aircraft brakes were never designed for stopping aircraft.
Old July 31st 08, 04:20 PM posted to rec.aviation.homebuilt
Default aircraft brakes were never designed for stopping aircraft.
On Jul 31, 7:00 am, Stealth Pilot
On Wed, 30 Jul 2008 16:14:26 -0700 (PDT), 150flivver
now brakes for commercial aircraft are different and they *are* used
for stopping, but the brakes on little lighties arent.
some people have yet to realise that.
Stealth Pilot
What an utterly absurd statement! You may not need to use the brakes
to stop but that's what they're there for. On a long enough runway I
may not use the brakes at all but on a short runway, you better
believe the brakes will be needed to stop whether you're flying a 747
or a C-150. Everything is a compromise concerning weight and
capability on an aircraft; aircraft brakes on light aircraft may not
have the stopping power of power disc brakes on a dump truck but both
are designed for "stopping."
one day it is hoped that you will learn something of aircraft design
and good piloting skills.
untill then I suppose you'll just keep plugging away doing the best
you can as a poor pilot.
the brake pads on your aircraft are about 3/4" x 2" in size.
the aircraft weighs 1500lb.
From the Cessna 172M POH, regarding forced landings:
6. Airspeed--65 to 75 MPH (flaps down)
7. Turn off master switch
8. Unlatch cabin doors prior to final approach
9. Land in a slightly tail-low attitude
10. Apply heavy braking while holding full-up elevator.
The Canadian Flight Training Manual, in the Landings section,
mentions braking during rollout several times.
In Canada we have something called the Canadian Runway Friction
Index (formerly the James Brake Index) and it gives approaching pilots
an idea of the runways surface conditions for things like steering and
braking during the landing rollout. I imagine other countries
(including Australia) have a similar scale.
So, it would seem that both the manufacturer and the people
who govern both flight training and international airports expect us
to use the brakes in the landing roll. Strange, huh?
We run six airplanes in flight training service. We find that
the brakes aren't hurt by normal use, even by heavy braking in a short-
field landing. It's the guys who taxi with too much power and hold the
taxi speed down using brake, and do that for 2000' on the taxiway.
That's when they get really hot and the metallic bits in the pads
begin to weld to the discs. Small raised steel burrs on the disc then
chew the pads up.
The pads and discs on a 150, say, are not unusually small for
the weight of the airplane when they're compared to the pads and discs
on the front of my compact car, which grosses three times as much as
the 150 and goes a lot faster on the ground than the 150 does. (The
rear brakes in most cars contribute maybe 20% of total braking and you
might not even miss them if they didn't work.) McCauley, and Cleveland
after them, design light aircraft bakes that are expected to stop
airplanes. If they didn't, someone else would and the manufacturers of
airplanes would buy those better brakes, believe me.
Dan
Old July 31st 08, 10:03 PM posted to rec.aviation.homebuilt
150flivver
...but why am I surprised. the average american doesnt even know how
to change a tyre.
Stealth Pilot
Gosh darn! I'm hurt that you call me a poor pilot because I
occasionally find it necessary to step on the brakes to stop my
aircraft. The placard against using the brakes for stopping must have
gone missing. The reverse thrust lever on my aircraft must have gone
missing along with that placard. How does a masterful pilot like
yourself decelerate on a short field landing before going off into the
trees? Perhaps you're used to landing on aircraft carriers with
arresting gear? Me thinks "Stealth Pilot" would be more aptly named
"Imaginary Pilot."
Old August 1st 08, 04:29 AM posted to rec.aviation.homebuilt
Harry K
On Jul 31, 6:00*am, Stealth Pilot
Stealth Pilot
What an utterly absurd statement! *You may not need to use the brakes
to stop but that's what they're there for. *On a long enough runway I
or a C-150. *Everything is a compromise concerning weight and
to change a tyre.
Stealth Pilot- Hide quoted text -
- Show quoted text -
You have recieved sane and reasoned responses to your 'theory'. They
have even provided some cites to back them up. Where is your evidence
that your 'theory' is correct? Untill you provide some respectable
source, I, and I am sure others, can one regard it as a 'cockamamie
theory'.
Harry K
Old August 1st 08, 02:19 PM posted to rec.aviation.homebuilt
Steve Foley
"Stealth Pilot" wrote in message
as I put it in the subject line aircraft brakes were never designed
for stopping aircraft. they were designed to hold aircraft.
Where is that written?
Old August 2nd 08, 01:16 AM posted to rec.aviation.homebuilt
Sliker
Well, that "may" be true for certified aircraft. But with a homebuilt,
all bets are off. The builder is free to overpower his brake system
however he sees fit. And put large and powerful enough brakes on it to
provide plenty of energy absorbing power to stop his aircraft. Even
airliners have definite limits on their brakes. You take off heavy and
abort above 100 knots, and you are most certainly going to be in the
"melt zone". wherby the fuse plugs will melt and deflate the tires by
design. So your statement can't be a blanket statement about all
aircrat. Depends on the aircrafts weight at takeoff or landing. the
speed at which the brakes are applied to bring the aircraft to a stop.
