AC-130 Replacement Contemplated
Old February 7th 04, 01:43 AM
sid
Default AC-130 Replacement Contemplated
After having been excoriated for saying that civil designs such as
those envisioned for the MC2A and ACS have no business over the
battlefield, this article gives me a bit of gratification:
USAF Plans Serious Look At Replacing Special Ops Aircraft
By Marc Selinger
February 6, 2004
The U.S. Air Force plans to start taking a serious look at potential
replacements for several C-130 variants used by its special operations
forces, a service representative said Feb. 5.
Maj. Gen. John Dorris said the Bush Administration's fiscal 2005
budget request, submitted to Congress Feb. 2, contains "seed money" to
develop concepts for an "MX" aircraft, which would replace the
MC-130E/H airdrop/transport aircraft, and an "AX" which would replace
the AC-130 gunship. The analysis could take about two years.
With surface-to-air threats becoming increasingly sophisticated, the
Air Force Special Operations Command (AFSOC) believes it will need to
begin fielding the new aircraft in about 2015 as a replacement for its
aging Lockheed Martin C-130 variants, Dorris said. He spoke to
reporters after speaking at a special operations conference sponsored
by the National Defense Industrial Association (NDIA).
"After 2015, the ability of the C-130 as it's currently configured,
even with enhancements, is not going to be able to go into a lot of
the airspace that it needs to go into," he said.
The MX is envisioned as a long-range aircraft that is "able to do the
mission in one period of darkness," Dorris said. The latest thinking
for the AX is that it would be a "mothership that sends out sensors."
The sensors would then report back to the mothership, which would send
out "lethal and/or non-lethal projectiles," possibly small, guided
missiles.
A new aerial refueling capability will also be needed by AFSOC but
probably later than 2015, Dorris said.
To address AFSOC's tanker shortfall in the interim, about 27 MC-130H
Combat Talon IIs are being modified to be capable of refueling. That
work will be completed by about 2007. AFSOC's MC-130E Combat Talon Is
already can perform the tanker mission.
Old February 7th 04, 04:15 AM
Kevin Brooks
"sid" wrote in message
m...
There is quite a gulf between the kind of "battlefield" (or more
specifically "battle environment") that the special operations aircraft have
to operate in and that which the E-10 will be expected to survive. So I am
not really sure what your point here is...?
Brooks
By Marc Selinger
February 6, 2004
snip
Old February 7th 04, 09:19 PM
sid
"Kevin Brooks" wrote in message ...
m...
Brooks
Not nearly as big a gulf as you characterize. ISR assets are now
enmeshed in tactical operations. The days of these aircraft standing
off in benign airspace a la Cold War style are over:
http://www.lexingtoninstitute.org/defense/111803ISR.pdf
• Without early air dominance, many ISR systems could not
have been used to optimal effect.
– Vulnerable manned aircraft like JSTARS & EP-3 operated deep
in Iraqi airspace
– Aerial refueling tankers penetrated to support ISR
– Unmanned vehicles nearly defenseless if attacked
To illustrate further, here are some comments on the expected use the
of the ACS:
http://www.defensenews.com/conferenc...3/2409450.html
....As one of the first systems to the fight, ACS will provide early
intelligence that could help shape the first stages of battle,[LtCol]
Hinsdale said Nov. 18 during a Defense News Media Group conference,
ISR Integration 2003: The Net-Centric Vision, in Arlington, Va.
For instance, it could warn forces if their port of entry has been
compromised "before we put our sons and daughters in harm's way." ...
Since the ACS will be "one of the first systems to the fight" its
axiomatic that air dominance may not be assured when the ACS "arrives
to the fight".
As I mentioned in previous posts, the aircraft in question make fine
civil transports, but shoot at them and you have death traps. They are
designed to withstand component failure;not damage.
Their electrical, avionics, and fuel systems in particular are
exceptionally vulnerable to even slight damage. In order to hold down
costs, these vulenrabilities are not being addressed as they get
shoehorned into military applications. These ain't your granddaddy's
C-135.
Later attempts to back engineer vulnerability improvements into former
transports have proven less than sucessful and expensive. The P-3
comes to mind.
So development of ths AX or whatever may prove a good thing. Also
Boeing and the other civil transport manufacturers now have a viable
commercial reason to harden their aircraft due to the MANPADS threat.
Old February 7th 04, 10:04 PM
Kevin Brooks
om...
m...
have
am
Brooks
Yes, but again, their exposure is an order of magnitude less than that
experienced by MC-130's and AC-130's.
