Newps wrote:
To make matters worser, I can't build one so I have to take someone else's work. ![]() the design. plus, you get to install a rotary-Wankel; this is good? How can a Wankel be good? Terrible fuel economy. A turbocharged rotary engine runs about 0.50- 0.55 Lbs/hp/hr BSFC A normally aspirated rotary engine runs about 0.45-0.50 lbs/hp/hr BSFC An air cooled lycoming runs 0.40-0.45 lbs/hp/hr BSFC when run LEAN OF PEAK. The rotary can use auto gas (including ethanol as an oxygenate) as well as the blue 100LL. The lycoming for the most part can only use 100LL, unless in experimental, or you can guarantee the mogas is alcohol free. The rotary is SLIGHTLY less fuel efficient than a normally aspirated lycoming engine when the lyc is tuned properly and run LOP. Being able to use car gas in a rotary obliterates any cost penalty on that marginal fuel economy issue. Cost per mile is cheaper in the rotary. And it can be rebuilt for less than the cost of ONE new lycoming jug, or replaced for the cost of 3 new jugs. Do the math yourself and you will see. Not so terrible now, is it? Dave |
![]() "Dave S" wrote The rotary is SLIGHTLY less fuel efficient than a normally aspirated lycoming engine when the lyc is tuned properly and run LOP. Being able to use car gas in a rotary obliterates any cost penalty on that marginal fuel economy issue. Cost per mile is cheaper in the rotary. And it can be rebuilt for less than the cost of ONE new lycoming jug, or replaced for the cost of 3 new jugs. Do the math yourself and you will see. Not so terrible now, is it? Not so bad, if you can figure out how to keep the oil and water cool enough, and keep the exhaust pipes from melting, and radiating all of the heat to the cowling. (which if it fiberglass, will tend to make it get soft as play-dough) Hint: almost all of the lost fuel economy is lost in the form of lots of heat radiating from the engine, mainly the exhaust gasses. -- Jim in NC |
test, can't seem to post as get error from Google
On May 3, 9:35 am, Linton Yarbrough wrote: I don't get the reason for the Cozy or the Velocity (which isn't selling anyway) from the standpoint of speed, comfort, etc. The $$$ come out the same for the most part and you don't have composite issues or trouble getting things fixed. Pusher/tractor preferences aside, am I missing something that would or does make one of the canards a better purchase? |
The group you are posting to is a Usenet group. Messages posted to
this group will make your email address visible to anyone on the Internet. We were unable to post your message If you believe this is an error, please contact Google Support. On May 12, 6:12 am, jsbougher wrote: test, can't seem to post as get error from Google On May 3, 9:35 am, Linton Yarbrough wrote: I don't get the reason for the Cozy or the Velocity (which isn't selling anyway) from the standpoint of speed, comfort, etc. The $$$ come out the same for the most part and you don't have composite issues or trouble getting things fixed. Pusher/tractor preferences aside, am I missing something that would or does make one of the canards a better purchase? |
Comments from a Velocity owner and aeronautical engineer who also
didn't have time to build, so bought instead. Additional comment is that my Dad has a Mooney 201 that I've flown quite a bit so I think I'm fairly well placed to at least comment on your question. For me, there were a few big drivers for the Velocity. 1) Stall characteristics - I can pull the throttle, slow to stall speed, roll into a 45 degree bank and pull the stick to my stomach and nothing happens. I know this isn't an issue for "good" pilots, but the records are littered with stall/spins. I'm human and make mistakes. Whether rational or not, the stall/spin is one of my biggest fears. 2) Maintenance / avionics - with a homebuilt, I can do everything myself outside of the "annual". This has helped with the nuisance issues, but I still use the local A&P for a lot of work. Additionally, I have access to cutting edge development that is too expensive or simply not available to certified aircraft. Example is my Trutrak 2 axis autopilot / ADI. I absolutely love it and my Dad can't put it in his Mooney without a LOT of effort if at all. 3) Factory support / aircraft complexity - factory support may not be as good as Mooney, but in the experimental world the ability to get factory check out and factory annual is a big deal. Also note that the Velocity can perform extremely well as a VERY simple airplane. My plane is fixed prop, fixed gear and keeps us with a 201. My plane is more basic from a maintenance perspective than a Cessna 172 and was it a simple transition from that plane. 4) Useful load - I can put myself, my wife, both kids, the dog and a weekends worth of luggage into it and still easily cover 300-400 miles. Jeff |
On Mon, 12 May 2008 06:18:20 -0700 (PDT), jsbougher wrote:
For me, there were a few big drivers for the Velocity. 1) Stall characteristics - I can pull the throttle, slow to stall speed, roll into a 45 degree bank and pull the stick to my stomach and nothing happens. I know this isn't an issue for "good" pilots, but the records are littered with stall/spins. I'm human and make mistakes. Whether rational or not, the stall/spin is one of my biggest fears. Fair statement. 2) Maintenance / avionics - with a homebuilt, I can do everything myself outside of the "annual". This has helped with the nuisance issues, but I still use the local A&P for a lot of work. Additionally, I have access to cutting edge development that is too expensive or simply not available to certified aircraft. Example is my Trutrak 2 axis autopilot / ADI. I absolutely love it and my Dad can't put it in his Mooney without a LOT of effort if at all. Hadn't thought of this one. 3) Factory support / aircraft complexity - factory support may not be as good as Mooney, but in the experimental world the ability to get factory check out and factory annual is a big deal. Also note that the Velocity can perform extremely well as a VERY simple airplane. My plane is fixed prop, fixed gear and keeps us with a 201. My plane is more basic from a maintenance perspective than a Cessna 172 and was it a simple transition from that plane. 4) Useful load - I can put myself, my wife, both kids, the dog and a weekends worth of luggage into it and still easily cover 300-400 miles. Jeff All of these work for me except the dog. I'm married to one, Sweet Vicki. Don't need another ![]() |
Google sucks and won't let me post remainder of story. If you're
interested, let me know and I can e-mail. |
jsbougher wrote:
Google sucks and won't let me post remainder of story. If you're interested, let me know and I can e-mail. It let you post 4 times in 10 minutes. |
On May 12, 7:25 am, Gig 601Xl Builder
wrote: jsbougher wrote: Google sucks and won't let me post remainder of story. If you're interested, let me know and I can e-mail. It let you post 4 times in 10 minutes. Yup, and not a single one is what I had in the message window. |
Canard or Mooney | Linton Yarbrough | Piloting | 18 | May 21st 08 09:54 PM |
Aircraft ID? canard biz plane | Ron Hardin | General Aviation | 5 | October 1st 06 09:55 PM |
Canard Rotor/Wing | Eric Moore | Military Aviation | 0 | December 14th 03 04:39 AM |
Dumb Canard Question. | Russell Kent | Home Built | 39 | October 19th 03 03:25 PM |
Question - Regarding Canard Pushers... | Tilt | Home Built | 33 | August 10th 03 11:07 AM |
