SGC237
http://www.internationalferryflights...X/S4010560.JPG
Preview Of Mounting Astron Voltage Converter to lid Of SGC-237 Antenna
Tuner,
http://www.internationalferryflights...X/S4010557.JPG
http://www.internationalferryflights...X/S4010558.JPG
Tomorrow!!! Mounting Voltage Converter, And Selector Switch 14v or 28v
Systems, Adding External Fuse's, Cutting Top Plate, Adding Antenna And
Power Connectors, Airflow Cooling Tests, Etc...
You, Want to use Nylon Screws When Mounting the Astron Voltage Converter
dure to the High Voltage In The Antenna Tuner.
This box is nowhere done I may find problems and Issues along the way and
correct...will post trial and error. I will try and be strait fwd as
possible.. All input will be accepted. Used??
BBL!!!
Photo's Of Diesel 182 Coming Soon Trip to Tanzania is Delayed Due to FAA
B.S. Supplemental Type Cert Update From SMA!!! Oops!!!
OH!! Jay, You Will get To see the Tanzinia Bird, Tanked and all when I
stop by for a night at my favorite hotel..... What room do I wanna stay in
this time? Lets See if I can sleep in them all by 2009 hahaha !!
Old January 27th 08, 03:39 PM posted to rec.aviation.piloting
NW_Pilot
"NW_Pilot" wrote
in message . ..
Radio!
Supply List,
Remote Mount Cable.
Tuner,
Day-2
Drilling the vent holes for fan.
http://internationalferryflights.com...2/S4010563.JPG
http://internationalferryflights.com...2/S4010564.JPG
http://internationalferryflights.com...2/S4010565.JPG
http://internationalferryflights.com...2/S4010566.JPG
http://internationalferryflights.com...2/S4010569.JPG
SGC-237 to 706 Hookup
Manfactures Instructions I did it but put it inside the tunner.
http://www.sgcworld.com/Publications...connecting.pdf
Muine Inside The Tunner,
http://internationalferryflights.com...2/S4010575.JPG
The Molex Connector,
http://internationalferryflights.com...2/S4010578.JPG
Sireing Hooked Up,
http://internationalferryflights.com...2/S4010584.JPG
http://internationalferryflights.com...2/S4010587.JPG
http://internationalferryflights.com...2/S4010588.JPG
Mounting the Astron to the 237, Use Mylon Screws as they is high Voltage,
http://internationalferryflights.com...2/S4010581.JPG
http://internationalferryflights.com...2/S4010582.JPG
http://internationalferryflights.com...2/S4010583.JPG
Astron Mounted to 237,
http://internationalferryflights.com...2/S4010590.JPG
http://internationalferryflights.com...2/S4010591.JPG
706MKIIG Power Line Routing, to Astron
http://internationalferryflights.com...2/S4010594.JPG
http://internationalferryflights.com...2/S4010595.JPG
http://internationalferryflights.com...2/S4010596.JPG
Antenna, Connector, 3 Pin Power Connector, (Will ahve Switch to Select 14V
or 28V System) All protected between hard plastic. plenty of oom to connect
the cables.
http://internationalferryflights.com...2/S4010600.JPG
Inside, decided to go with a thermaltake fan nice and quiet.
http://internationalferryflights.com...2/S4010602.JPG
Inside With Radio,
http://internationalferryflights.com...2/S4010603.JPG
Added And Airframe Ground,
http://internationalferryflights.com...2/S4010604.JPG
1/2' Foam,
http://internationalferryflights.com...2/S4010605.JPG
Radio Fitted with Foam Under Aluminum,
http://internationalferryflights.com...2/S4010607.JPG
Still have some wiring to do for main power and 14 Volt and 24 Volt, Need to
wire an 8pin connector under the power for remote mount control head...
Depending on if the junk store is open or not Monday I should have it done
and ready to test. May have to D sub the Control Head. really want to use a
8pin round connector similar to the power.
BBL...
Old January 27th 08, 06:51 PM posted to rec.aviation.piloting
Larry Dighera
On Sun, 27 Jan 2008 06:39:21 -0800, "NW_Pilot"
wrote in
1/2' Foam
Are you planning on bolting the aluminum base-plate to the Pelican
case, or just letting it float against the foam?
With the fan oriented to exhaust the hot air from the interior of the
case, I can see where two supply-air registers might be cut into the
sides of the case, one on either side near the handle-end. But I have
a feeling you've already considered the cooling issue carefully.