SOF platforms like the Combat Talon and Spectre operate in airspace that is
much more dangerous than that experienced by the E-8 or ARL-M's.
. Without early air dominance, many ISR systems could not
Combat Talons operate in an environment that does not require "air
dominance". The AC-130's have to operate down within the MANPADS envelope to
be very effective (which is why they operate almost exclusively at
night--the last one to try daylight operations got picked off by a SAM
during ODS). When was the last time you heard of an ARL-M or E-8 doing
either?
- Vulnerable manned aircraft like JSTARS & EP-3 operated deep
in Iraqi airspace
AFAIK, the E-8 remained outside the SAM threat envelope. Not sure what the
operating altitude was for the Aries, but I'd be surprised if they ever
ventured down into the MANPADS range or within the engagement circle of
larger Iraqi SAM's.
- Aerial refueling tankers penetrated to support ISR
I know of one report of a KC-135 going *towards* Baghdad at one point, but
did it enter within range of the surviving Iraqi AD assets? Doubt it.
- Unmanned vehicles nearly defenseless if attacked
of the ACS:
Obviously to be done using oblique imaging or UAV's reporting to the
aircraft--you don't think they intend to conduct overflights of an enemy
possessing an decent IADS, do you?
to the fight".
In which case it had either be very stealthy or use long range
sensors/UAV's; otherwise it will be meat for an IADS.
No, you have to *hit* them in order to make them a "deathtrap". How many
KC-135's, KC-10's, E-8's, EP-3's, or ARL-M's have been hit during combat
operations to date? None. How many have even been shot *at*? Again, AFAIK,
none.
They are
C-135.
Since they are not going into the hot part of the bad guy's threat envelope,
why do they need to be survivable in terms of enemy weapons effects?
comes to mind.
None of which have been lost due to combat operations, IIRC.
Since the SOF platforms operate in an entirely different threat environment,
I fail to see the connection to programs like ACS. Remember that the ACS
platform will be one of the current flock of business jets (Gulfstream and
Bombadier being major competititors for that role right now). The E-10 is
going to use a 767 platform. Now why do you think you know something about
the unsuitability of these systems that the combined brain power of the
USAF, USN, and US Army don't?
Brooks
Also
Old February 8th 04, 03:41 AM
sid
Sure. In the last few conflicts as the Lexington institue piece made
clear, but what about a few years down the road?
With long range SAM and AAW systems readily available for export its
not something that can be counted on. You may have missed this little
article in a December issue of AW&ST:
"Russian guided-weapons builder Novator is continuing to work, albeit
slowly, on an ultralong-range air-to-air missile, with a version on
offer for export to a select customer set.
Designated article 172, the weapon was included on a model of the
Su-35 derivative of the Sukhoi Su-27 Flanker, on display during the
Dubai air show. The export version, known as the 172S1, has a 300-km.
(186-mi.) range, compared with 400 km. for the original version
specified by the Russian air force. The missile, which is also
referred to (perhaps erroneously) as the KS-172, is intended to engage
specific high-value targets such as airborne warning and control
aircraft, air-to-ground surveillance and tanker platforms."
There were public reports of tanker assets going "downtown". The
commanding general flew one mission purportedly to allay tanker crews'
fears.
of the ACS:
And against an S-300(or equivalent) capapble opponent? They may have
to be risked to get the job done.
"UAV Wrangling" from aircraft is still in the early stages. Given
budget realities its likely going to be a capapbility somewhere up the
"spiral". Until then the standoff ranges will be measured for the
aircraft.
none.
As improtant as these aircraft are bcoming to our operational
doctrine, and as few of them as there are or will be, these vulnerable
aircraft will offer a rich target for an opponent with a big payback
no matter the cost to neutralize them. Looks like Novator for one is
already moving in on the business.
Because it appears the threats will be reaching out to them.
comes to mind.
Two P-3s were lost in 1968 to ground fire actually. Likely because of
vulenrability to hydrodynamic ram after a small caliber round hit
them. Same vulnerabilty that turned the DHL 'bus into a roman candle
after a small shrapnel hit. Same vulnerability that all civil
transports share.
Read through this selection of links and you will see that
vulnerabilty is a perennial back burner issue...Until losses bring it
front an center.
http://www.dtic.mil/ndia/aircraft/
This one in particular discusses historical lapses in this regard:
http://www.dtic.mil/ndia/aircraft/8.pdf
Old February 8th 04, 05:08 AM
Kevin Brooks
m...