It's all about engery, which is variable for each instance. So even
large aircraft have limits to their stopping power. They'll stop the
aircraft at just about any weight, but over a certain amount, and you
better not stand too close to it after landing.
Plus, way back when, old light aircraft had crap for brakes. Back when
Stinsons, Swifts, and other postwar aircraft were built, there were no
Cleveland brakes. With those, and clones of them, you can stop just
fine.
On Sat, 19 Jul 2008 18:54:27 +0800, Stealth Pilot
some interesting points came out of one guy's query re servicing some
old brake master cylinders.
gringomasloco commented regarding broken brake lines spraying brake
fluid over hot calipers and setting the wheels on fire. hmmmmm.
I am talking about light private aircraft here...
now that may sound like semantic nonsense but it is true.
aircraft brakes were designed for use in holding the aircraft still
while the engine was started. after the taxy out and the engine has
warmed you do a run up check to make sure that the magneto circuits
are up to the bit of work that lies ahead for them. the brakes are
applied to hold the aircraft while the revs are bought up and each
maggy checked in turn.
from a design aspect that is the end of the use of a light aircraft's
brakes until after landing and we wish to hold the aircraft still for
shutdown and disembarkation.
of course brakes are brakes and people will use them like they were
driving cars. light aircraft brakes were never designed for slowing an
aircraft when landing.
I know that they get used for that by students of bad piloting
technique but the design intent is a fact borne out by their
diminutive size.
I'll give one concrete example. The Stinson 108 is a huge aircraft, 4
seats in 1940's luxury, yet it only has brake pucks the same size as a
5.00x5 cleveland. in fact on the one Chris M-F ownes the brakes *are*
cleveland 5.00x5 calipers.
it is quite ok to be masters of the world and fly however you like.
you'll just wear out your aeroplanes faster.
just remember though that aircraft brakes are for holding the aircraft
not stopping it.
Stealth Pilot
Old August 2nd 08, 02:00 AM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
"Sliker" wrote in message
fine.
Does a 1946 Cessna 120 qualify as a "postwar aircraft"? Brakes were good
enough for stopping hard enough to keep the tail in the air until you
stopped.
Geoff
Old August 2nd 08, 02:32 AM posted to rec.aviation.homebuilt
Sliker
If the brakes were that good, that was a nice exception. The postwar
stuff I flew had lousy brakes. Like the Swift with the orginal
Goodyear brakes. The disk pucks were about as big around as a quarter.
I know they must have known those wouldn't stop the plane.
The Champ had weak brakes too. And just about any of the planes with
heel brakes were pretty weak. And the worst were the ones with
mechanical brakes. I hear that's pretty much what got the old Ford
Model A's off the road. They couldn't pass inspection with mechanical
the installed mechanical brakes. Is there anyone hear that drove
those?
On Fri, 1 Aug 2008 20:00:57 -0400, "Capt. Geoffrey Thorpe" The Sea
fine.
stopped.
Old August 2nd 08, 04:56 AM posted to rec.aviation.homebuilt
Ed Sullivan
On Fri, 01 Aug 2008 20:32:29 -0400, Sliker
those?
My '34 Ford had mechanical brakes and if I'm not mistaken the '37 Ford
still had mechanical brakes, maybe even later.
Ed Sullivan
Old August 2nd 08, 05:16 AM posted to rec.aviation.homebuilt
Harry K
those?
Ed Sullivan
37 for sure, don't know about later. What got them off the street was
not inspections but market force. I don't think there even _were_
vehicle inspections back in the late 30s.
Harry K
Old August 3rd 08, 12:59 AM posted to rec.aviation.homebuilt
Charles Vincent
those?
Ed Sullivan
There are still Model A's on the road today. I have a neighbor and an
uncle with bone stock model A's that are licensed and tagged and still
driven regularily on weekends.
Charles
Aircraft parts FS Cleveland Whels Brakes & Discs ! Victor Bravo Home Built 1 August 18th 07 05:00 PM
Aircraft parts FS Cleveland Whels Brakes & Discs ! Victor Bravo Aviation Marketplace 1 August 18th 07 05:00 PM
Commercial rating: complex aircraft required aircraft for practical test? Marc J. Zeitlin Piloting 22 November 24th 05 05:11 AM
Intended stopping point W.J. \(Bill\) Dean \(U.K.\). Soaring 0 February 17th 05 03:04 AM
Experience transitioning from C-172 to complex aircraft as potential first owned aircraft? Jack Allison Owning 12 June 14th 04 09:01 PM
