control cable questions
Old May 8th 08, 12:00 PM posted to rec.aviation.homebuilt
Dick[_1_]
Default control cable questions
possibly but last time I tried a few years ago but still fat G, my taped
connection came loose. now that I just wrote that maybe an electrical wire
butt splice would work. thanks for stimulation.
"Jay Maynard" wrote in message
On 2008-05-07, Dick wrote:
agreed, no hiding strands. however with all three of us big, heavy, stiff
guys, we can't get inside the fuselage G
Can you use the old cable as a fish tape to pull the new cable through?
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
Old May 8th 08, 12:45 PM posted to rec.aviation.homebuilt
Dick[_1_]
thanks,would appreciate it. Are your cables 1/8"?
Old May 8th 08, 02:14 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Trimmed a little tight on that one but the threading looks like your are
talking to me so yes, they are 1/8".
Old May 8th 08, 02:27 PM posted to rec.aviation.homebuilt
Dick[_1_]
g. just the start of one of those days where I can't get anything right .
Here's probably a better reference.
I don't have my plans here at the office they are at the airport but I
THINK. It is an AN115-21 cable shackle. If someone else doesn't pop up with
the answer shortly I can find out for you.
Old May 8th 08, 05:10 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Dick, I just checked and surprisingly my memory was correct, it is
AN115-21 shackles.
There is a picture of this connection here.
http://peoamerica.net/N601WR/html/fuselage_1_180.html
Old May 8th 08, 06:21 PM posted to rec.aviation.homebuilt
Dick[_1_]
Thanks, good picture. My buddy is going to add brake lines from the Matco
units and a remote firewall mounted brake fluid reservoir.
"Gig 601Xl Builder" wrote in message
m...
with the answer shortly I can find out for you.
AN115-21 shackles.
Old May 8th 08, 08:06 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
I decided the guy in the right seat didn't need brakes because I didn't
want to go to the hassle of a dual set up. I am going to add a parking
brake though.
Old May 8th 08, 09:56 PM posted to rec.aviation.homebuilt
Dick[_1_]
Default control cable questions now brakes
He also decided not to have right seat brakes but I was wondering what you
thought of the brake master reservoir on the firewall idea (so he doesn't
have to crawl inside and under the panel)?
Also what kind of parking brake are you thinking about?
Thanks
"Gig 601Xl Builder" I am going to add a parking brake though.
Old May 8th 08, 10:40 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Thanks
If you are talking about putting the brake master reservoir on the
engine side of the firewall, I don't like the idea. First, you have the
additional hole in the firewall, then you have the heat issue.
If you are talking about putting the reservoir on the inside of the
firewall I don't see what is gained.
Old May 9th 08, 12:39 AM posted to rec.aviation.homebuilt
Dick[_1_]
Default now brakes
Respectfully, I'm not sure that heat is a problem: as long as the
reservoir is mounted away from exhaust pipes and oil cooler discharge, and
if necessary, could do some shielding like for gascolators or air duct like
those directed on magnetos.
I'd like to hear where others have a master reservoir located....
He has a removable top cowl skin between the firewall and instrument panel
for access to fuel tank and back of panel. Having the same removable skin on
my 601, it is easier to access my Matco rudder mounted brake units thru a
floor access panel. Each annual when I check the fluid level at the pedal
units and still pull the top skin to check instrument connections, hoses,
wiring, filters, I think how nice it would be to have an easily accessible
remote master reservoirG, hence the firewall aft side thought .
control cable protection question Dick[_1_] Home Built 11 March 13th 08 11:31 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat Home Built 6 October 15th 04 08:51 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 05:11 PM
You Want Control? You Can't Handle Control! -- Was 140 dead ArtKramr Military Aviation 0 March 2nd 04 08:48 PM
Mig-29 questions & general aviation questions 2003 Steven Military Aviation 1 October 20th 03 06:06 AM
