#11
There are various possibilities but none are likely to be as good as 100LL
and all will be costly. It nonetheless seems like a good time to start thinking about the options in a post 100LL world. It's true that much more ethanol than 100LL is required so even if it's cheaper per gallon, the cost per engine hour is likely to be nearly the same - maybe even higher. I really don't think ethanol is a workable solution for those who want to fly their airplanes cross country. That probably means AGE85 fuel pumps will be rare so if you want to take your tug to an encampment, you may have to bring along your own fuel supply. As for carburetors and ethanol, there seems to be some disagreement. The AGE85 (Aviation Grade Ethanol 85% See: http://www.age85.org/ ) people say that carburetors at full rich provide a stochimetric fuel/air ratio at sea level and that's good enough. Other's say that the old Marvel Schrieber carburetors can't work with ethanol due to the fuel passages being too small for the additional 40% fuel flow that ethanol requires. It makes me nervious to think of being lean of peak EGT for a sea level takeoff so I tend to agree with the detractors. Still, it might work for operation at high altitudes. Fuel injection is easier since there are fewer elastomer seals in the system and you only need to select injectors with 40% greater fuel flow. As for MOGAS, any STC will specify exactly what fuel is allowed but the stuff at the nearest pump is not likely to match the STC. Every state and locality seems to have laws specifying a different fuel blend. That makes MOGAS problematic. Higher compression ratios are allowed with ethanol since it has an octane equivalent of about 115 - 145. Higher compression + some ignition advance recovers some of the fuel economy lost to the lower energy content. Bill D "BT" wrote in message ... Bill.. our STC to bump the O-540 from 235HP to 250HP with a piston change negates the autofuel STC.. 100LL required. That STC would also need to be reworked or the STC to allow the IO-540 to use Ethanol would need to include the option for higher HP. Current auto engines that are "flex" fuel can burn regular auto low lead or E-85 fuels. The E-85 fuel is cheaper than standard fuel, but the resulting mpg is lower, the E-85 is less efficient and your total dollars spent to complete the same work (travel the same distance) is higher with more fuel stops. BT "Bill Daniels" bildan@comcast-dot-net wrote in message ... "Mike Schumann" wrote in message .. . I can't imagine that happening. Until there is a replacement for 100LL, with the number of aircraft flying in the US, there will be a supply from somewhere. The big question will be the cost. Mike Schumann The volume of fuel consumed by the US piston fleet is miniscule - less than 1% of all gasoline production and thus doesn't even appear on the radar of fuel producers. I think the idea that "supply will meet demand" is a risky one. As far as they are concerned, anything less than 1% is no demand at all. The liabilities involved in handling TEL far outweigh potential profits. I think we are in the last stages of an economic "death spiral" for AVGAS. High prices mean lower demand. Lower demand means higher price per gallon since fixed overhead is spread over fewer gallons. Still higher prices further reduces demand. In effect, it's "economies of scale" working in reverse. However, there may be hope. See: http://www3.baylor.edu/bias/publicat...ayaircraft.pdf This paper describes obtaining an STC for operating a Pawnee on ethanol. Note that the engine described is the fuel injected Lycoming IO-540 and not the more common carburated O-540. Nonetheless, given enough money, it's possible to convert a O-540 to fuel injection since the injector bosses are cast into the cylinder heads - one need only drill them for injectors. Converting a fuel injected engine to ethanol is relatively easy. The modifications required to use ethanol with a carburator are not really feasable. Note the large increase in fuel consumption - ~40%. This probably eliminates ethanol as a fuel for long range cross country airplanes but for "fixed point" operators like crop dusters and glider towing operations, it's a PITA but workable. The total modifications required would be to convert the O-540 to fuel injection using injectors suitable for ethanol and, since the cylinders have to be removed anyway, it would be desirable to replace the pistons to achieve a higher compression ratio. If it were desired to keep refueling stops to the same intervals as with AVGAS, larger tanks would be needed. The downside is that the conversion will be costly. The upside is that we maintain the availability of aero tows, we get more performance from the Pawnee and, possibly, greater engine life due to cooler running cylinders. Bill Daniels "Bill Daniels" bildan@comcast-dot-net wrote in message . .. "Dave Newill" wrote in message ... On Mar 4, 12:32 am, "Mike Schumann" mike-nos...@traditions- nospam.com wrote: They will keep making TEL untill it is no longer profitable. I visited GAMA headquarters to understand the situation on AvGAs from their expert. He said that the tanker (ship) that carries the TEL will be decommissioned in a few years - that will not stop it from being shipped from its source (Russia) as it will simply be put into triple walled sea-tainers - but the amount shipped each time will be smaller and the insurance - as it is being shipped with other goods - will be higher. It will not go away - but it will be very expensive -however there is so little of it in the fuel that it thankfully does not take much. Also note that it is not shipped by pipeline - must be shipped by truck so as not to pollute the pipes! Finally, there is a Friends of the Earth petition getting hearing in congress to remove lead from all fuels - if you think we have problems - think about all those outboard motors out there! The only producer of TEL is the Octane Additives Division of Innospec (formerly Octel) - A UK based company. I believe, but can't find referencable sources, that the actual TEL production is at a plant near Madras, India. I have found no references to Russian production. From reading press releases in financial publications, it appears that revenue and profitability of the OA division is in a steep decline (50%/year). The parent company is loading accounting charges onto the Octane Additives Division in the form of "Goodwill Impairments". They are also making statements to the effect that the future business of the division will be "environmental remediation activities". The company is now accepting bids in India for the dismantling and desposal of the worlds only TEL tanker ship. This looks like an imminent shutdown of TEL production. I did find a comment that there is a six months supply of TEL in the US. It appears to a casual reader that the end for TEL may indeed very near. Bill D -- Posted via a free Usenet account from http://www.teranews.com |
Cont. A-40 or A-50? | [email protected][_2_] | Piloting | 5 | August 14th 07 03:06 AM |
E-185-225 Cont. | jerry wass | Home Built | 0 | September 3rd 05 05:37 AM |
Detonation in a Cont. 550 | [email protected] | Home Built | 3 | August 28th 04 04:33 AM |
Detonation in a Cont. 550 | Corky Scott | Piloting | 2 | August 28th 04 04:33 AM |
Detonation in a Cont. 550 | [email protected] | Piloting | 0 | August 26th 04 12:45 PM |
