#11
Frank Olson wrote in
news:3Wk1k.4381$C12.2615@pd7urf3no: Bob Noel wrote: In article , Tina wrote: I understand how positive dihedral helps dynamic stability in airplanes, but some big ones, like the Russian An 124 Condor, has a pronounced negative dihedral -- the wings have a noticeable downward slope. Q1: Do those airplanes need active fly by wire controls to maintain stability, or is something else at play that keeps them right side up? Q2: Does anyone have a design rationalization for such a configuration, as opposed to just zero dihedral? I can appreciate why fighters have it -- they exploit lack of aerodynamic stability for rapid maneuvers -- but transports that spend their whole life being straight and level are another issue. Note: I have not morphed into an Mx clone! Don't know why, but don't those transports with negative dihedral also have wings above the hull? So those aircraft have the CG below the wings. And large transport aircraft are amongst the most aerodynamically stable aircraft to fly. Actually, that's not the case in every sense. They're not very speed stable, for instance and thye have other problems with two diferent kinds of dutch roll, related to sweep, mostly. Bertie |
On Jun 3, 10:25 pm, Bertie the Bunyip wrote:
Tina wrote in news:d9fb071f-4d30-45c3-916d- : I understand how positive dihedral helps dynamic stability in airplanes, but some big ones, like the Russian An 124 Condor, has a pronounced negative dihedral -- the wings have a noticeable downward slope. That's called Anhedral.. Q1: Do those airplanes need active fly by wire controls to maintain stability, or is something else at play that keeps them right side up? Nope. Q2: Does anyone have a design rationalization for such a configuration, as opposed to just zero dihedral? I can appreciate why fighters have it -- they exploit lack of aerodynamic stability for rapid maneuvers -- but transports that spend their whole life being straight and level are another issue. Well, the anhedral negates what can be excessive stability that comes form the sweep of the wings. Sweep provides a very similar kind of stability as does dihedral and the addition of anhedral negates some of this and keeps the airplane form becoming so stable that it can't even be maneuvered! Most of the airplanes with pronounced anhedral are high wing and would have parasol stability as well. The anhedral helps neutralise some of that. Some low wing Russian jets have anhedral, but it's quite small Their sweep is quite marked and the anhedral is there to ammeliarate that. The 727 had a fairly radical sweep and you will notice, that though it has dihedral it's very little compared to the 737 or similar. Note: I have not morphed into an Mx clone! We'll know for sure if you tell me this answer is completely wrong because your MSFS 172 doesn't have anhedral. Bertie Only after a very hard landing would a 172 develop negative dihedral. A Mooney, on the other hand, given the placement of the wheels, would either increase its positive dihedral, or more likely, given how strongly they are built, put a dent in the runway. |
"Kyle Boatright" wrote in
: "Tina" wrote in message news:d9fb071f-4d30-45c3-916d-3e4c00f89d52@ 34g2000hsh.googlegroups.com.. . I understand how positive dihedral helps dynamic stability in airplanes, but some big ones, like the Russian An 124 Condor, has a pronounced negative dihedral -- the wings have a noticeable downward slope. Q1: Do those airplanes need active fly by wire controls to maintain stability, or is something else at play that keeps them right side up? Q2: Does anyone have a design rationalization for such a configuration, as opposed to just zero dihedral? I can appreciate why fighters have it -- they exploit lack of aerodynamic stability for rapid maneuvers -- but transports that spend their whole life being straight and level are another issue. Note: I have not morphed into an Mx clone! Dihedral (or anhedral - negative dihedral) are both used to reposition the aircraft's Center of Lift (CL) vs the aircraft's CG. This effectively creates a pendulum, which wants to stabilize with the heavy part at the lowest possible position. Like a pendulum, relatively speaking, the farther above the CG the CL is, the more stable an aircraft will be. The whole "dihedral increases roll stability" issue is based around this, not increased or decreased roll due to lifting forces stemming from the attitude of the airplane. The roll forces which create stability are due to this pendulum effect. If you want a stable aircraft in roll, add as much dihedral as possible to raise the CL. If you want an unstable