Hypothetical AC-130 replacement
Old February 12th 04, 05:49 AM
George
"Harley W. Daugherty" wrote in message k.net...
"Chad Irby" wrote in message
om...
In article 402a7579$1@bg2., "Matt Wiser"
If you had been given the task of choosing the plaform for a
next-generation
gunship, would the C-130J be the platform base, or would an as yet
unbuilt
A400M be chosen? I'd take an AC-130 based on the J, but use the
stretched
J, with two instead of one 25mms, one 40mm, and the 105. Add single rail
launchers underwing for Hellfire.
We've already had the AC-5 suggested...
sweet Jesus..................... What kinda loadout you put on that
monstrosity?
I'd prefer a AC-17 variant....
Harley W. Daugherty
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
C-17 has 3x the max takeoff weight of a AC-130, C-5 5x. Even with
structural strengthening, that is a lot of leftover weight to play
with. However, not a chance in hell are C-5s getting used as gunships.
If anyone is an AFA member, read last month's magazine. The Air Force
is doing everything it can to keep the cargo C-5s hauling as much as
possible, and with little or no prospect of new construction of them,
they aren't going to divert airframes from Air Mobility Command to
Spec Ops. The C-17 is still in production, so that is another story. A
C-17's MTW is around 500000 lbs versus about 150000 lbs for an AC-130.
Even with the weight to strenghten the airframe, that is a lot of
volume and lift to use for guns, ammo, sensors, jammers, missiles
etc...
Old February 12th 04, 06:49 AM
John Keeney
. com...
om...
monstrosity?
Everything.
Just... everything.
Yea, if not some 8" cannon with Copperhead I understand there's
still some 16" guns in depot. Probably not have more than one of
either and the 16 would have to fire straight ahead. Think of it like
the B-25G but with the 16" replacing the 75mm.
Possibly an airborne reloadable rotary launcher for MLRS rounds;
if we have spare development cash at the end a special version with
3/4s of the propellant traded for more HE.
A couple of Phalanx systems for self defense. Or, again, if the
development budget is big enough an adaptation of THEL for the job.
Could give THEL the role of defending troops in contact from
mortar rounds too. Hmm, come to think of it, THEL would make
a nice "danger close" antipersonnel weapon too.
Ah heck, let's just stuff the thing full of THEL, COIL and/or the
solid state systems that are about ready and go pure directed
energy. We'll call it the "Death Star", er, make that the "Death Galaxy".
Old February 12th 04, 12:37 PM
Les Matheson
Well that's what I was told as to why the USAF is only buying the regular
one and the Brits aren't buying them for their Spec Ops squadrons. Like
you, I thought the stretch J was a great upgrade for the Combat Talon, but
when I proposed it as an option (in the late '90s ) that was the answer I
got from some pretty high up in AFSOC.
Les
"Kevin Brooks" wrote in message
"Les Matheson" wrote in message
news:iOyWb.3630$Yj.3407@lakeread02...
Stretched J model is a problem, as you can't do assault landings with
it,
and I'm sure some minimum field length issues will be in the specs.
Are you sure about that? According to LMCO, the USAF was conducting tests
with the CC-130J back in late 2002 to certify it for assault landing use.
www.lmaeronautics.com/lmaerostar/ pdfs/year02/sep_02.pdf
Brooks
Les
F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret)
"Matt Wiser" wrote in message
news:402a7579$1@bg2....
next-generation
unbuilt
stretched
rail
Posted via www.My-Newsgroups.com - web to news gateway for usenet
access!
Old February 12th 04, 02:17 PM
Kevin Brooks
news:hsKWb.3680$Yj.1623@lakeread02...
Things have changed. The USAF is indeed buying the stretched CC-130J--IIRC
the first ones went to the Rhode Island ANG. I doubt they would be buying
them if they could not perform assault landings.
Brooks
Les
it,
tests
use.
Brooks
Les
next-generation
unbuilt
stretched
rail
access!
Old February 12th 04, 10:52 PM
Les Matheson
I doubt they do assault landings like Spec Ops 130s do assault landings.
I've broken teeth.
Les
regular
but
I
Brooks
Les
with
it,
tests
use.
Brooks
Les
next-generation
unbuilt
stretched
single
rail
access!
Old February 13th 04, 12:33 AM
Thomas Schoene
landings. I've broken teeth.
I'm somewhat confused. Why would the AC-130 replacement *need* to do
assault landings. An MC-130 replacementr, sure, but the AC should be
orbiting somewhere, not landing, if I understand their roles properly.
Tom Schoene Replace "invalid" with "net" to e-mail
"If brave men and women never died, there would be nothing
special about bravery." -- Andy Rooney (attributed)
Old February 13th 04, 03:30 AM
Les Matheson
Because they are going to use the same airframe, I'm pretty sure of that.
Les
"Thomas Schoene" wrote in message
ink.net...
Old February 13th 04, 06:04 AM
Steve R.
news:nxXWb.4716$Yj.2563@lakeread02...
Les
ink.net...
Baltimore was the first US unit to get the 130J but they were shorties. So
are Keesler's I believe. Rhode Islands and ours are stretches, and as far as
we've been told all the new J's will be stretches. There was talk of sending
the shorties back to be stretched. We were doing assault landings with a
stretch out in the desert by Yuma back in the fall of 2002. As far as I know
it all came out good.
Steve R.
Old February 13th 04, 12:44 PM
Les Matheson
I guess that is good news, but is contradictory to what I was told. Maybe
they did something to the frame.
Les
"Steve R." wrote in message
news
that.
Les
ink.net...
as
sending
know
Steve R.
Old February 14th 04, 03:30 AM
Harley W. Daugherty
"George" wrote in message
m...
k.net...
om...
next-generation
unbuilt
stretched
rail
monstrosity?
Harley W. Daugherty
cirby at cfl.rr.com
etc...
So a AC-17 is a serious possibility!?
THEL. hmmm, any one got a mass/Weight break down on that? It would make a
intrewsing add on.
Harley
AC-130 Replacement Contemplated sid Military Aviation 29 February 10th 04 10:15 PM
Magneto/comm interference on TKM MX-R Narco 120 replacement Eugene Wendland Home Built 5 January 13th 04 02:17 PM
Canada to order replacement for the Sea King Ed Majden Military Aviation 3 December 18th 03 07:02 PM
Replacement for C130? John Penta Military Aviation 24 September 29th 03 07:11 PM
Hellfire Replacement Eric Moore Military Aviation 6 July 2nd 03 02:22 AM
