#11
"BT" wrote:
Technology is coming for the small transponder, along with ATS-B. Why would I put a 50# $15K ATS-B system in a $15K glider. I suspect that you mean "ADS-B Out" Reference: http://tinyurl.com/33k9m2 You will see responses from me. I am adamantly against it. Ron Lee |
Larry.. it's been a few years since I've been on the ATC side of the radar..
but "we" had to monitor "primary" returns when working low altitude sectors, Below FL180. I've listened in on the local TRACON ATC frequency when flying in the "airline approach area" and yes, they are issuing "traffic, altitude unknown, could be a glider", and I did not call them first to give them a heads up. This has been in Grob 103s and LS-4, fiberglass with metal pushrod controls. Becker Transponders are very popular with glider pilots, I missed on the price.. it's closer to $1900 plus antenna and install. http://www.beckerusa.com/products/de...php?search=557 B "Larry Dighera" wrote in message ... On Sun, 27 Apr 2008 21:27:54 -0700, "BT" wrote in : Larry.. DO you fly gliders? Not in several years. From these statements it would appear that you do not. Gliders may or may not have electrical systems, they do not "generate power", but stored battery power of a limited life span. Gliders are small, batteries are small, everything needs to be small. None of the gliders I have flown have had electrical systems, small or otherwise. NTSB "recommends", FAA cannot mandate without a comment period and a change to many CFRs. True, but I'm thinking that it is in our best interest to provide some guidance to the FAA before they draft their NPRM; hopefully proactive will be better than reactive. Technology is coming for the small transponder, along with ATS-B. Are you able to provide any specific information about that technology? Why would I put a 50# $15K ATS-B system in a $15K glider. Of course, it's worse than that. There would need to be antennas, cabling, batteries, switches, circuit breakers, ammeter, ... It wouldn't be very cost effective to equip gliders used for training with all that, not to mention the resulting degraded flight performance and maintenance requirements. Small transponders now are about $1300 plus antenna and installation. It can be done. Can you provide more specific information about them? My issue is not with TCAS equipped aircraft, but with smaller GA aircraft that do not have TCAS, do not have a Garmin 430 with TIS (or equivalent) and are not talking to ATC. It does no good to have a transponder, when the aircraft causing the traffic conflict is not talking to anyone. Just sitting there FDH and not even paying attention in the traffic pattern. I'm not sure if there is a solution to that issue short of having a control tower at _all_ fields. Have you got any ideas? Last Saturday we had at least 4 transient aircraft attempt to land at the airport with 15 to 20 knot tail winds, and against the flow of traffic. While not very smart, it's not a violation of regulations, is it? They could not even listen up to the radio to figure out the runway in use, or even look at a wind sock or a huge flag and see the 15knt winds and make up their own mind about the landing runway. I find the level of competence, diligence, and responsibility of some airmen to be disappointing, and it's not just the "hobby" pilots. One wonders how they manage to pass their biennial flight reviews. What makes you think a transponder in a glider would make any difference. |
![]() "Larry Dighera" wrote in message ... So if you see a glider in you path while piloting a powered aircraft, but its pilot doesn't see you, you don't give it the right of way? So if you see a powered aircraft in you path while piloting a glider, but its pilot doesn't see you, do you expect it to yield the right-of-way? |
Feds Want to Equipe Gliders With Transponders and Radios | Larry Dighera | Piloting | 155 | May 10th 08 02:45 PM |
Gliders, transponders, and MOAs | Greg Arnold | Soaring | 2 | May 26th 06 05:13 PM |
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* | JStONGE123 | Military Aviation | 1 | May 11th 04 06:22 AM |
Transponders and Radios - USA | Ray Lovinggood | Soaring | 1 | February 27th 04 06:10 PM |
Transponders, Radios and other avionics procurement questions | Corky Scott | Home Built | 5 | July 2nd 03 11:27 PM |
