cabin pressure and health
Old August 17th 08, 04:20 PM posted to rec.aviation.piloting
Vaughn Simon
Default cabin pressure and health
Is there a link other than a common country between the engine makers
and Austin Healey cars? The AH I had positioned the distributor
exactly where water would splash when I drove through a puddle. There
was no need to put a top on that car, if it was raining it wouldn't go
anywhere anyhow. But it would leak! It was the car I owned that was
both the most trouble and the most fun to drive.
And don't forget the joys of Lucas electrics! (The Prince of darkness)
Does Lucas make aircraft electrics?
Vaughn
Old August 17th 08, 07:11 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
wrote in
On Aug 17, 10:48*am, Bertie the Bunyip wrote:
James wrote
innews:8KCdnZwGw601sTXVnZ2dnUVZ_jGd
Robert Moore wrote in
.15.205:
Bertie the Bunyip *wrote
The next generation are eschewing bleed air driven pressurisation
and going to seperate supercharger systems. A lot of older
turboprops used this system as well as a small number of jets.
The 787 will have this system. *
The B-707 had both Bleed Air and Turbochargers. We used the
Turbochargers most of the time. An engine bleed line spun a
turbine which then turned a fresh outside air compressor.
Yeah, that was the jet exception I had noted. You were lucky you
didn't have to breath the compresser section air in that thing!
The JT8 was OK AFAIK There would have been some fumes, but the
RB-211 is a complete piece of junk. The Brits never could build an
oil tight engine....
Thats why you never change the oil in a british engine, *you just
change the filter every 6000 miles, with the leak and replace of
the oil, oil changes are just a waste of time.
True, and they actually don't change the oils in RB 211s either! That
is part of the problem. As jet oil ages it gets thinner and leaks
more easily, and it also gets smellier.
Bertie
They're worth a lot of money now!
I got a rubber boot to go over the distributor on most of the brit cars
I owned. It did help a lot. Just had to replace the cap on my VW for the
same reason. Must be twenty years since moisture stopped a car of mine..
Bertie
Old August 17th 08, 10:25 PM posted to rec.aviation.piloting
Flydive
Vaughn
Oh yes, they do.
Old August 17th 08, 10:52 PM posted to rec.aviation.piloting
Ken S. Tucker
On Aug 16, 5:20 am, wrote:
Boeing funded a clinical trial to actually determine the effects of
being at an 8000 foot altitude for extended periods, and the results
were published last year in the New England Journal of Medicine. It's
an interesting read: here's the URL Many peer reviewed journal
articles require membership in an appropriate group (usually involving
fees) to be read: this one is freely available.,
http://content.nejm.org/cgi/content/abstract/357/1/18
For what it's worth, the number of subjects involved, and the
inclusion/exclusion criteria were fairly limited ( a couple of
hundred people, not nearly enough to uncover rare but important
conditions that could impact health) but the population probably is
representative of those holding Class III medicals or better. It's
fair to say nothing surprising was uncovered, except to learn that
such a study had not been done long ago.
It reminds me of the old adage that we should drink 8 glasses of water
a day. That's something that has actually been debunked in a recent
study.
Of the gazillion times I've flown, once I had a
problem equalizing ear drum pressure, that was
quite uncomfortable. I guess the *rate of change*
of barometrics is a subjective unknown, as it does
require a rate of adaptation.
Ken
Old August 17th 08, 10:56 PM posted to rec.aviation.piloting,alt.usenet.kooks
Bertie the Bunyip[_25_]
"Ken S. Tucker" wrote in news:1ba773f7-5205-45c8-
study.
Very little in your head to block the passage of air...
Bertie
Old August 17th 08, 11:01 PM posted to rec.aviation.piloting
Gino Marchetti
"Vaughn Simon" wrote in news:9lXpk.5591
I believe they also make refrigerators, which is why the Brits drink warm
beer.
Old August 18th 08, 02:40 AM posted to rec.aviation.piloting
Dakota
Bertie
You have a VW also?
Do you have to push it home as often as you do your motorcycle, or do you
let someone else work on it?
Dakota
James wrote in
5.205:
turboprops used this system as well as a small number of jets. The
Turbochargers most of the time. An engine bleed line spun a turbine
Thats why you never change the oil in a british engine, you just
change the filter every 6000 miles, with the leak and replace of the
True, and they actually don't change the oils in RB 211s either! That is
part of the problem. As jet oil ages it gets thinner and leaks more
Bertie
Much like the fluid on your brain.
Old August 18th 08, 02:49 AM posted to rec.aviation.piloting
Dakota
5.205:
and going to seperate supercharger systems. A lot of older turboprops
used this system as well as a small number of jets. The 787 will have
this system.
The B-707 had both Bleed Air and Turbochargers. We used the Turbochargers
most of the time. An engine bleed line spun a turbine which then turned
Yeah, that was the jet exception I had noted. You were lucky you didn't
The JT8 was OK AFAIK There would have been some fumes, but the RB-211 is
a
complete piece of junk. The Brits never could build an oil tight
engine....
Bertie
Damn, I wish they would have let you design it. It would have been perfect,
uh.
Old August 18th 08, 02:54 AM posted to rec.aviation.piloting
Dakota
Thin air and even radiation exposure are insignificant in comparison to
the problems associated with engine oil seeping into the aircon. Some
airplanes are a lot worse than others, the older Rolls Royce powered
757s and TriStars being the worst with the Lycoming Powered Bae 146s not
far behind. Almost all have the problem to some extent or another.
All jet oils, particularly Mobil, contain huge amounts of nasties such
as organo-phosphates which affect the central nervous system and are
extremely hard to get rid of. Almost all airliners have this problem,
however, and every time you fly on one you get a certain amount of this
crap in you.
If you ever get on an airliner and you get a certain sour "smelly
socks" smell, that means there's an unusually high concentration and
that the engine seals arent doing their job. If you get enough in your
system during a flight, you'll probably have runny eyes and irritation
in your throat and sinuses. If you get a high enough dose in one flight,
you'll also have a nice tingly headache right at the top of your skull.
A major dose will bring about a night wither on, or kneeling in front of
the toilet...
It's a huge problem that the airlines and manufacturers are keeping as
quiet as possible about because of the huge liability exposure they
have. The next generation are eschewing bleed air driven pressurisation
this system.
Bertie
I'll forward this to all the airlines and let them know their pilots are
concerned enough to be posting to the world.
What is cabin air pressure set at scm General Aviation 25 October 16th 05 03:29 AM
Cabin Air Pressure [email protected] Piloting 9 December 20th 04 03:07 PM
Cabin Pressure Altitude Greg Esres Piloting 4 March 24th 04 08:35 PM
Punctured pressure cabin. M. J. Powell Military Aviation 103 January 5th 04 06:16 AM
Greatest Altitude without pressure cabin/suit W. D. Allen Sr. Military Aviation 12 July 26th 03 04:42 PM