Old January 28th 08, 01:26 AM posted to rec.aviation.piloting
NW_Pilot
wrote in
1/2' Foam
Yea, the aluminum plate will be secured to the case Iwant to wait till i
have all required connectors in before drilling any other holes
Old January 28th 08, 03:59 AM posted to rec.aviation.piloting
Jay Honeck[_2_]
Cool! I'll check the schedule -- we'll see if we can get you in one that
you haven't hit yet....
What day you coming?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 28th 08, 04:18 AM posted to rec.aviation.piloting
Jay Maynard
It's a real shame that the Amana Colonies Renaissance Faire didn't last more
than one year...or else I'd have an excuse to come and stay there.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
http://www.hercules-390.org (Yes, that's me!)
Buy Hercules stuff at http://www.cafepress.com/hercules-390
Old January 28th 08, 12:31 PM posted to rec.aviation.piloting
NW_Pilot
"Jay Maynard" wrote in message
in
more
Renaissance Faire's, Girls in blowsy dresses or skimpy corset gown's with
chainmail, Gypsy Fire Dancing some of them events can be really fun. I have
been to a couple the first one was with a girl I picked up she was hitch
hiking she was a stilt walking human marionette puppeteer - gypsy fire
dancer she was really fun and really enjoyed the "lift" hehehehe.
I still would like to go to the Burrning Man if i ever get the chance...
Old January 28th 08, 11:07 PM posted to rec.aviation.piloting
NW_Pilot
Default Portable Aircraft HF Radio Build (Going to Be Long) MultiplePosts....
NW_Pilot wrote:
"NW_Pilot" wrote
in message . ..
Radio!
Supply List,
Mount Kit Required It's Usually Free + a $50 to $100 Rebate) Look Here
Remove From Case and Mount Radio
Remote Mount Cable.
Tuner,
Day-2
Manufactures Instructions I did it but put it inside the tuner.
Mine Inside The Tuner,
Wiring Hooked Up,
Mounting the Astron to the 237, Use Nylon Screws as they is high Voltage,
Antenna, Connector, 3 Pin Power Connector, (Will Have Switch to Select 14V
or 28V System) All protected between hard plastic. plenty of room to connect
the cables.
Inside With Radio,
1/2' Foam,
BBL...
Called norvac and ordered the rest of the parts today... so it's drive 40 miles
round trip traffic and snow or pay $8.00 for shipping should be here tomorrow.
The $50.00 remote separation cable is an 8 conductor cable so I ordered P700 And
T700 microphone connectors,
http://internationalferryflights.com/HF_BOX/2399.jpg
http://internationalferryflights.com...X/micplugz.jpg
Possible mount under the handle or below the power cable.
Tasks today is the External fan nod to the radio to help with cooling,
Instructions here, http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=10087
Will finish 98% of the wiring for 28V/14v system,
Wire Tune Locked LED to case
Make a fee ground straps.
Clean up kitchen table, prepare for finial assembly & testing.
Wire roof with coper wire and coax for testing, And why dose it have to
snow/rain every time I get on the roof?
Old January 29th 08, 04:39 PM posted to rec.aviation.piloting
gwengler
On Jan 28, 5:07*pm, NW_Pilot
NW_Pilot wrote:
"NW_Pilot" wrote
in messagenews:v_idnYqCWoAcMwTanZ2dnUVZ_tSknZ2d@comca st.com...
Most all you know what I do for a living *fun, fun, fun, *:-) yep mostly
Radio!
Supply List,
Antenna, Tools, *And Universal Mounting Hardware Cessna, Piper, Grumman,
Take You Sheet Of Aluminum Cut it To Fit The Bottom Of the Pelican Case..
Remote Mount Cable.
Tuner,
Day-2
Wiring Hooked Up,
the cables.
Inside With Radio,
1/2' Foam,
BBL...
&http://internationalferryflights.com...X/micplugz.jpg
Instructions here,http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=10087
snow/rain every time I get on the roof?- Hide quoted text -
- Show quoted text -
What do you need the microphone connectors for?
Is there a way to somehow plug the microphone cable/plug of a standard
aviation headset into the transceiver?
Gerd
Portable/handheld radio Danny Deger Piloting 15 February 22nd 07 06:10 PM
Portable Radio Waduino Soaring 12 September 14th 05 07:36 PM
Portable radio scanners Casey Wilson Piloting 1 August 1st 05 03:05 PM
Portable XM Radio receiver in the cockpit? Peter R. Piloting 13 September 4th 04 04:46 AM
FA OLD AIRCRAFT RADIO TRANSMITTER STANDARD RADIO Ron Restoration 0 October 26th 03 01:02 AM