aircraft, do the opposite. The anhedral on some on high wing transports is probably designed to give a desired amount of stability. Some level of stability is great for a transport, but you don't want to create an aircraft so stable it requires oversized ailerons to generate the desired roll rate. All correct! Also, anhedral helps a bit with the high alt dutch roll case. I'd have to go into a lengthy explanation to cover it all, but suffice it to say that swept wing airplanes are subject to a roll yaw reversal at high altitues that can get rather unpleasnt ( complet loss of control) Most must fly with a yaw damper, which is a gyro-controlled rudder input that keeps the thing going straight. Anhedral offers a non mechanical ad to ammelierating this effect. In fact, the russians are notoriously clever at this sort of thing, which is why thye have madly maneuverable fighters with more or less conventional control systems while contemporary western aircraft relied on computers to achieve the same results. Bertie Bertie |
![]() "Bertie the Bunyip" wrote in message ... "Kyle Boatright" wrote in : "Tina" wrote in message news:d9fb071f-4d30-45c3-916d-3e4c00f89d52@ 34g2000hsh.googlegroups.com.. . I understand how positive dihedral helps dynamic stability in airplanes, but some big ones, like the Russian An 124 Condor, has a pronounced negative dihedral -- the wings have a noticeable downward slope. Q1: Do those airplanes need active fly by wire controls to maintain stability, or is something else at play that keeps them right side up? Q2: Does anyone have a design rationalization for such a configuration, as opposed to just zero dihedral? I can appreciate why fighters have it -- they exploit lack of aerodynamic stability for rapid maneuvers -- but transports that spend their whole life being straight and level are another issue. Note: I have not morphed into an Mx clone! Dihedral (or anhedral - negative dihedral) are both used to reposition the aircraft's Center of Lift (CL) vs the aircraft's CG. This effectively creates a pendulum, which wants to stabilize with the heavy part at the lowest possible position. Like a pendulum, relatively speaking, the farther above the CG the CL is, the more stable an aircraft will be. The whole "dihedral increases roll stability" issue is based around this, not increased or decreased roll due to lifting forces stemming from the attitude of the airplane. The roll forces which create stability are due to this pendulum effect. If you want a stable aircraft in roll, add as much dihedral as possible to raise the CL. If you want an unstable aircraft, do the opposite. The anhedral on some on high wing transports is probably designed to give a desired amount of stability. Some level of stability is great for a transport, but you don't want to create an aircraft so stable it requires oversized ailerons to generate the desired roll rate. All correct! Also, anhedral helps a bit with the high alt dutch roll case. I'd have to go into a lengthy explanation to cover it all, but suffice it to say that swept wing airplanes are subject to a roll yaw reversal at high altitues that can get rather unpleasnt ( complet loss of control) Yep. Early 707's had a big enough dutch roll problem that it resulted in aircraft being lost. This brought forth a redesign of the vertical stab. Most must fly with a yaw damper, which is a gyro-controlled rudder input that keeps the thing going straight. Anhedral offers a non mechanical ad to ammelierating this effect. In fact, the russians are notoriously clever at this sort of thing, which is why thye have madly maneuverable fighters with more or less conventional control systems while contemporary western aircraft relied on computers to achieve the same results. Bertie Bertie |
: "Bertie the Bunyip" wrote in message ... "Kyle Boatright" wrote in : "Tina" wrote in message news:d9fb071f-4d30-45c3-916d-3e4c00f89d52@ 34g2000hsh.googlegroups.com.. . I understand how positive dihedral helps dynamic stability in airplanes, but some big ones, like the Russian An 124 Condor, has a pronounced negative dihedral -- the wings have a noticeable downward slope. Q1: Do those airplanes need active fly by wire controls to maintain stability, or is something else at play that keeps them right side up? Q2: Does anyone have a design rationalization for such a configuration, as opposed to just zero dihedral? I can appreciate why fighters have it -- they exploit lack of aerodynamic stability for rapid maneuvers -- but transports that spend their whole life being straight and level are another issue. Note: I have not morphed into an Mx clone! Dihedral (or