At least two of your Lexington Institute "pieces" have endorsed the ACS and
E-10, with their commercial aircraft platforms--what does this say about
your theory that using commercial derivitive platforms is unacceptable?
http://www.lexingtoninstitute.org/defense/031218.asp
http://www.lexingtoninstitute.org/defense/031211.asp
is
What was there to miss? The acknowlegement that the pace of development on
this rather strange weapon is "slow"? How would it be targeted? 300 to 400
km is an awful long way for a fighter radar to "see", much less target.
but
fears.
Sure--going "downtown" after the IADS, or what was left of it pre-war, was
further destroyed. We lost *one* aircraft over Baghdad--an A-10 to an
SA-7/SA-18, IIRC. How much of a threat do you think that SA-18 was to any
KC-135's orbiting at 25K or so feet?
of the ACS:
Then you use your UAV's--that is what they are for, to go where manned
platforms shouldn't/can't.
They may have
I don't see the USAF placing its RC-135's at great immediate risk, nor do I
see the EP-3's doing that. As to ACS, remember that it is intended to
replace ARL-M (and the remaining RC-12's)--that "L" means low, as in "low
intensity". Nobody is going to be sortying them into an IADS environment.
Period.
aircraft.
Let's get this straight--you see a strong potential of AAM's that can engage
our E-10's at 300-400 km, but you think managing an existing UAV from an
airborne operator's station is too tough to handle? I find that a bit hard
to digest.
AFAIK,
none.
I would not be buying too much stock in that enterprise just yet.
envelope,
Your argument that this is the case is less than convincing so far.
comes to mind.
transports share.
Checking around, there was one confirmed shoot-down of a P-3 in SEA (both
following incidents VP-26 Orions). One was an "unknown" (may have very well
gone down due to accident), the other took a burst of .50 cal while doing a
*low level* pass over a suspect LCM, which set set no. 4 engine on fire. The
crew apparently tried to put as much distance between them and the bad guys
as possible before attempting to ditch, and the wing snapped in the vicinity
of the aforementioned fire. Note that these guys were doing visual recon
from low level--they did not have the super synthetic aperture radars we
have today. The EP-3 does not conduct low level missions, nor do the
ARL-M/RC-12. So what is the applicability of the loss of one P-3 that got
hammered by .50 cal (which can be tough on any airframe, even those designed
to military specs--my brother lost a UH-1 Dustoff bird during Lam Son 719 to
a .50 cal, and more than a couple of A-1's, etc., were allegedly brought
down by 12.7mm and *below* calibers) to current programs like the E-10 and
ACS?
environment,
and
is
about
front an center.
Great--for aircraft going into the thick of the combat. E-10 and ACS won't
be.
Brooks
Old February 7th 04, 04:23 AM
Les Matheson
Even though they say the C-130 isn't going to be capable, all the plans I've
seen for the AX and MX aircraft are based on a four engine turboprop design
that sure looks like a C-130J.
Les
F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret)
Old February 7th 04, 06:45 AM
Thomas Schoene
plans I've seen for the AX and MX aircraft are based on a four engine
turboprop design that sure looks like a C-130J.
Boeing has mentioned a tilt-wing design they call the Advanced Theater
Transport (aka Super Frog) that sure sounds like it fits the MX mission
description. Doesn't look all that much like a C-130J.
http://www.boeing.com/phantom/att.html
I wasn't able to find anything on Lockheed's ideas (MX is a hard term to
search on, even with modifiers)
Tom Schoene Replace "invalid" with "net" to e-mail
"If brave men and women never died, there would be nothing
special about bravery." -- Andy Rooney (attributed)
Old February 7th 04, 03:58 PM
Bill McClain
Hmm...no vert stab and rudder. Maybe the Navy will want some to
replace the C-2 Greyhound? If the wingspan isn't too great, they
might be able to put this on an aircraft carrier's deck elevator if
they have to strike it below; I think that was one of the issues with
using a C-130 for COD.
Old February 7th 04, 06:38 PM
John
is it just me, or does the ATT bear a strong resemblance to the
German Me 323 Gigant ?
Magneto/comm interference on TKM MX-R Narco 120 replacement Eugene Wendland Home Built 5 January 13th 04 02:17 PM
Canada to order replacement for the Sea King Ed Majden Military Aviation 3 December 18th 03 07:02 PM
Replacement for C130? John Penta Military Aviation 24 September 29th 03 07:11 PM
Narco MK 16 replacement SoulReaver714 Aviation Marketplace 1 September 23rd 03 04:38 PM
Hellfire Replacement Eric Moore Military Aviation 6 July 2nd 03 02:22 AM