anhedral - negative dihedral) are both used to reposition the aircraft's Center of Lift (CL) vs the aircraft's CG. This effectively creates a pendulum, which wants to stabilize with the heavy part at the lowest possible position. Like a pendulum, relatively speaking, the farther above the CG the CL is, the more stable an aircraft will be. The whole "dihedral increases roll stability" issue is based around this, not increased or decreased roll due to lifting forces stemming from the attitude of the airplane. The roll forces which create stability are due to this pendulum effect. If you want a stable aircraft in roll, add as much dihedral as possible to raise the CL. If you want an unstable aircraft, do the opposite. The anhedral on some on high wing transports is probably designed to give a desired amount of stability. Some level of stability is great for a transport, but you don't want to create an aircraft so stable it requires oversized ailerons to generate the desired roll rate. All correct! Also, anhedral helps a bit with the high alt dutch roll case. I'd have to go into a lengthy explanation to cover it all, but suffice it to say that swept wing airplanes are subject to a roll yaw reversal at high altitues that can get rather unpleasnt ( complet loss of control) Yep. Early 707's had a big enough dutch roll problem that it resulted in aircraft being lost. This brought forth a redesign of the vertical stab. That's right. I never flew it but the guys who did said the high alt departures were so violent as to be truly frightening. The 727 was pretty wild if it lost its yaw dampers and the only cure was to get down to where the mach margins were wide enough not to be an issue. Fortunately I only ever had a double yaw damper failure in the sim. Bertie |
On Jun 3, 5:05 pm, wrote:
Tina wrote: I understand how positive dihedral helps dynamic stability in airplanes, but some big ones, like the Russian An 124 Condor, has a pronounced negative dihedral -- the wings have a noticeable downward slope. No idea of why or how it stays upright. From the pictures I've seen of it in the air, most of that negative dihedral seems to go away while flying. Yup, here's an example. http://www.google.com/search?hl=en&q...=Google+Search Ken |
On Jun 4, 2:30*pm, Tina wrote:
On Jun 3, 10:25 pm, Bertie the Bunyip wrote: Tina wrote in news:d9fb071f-4d30-45c3-916d- : I understand how positive dihedral helps dynamic stability in airplanes, but some big ones, like the Russian An 124 Condor, has a pronounced negative dihedral -- the wings have a noticeable downward slope. That's called Anhedral.. Q1: Do those airplanes need active fly by wire controls to maintain stability, or is something else at play that keeps them right side up? Nope. Q2: Does anyone have a design rationalization *for such a configuration, as opposed to just zero dihedral? I can appreciate why fighters have it -- they exploit lack of aerodynamic stability for rapid *maneuvers -- but transports that spend their whole life being straight and level are another issue. Well, the anhedral negates what can be excessive stability that comes form the sweep of the wings. Sweep provides a very similar kind of stability as does dihedral and the addition of anhedral negates some of this and keeps the airplane form becoming so stable that it can't even be maneuvered! Most of the airplanes with pronounced anhedral are high wing and would have parasol stability as well. The anhedral helps neutralise some of that. Some low wing Russian jets have anhedral, but it's quite small Their sweep is quite marked and the anhedral is there to ammeliarate that. The 727 had a fairly radical sweep and you will notice, that though it has dihedral it's very little compared to the 737 or similar. Note: I have not morphed into an Mx clone! We'll know for sure if you tell me this answer is completely wrong because your MSFS 172 doesn't have anhedral. Bertie Only after a very hard landing would a 172 develop negative dihedral. A Mooney, on the other hand, given the placement of the wheels, would either increase its positive dihedral, or more likely, given how strongly they are built, put a dent in the runway. With those struts I would expect polyanhedral! Cheers |
Another old negative | Don Pyeatt | Aviation Photos | 0 | March 2nd 08 05:32 PM |
"predator' dihedral | Phil Rhodes | Naval Aviation | 5 | May 25th 07 09:54 PM |
Wing dihedral | Dallas | Piloting | 35 | March 20th 06 04:01 PM |
how to cope with negative g´s? | Markus | Aerobatics | 6 | July 2nd 05 12:00 AM |
Biplane wing dihedral | vincent p. norris | General Aviation | 20 | June 18th 05 02:58 AM |
